Maxima Timing belt noise??
Old Nov 23, 2006 | 03:42 PM
Snobgoblin's Avatar
My 04 Maxima is making a faint screachy noise when i turned it on from a cold start. I let it warm up but the sound has gotten worse. I think its coming from the timing belt but i'm not sure. Is there some lube or something we need to put on the timing belt. Do we need to lube the belt under the hood? My max has 35k miles.
ONe more question. What is a good oil filter to get for our cars?? And the oil filter number.
Old Nov 23, 2006 | 04:47 PM
bluemaxx's Avatar
Moderator GT-R
There is no timing belt on your Maxima.
Old Nov 23, 2006 | 04:54 PM
Ritz's Avatar
timing belts are covered (by a timing cover, of course) and go between the crankshaft and camshaft to keep the valves opening in correct time.
serpentine belts/v belts go around the pulleys on the accessories of your engine, providing your power, a/c, steering, etc. they're also not generally covered by anything and is often mistaken for a "timing belt"
now that THAT lesson is over....
when the serpentine/v belt squeeks/screeches or whatever, it usually means it's just loose or wearing out (stretching) ... 35k miles is a little early for those to be going though. cold weather tends to make it happen much easier though. the only thing you can really do to fix the noise is adjust pulleys to counter the stretching... or just replace them.
Old Nov 26, 2006 | 04:26 PM
bluemaxx's Avatar
Moderator GT-R
On most Maximi, the timing belt is made from steel fashioned into the shape of three chains similar to:
The accessories are driven by two belts:
Old Nov 26, 2006 | 04:48 PM
NismoMax80's Avatar
SuPeRmOd
check the oil forum....
and like stated the squeak cannot come from your Timing Chain.
Old Nov 28, 2006 | 11:35 AM
nismo_star's Avatar
check your belts could be cracked to crap and/or your tensioner, probably loose belts.
check all accessories such as a/c compressor and alternator.
Hondarydr
Dec 30, 2024 06:15 PM
PH98I30
19
Jun 13, 2016 02:38 PM
maxinout93
Oct 27, 2015 01:29 PM
egali045
Aug 16, 2015 01:19 PM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
