Suspension help
Old Dec 5, 2006 | 11:04 AM
Big Mike's Avatar
Suspension help
Does anyone have detailed instructions for strut/shock removal and install? I am purchasing some struts/shocks and springs and would appreciate any technical guidance I can get.
Mike
Old Dec 5, 2006 | 11:32 AM
!PrjctMax!'s Avatar
struts=front is 3 12 or 14mm bolts on top to remove, then 1 bolt to take off the endlink and then 2 bolts to take off the strut
shock=rear i had a shop do so because i'm not too familiar with that setup and didnt want a spring to take my head off
hope this helps a little
dan
Old Dec 5, 2006 | 01:22 PM
gec
Mike
who are you getting them from... it may come with step by step directions.
Old Dec 6, 2006 | 07:07 AM
Big Mike's Avatar
I am ordering them from the group buy.
Old Dec 6, 2006 | 07:16 AM
xoomer.com's Avatar
I Donate! Why Don't You?
If its catman (Progress) then all directions will be included.
Old Dec 6, 2006 | 08:31 PM
madmik's Avatar
Ever used spring compressors? Are you sure you have all the tools? 12/14/15/17 mm sockets. 17 or 19mm for 2 bolts on lower strut. Solid jack and stand. WD40, blue loktite.
The rear lower link under the spring must be detached from the knuckle side. Car frame must rest on a jack stand and an hydraulic jack placed under the spring while you remove the bolt. Remove hydraulic jack and then press down on lower arm. Will have to wrestle a bit to get spring out. The rear top 2 bolts holding the strut will uncover an empty cavity. Got to transfer that cover to the new strut.
If its your first time, plan a whole day event. I installed my Progress/KYB, then switched the Progress for Eibach's. I have done springs and shocks many times before but this mod made me curse.
Get the service manual from
http://www.phatg20.net/modules.php?n...titleA&show=10
Old Dec 6, 2006 | 09:29 PM
MisterSparkle's Avatar
yeah mad mike said it right the hardest thing your going to be doing IMO will be the front struts... if your doing the cattman KYB and progress sets...then IE don't forget to use the bump stoppers...lolxz
too long to explain...buh its self explanatory if you have the tools...thats goin to be the pain...the tools...otherwise you'll be good.
Old Dec 7, 2006 | 12:19 PM
Big Mike's Avatar
Thanks for you help fellas. I couldn't open the FSM attachment on Phatg20's web site. I don't have the .rar format I guess.
Old Dec 7, 2006 | 12:32 PM
CanadianMoFo's Avatar
.rar is WinRAR. You can get it off download.com
Old Dec 8, 2006 | 05:55 PM
Big Mike's Avatar
Thanks!! I downloaded the FSM for my maxima. After reading through the suspension section of the manual I am confident I can do it. I did this before on my Jetta turbo. I am lucky since I have access to the Navy hobby shop, they have a lift and every tool known to man. I only have to pay about 10 buck to use the stall for a couple of hours. They also have certified mechanics to give you pointers when you get stumped. Thanks for everyone's help I will let you know how it turns out, I will upload before and after pics.
Mike
Old Dec 8, 2006 | 06:03 PM
Big Mike's Avatar
Also, should I replace the front mounts and bearings when I swap out the struts? I don't want any issues after I get everything all buttoned up.
Mike
Old Dec 8, 2006 | 06:08 PM
!PrjctMax!'s Avatar
Mike
you shouldn't have a problem with those...but if you can get the parts for cheap and don't mind possibly wasting the money then go for it!
Old Dec 8, 2006 | 06:11 PM
Big Mike's Avatar
I guess I will just replace the struts/shocks and springs.
Thanks,
Mike
Old Dec 8, 2006 | 07:13 PM
wait how many miles do you have on the car...i mean if you have a lot then maybe you should...just take a look at the mounts and see what condition they are in...if they look worn maybe you should if not leave them...i don't they should be good for at least 50K...
Old Dec 9, 2006 | 04:46 AM
Big Mike's Avatar
I have 53K on the car now, I will inspect them and replace if necessary.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
