CE y-pipe: Is it slower with it?
Old Dec 14, 2006 | 02:52 PM
Nietzsche's Avatar
So I put the y-pipe on with the motor mounts and I got to say I think the car might be slower. It's hard to say, at times it seems a little fast, at times a little slower. Also it seems to rev slower, is that even possible swapping an exhaust. I'm so confused. A freer flowing exhaust should help make more power. I am aware I need to tune to get full potential, but freeing up the exhaust should net some gains without a tune.
Thoughts?
Old Dec 14, 2006 | 03:13 PM
!PrjctMax!'s Avatar
A freer flowing exhaust will provide more mid-top end power while sacrificing lower end power
dan
Old Dec 14, 2006 | 03:54 PM
Nietzsche's Avatar
But a factory exhaust that pinches the tubes will hurt EVERYWHERE. Smaller is not better and people can debate what they will, but a larger exhaust will always net more power as long as it doesn't completely kill velocity.
Off point, it seems slower on the bottom, mid, and top; plus the revving issue.
I would like to hear only from people who have run this mod prior or are currently using it.
No offense to anyone, but I want to hear from experience, not theory.
Old Dec 14, 2006 | 04:14 PM
HotshotVQ35's Avatar
i have a cattman y on my 02. our exhausts are very similar. i dynoed 218WHP/228TQ with the y and a short ram. its worth maybe 5-10WHP. headers is the way to go, i got my HS ones going on soon. the older maximas had the cats in the y and gained lots of power. for your car and mine, the precats are in the manifolds, thats why headers give so much power
Old Dec 14, 2006 | 04:25 PM
Nietzsche's Avatar
So you see no reason why I shouldn't be making more power with the mod?
Old Dec 14, 2006 | 04:55 PM
u should pick up a few HP, its not going to be incredible, but figure 5-10.
Old Dec 14, 2006 | 05:50 PM
Nietzsche's Avatar
That's what I thought, but why would it feel slower and seem to rev slower? I wasn't expecting a power house from a y pipe, but certainly not going slower.
Old Dec 14, 2006 | 08:23 PM
!PrjctMax!'s Avatar
lololol
Old Dec 14, 2006 | 10:03 PM
xorbitman's Avatar
Did you flash your ECU? IF you did not modify your ECU or add a APEXi computer then your cars computer will actually modify it's output to negate most of the aftermarket goodies. I manually reflash the computer by using the pedal/floor technique. I am so praticed at this that I can do it in under 2 mins and voila lots of power. I also put in 94 Octane in the summer, so with all of that man does it unleash the beast! In the summer I do this about every 300 miles and/or every 2 fillups. Or on a sunny summer day when I feel like Mario Andretti LOL! There are guys here that are getting 250 HP at the wheel! I once shamed a 1998 Camaro SS on the Highway that was trying to pass me! Ha ha you should of seen the look on his face as I shifted from 3rd to 4th on the Auto tranny using the technique of holding down the shifter in manual mode. This keeps the tranny from shifting early in to 4th alowing you to redline in to 4th by using your lock up torque converter. But you need to know your engine sound and precise shift point or the failsafe will kick in. Some Max's here redline at 110 mph in 3rd gear! I don't advocate racing especially in the street. I don't like it on the highway either although an open stretch of emtpy highway is nice though.
Safe and Happy motoring!
Old Dec 15, 2006 | 12:01 AM
RHMax's Avatar
Newbie just Registered
What other mods you have? With y-pipe, you do lose some back pressure which decrease some initial torque, but give you more power up top. Same with CAI and exhaust. If you have all 3 then you'd really notice the lowend loss.
Old Dec 15, 2006 | 06:23 AM
xoomer.com's Avatar
I Donate! Why Don't You?
Makes me triple think if I want to do it now. I already have CAI which definitelly takes away from low end and picks up like a monster once the RPM is high'er. If I add the Y-pipe and catmann exhaust and it takes away the low end...than I might as well skip it.
Old Dec 15, 2006 | 11:03 AM
kamski's Avatar
.org extraordinaire
Dont judge before you try. Ask "DeusExMaxima" how his car whoops people at the track.
The key to all the mods is the ECU. If u lean out your mixture by adding go-fast gadgets (CAI, Y-pipe, Exhaust) you need to have the ECU tuned to dump more gas at early throttle tip in.
I'm pretty positive Deus has the fastest N/A no bottle 6th gen here. When he gets his headers..... good bye.
Kamski
Old Dec 15, 2006 | 11:06 AM
xoomer.com's Avatar
what would be required to "upgrade" the ECU. Is it safe?
Old Dec 15, 2006 | 11:12 AM
kamski's Avatar
.org extraordinaire
Best person to ask is Deus or TeqNik, they both have the upgrades. All you need to do is Dyno the car and send the DynoSheet and runfiles to Technosqare along with your ECU. They will reprogram your ECU to account for the DYNO runs and ship it back to you.
Its safe and they can allways reverse it.
BOOM TEK got 19hp and Deus..... im not even sure what he got but whatver it was it was FAST.
Kam
Old Dec 15, 2006 | 01:43 PM
Nietzsche's Avatar
I know the bottom end loses a bit, but even the top end feels softer. Reseting the ECU doesn't do much in the long run plus I have the timing advanced and am not sure if it would revert to the standard timing. Anyone know if clearing the ECU switches your timing back to normal? Once I get a datalogger I will be monitering my ratios and getting a flash done.
Old Dec 16, 2006 | 06:50 PM
xorbitman's Avatar
I would recommend that you get a UDP. This will free up bottom end big time.
Also a pop charger like a Fujita in stead of a CAI like an AEM would improve that also. I prefer having the passing power on the highway so all this is good. My spring goodies will include a Y-pipe, Greddy Cat Back and installation of my APEXi NEO which I already have in the closet.
Old Dec 16, 2006 | 07:15 PM
NmexMAX's Avatar
dot dot dot ...
A test pipe will free the 'top end'.
Old Dec 16, 2006 | 10:01 PM
madmik's Avatar
A few weeks ago I got the CE Y-Pipe and a spare ECU flashed by Technosquare. Hours after, the SES light came on. Like I posted on other threads, I found my A/F going real lean (18:1). CAI, headers and mods that improve air flow will lean out the A/F and make you loose mid-range power during WOT. After a few weeks working with my Autoginuity software I got the A/F between 12.3:1 and 13.7:1. I modified the MAF sensor to increase the air flow to force the ECU to run richer. I had to increase the MAF airflow by 30%+ to get stoic again. I don’t recommend this approach unless you have this software, Cipher or other datalogging tool.
You can send the ECU back to Techno after every mod but that's $150 a pop. The correct way IMO is to get a piggyback controller like Apexi Neo, AEM fic, Greddy E-manage, HKS, etc. This will allow you to fine tune the A/F ratio across the RPM range.
I did notice the Y-pipe power variation before I fixed the A/F. The reason I found: 1) under closed loop (partial throttle), the ECU will adjust the ‘trims’ and attempt to stay stoic using the O2 signal (but was still a bit lean on my car). 2) At WOT or under heavy throttle, the ECU goes to open loop. In that mode, the ECU stops using the O2 data and primarily uses its fuel map and MAF data. The impact for me was a real lean condition with A/F between 16:1 and 18:1. I did not believe my software and went for a dyno run. Got 18:1 between 2.5-5K rpm, down to 14.9:1 @ 5700, and back to 18:1 at 6400. An A/F of 18:1 is not real safe. Engine ran well when cold/cool, but sluggish when very hot.
The reason my SES light came on with code P0171, P0174 was the combo of the CAI and Y-pipe sending the A/F lean beyond what the ECU could adjust. Now with a better fuel ratio, the timing has backed off almost 5 degrees (no more pigging), the engine runs cooler, and power is up about 5-6%.
You could try cleaning your MAF sensor with CRC MAF Cleaner. It did improve my sensor reading (according to software) but I did not feel a difference. Ask for a piggyback controller for Xmas.
Old Dec 17, 2006 | 12:54 AM
Nietzsche's Avatar
I'm glad auto enginuity worked so well for you. I was debatting whether it would work as well as cipher for datalogging. How does the AFR work out? Did you have to convert it yourself or does the program do it for you? Also, how did you adjust the MAF with Auto Enginuity; or do you have a air/fuel controller?
Thanks for the help guys!
Old Dec 17, 2006 | 09:12 AM
madmik's Avatar
Yes I have to convert output voltages manually. In service manual EC, page 520, there is a voltage/AFR chart similar to a wideband sensor but not quite as linear. For the narrowband sensor voltage I found a chart on the net.
The way I changed the MAF air flow is by drilling holes in the back of the sensor, not in the 3 inch CAI pipe, but the sensor inside the pipe.
http://memimage.cardomain.net/member...2248073_25.jpg
The air enters the MAF sensor and makes a 'U' turn inside and then exits from the top and bottom of the sensor. I created a shortcut by enlarging one hole on the top of the sensor and created three 1/16 inch holes in the back. Took about 7 tries. If you don't have a tool to monitor the AFR, you can go too rich quickly. To remove the sensor you need the Torx bit with the hole in the center (Advance Auto $10.00 for a set). Pliers make a mess. I have also positioned the sensor at 1 o'clock in the pipe so it can be pulled out easily. I suspect that with patience one could use more or less holes to improve just the low or high-end range. I don't have an A/F controller yet.
I will take a better picture of the sensor with the holes in the back.
Old Dec 17, 2006 | 12:09 PM
alex19's Avatar
oh
oh ok i understand it now thanks
Old Dec 17, 2006 | 07:51 PM
madmik's Avatar
Better pic of holes in sensor.
http://memimage.cardomain.net/member...2248073_30.jpg
Old Dec 17, 2006 | 11:22 PM
Nietzsche's Avatar
Isn't that bad to do?
Old Dec 18, 2006 | 08:21 PM
madmik's Avatar
Bad in what sense? I have richer, safer AFR. I have not noticed any adverse effect yet: starts fine at 25F up to 65F. No stalling or unusual behavior. If I ever go back to stock, I will just plug the holes.
I like to experiment. Sometimes I break stuff. In this case it seems to have fixed my problem.
Get your car on a dyno. Its a quick way to find out if your AFR is correct.
Old Dec 18, 2006 | 09:43 PM
Nietzsche's Avatar
I just figured it wasn't wise to drill holes in such small, fragile, and expensive piece.
Old Dec 21, 2006 | 05:42 PM
NmexMAX's Avatar
dot dot dot ...
What are you using to gather A/F data?
Old Dec 21, 2006 | 11:01 PM
Nietzsche's Avatar
He's using Auto Enginuity
Old Dec 22, 2006 | 07:17 AM
NmexMAX's Avatar
dot dot dot ...
It still wont give you true a/f like a wideband o2 sensor would. Only o2 sensor data.
Old Dec 22, 2006 | 08:42 AM
madmik's Avatar
Correct. Like I mentioned earlier: I have to convert output voltages manually. In the service manual EC, page 520, there is a chart to convert voltage to A/F. I will dyno again in January. My a/f roughly follows my torque curve: about 12.1-12.2 @5500, and 13.1-13.5 for the rest of the range between 3500-6500. I will dyno again in January. I hope it shows similar numbers.
Happy holidays.
Old Dec 22, 2006 | 11:20 AM
Nietzsche's Avatar
What's the difference. If you have the raw voltage converting it is just an equation. If you buy a wideband o2 it does the same conversion does it not. The Maxima uses wideband o2's so how are they any different then a aftermarket system? I was planning on using AE or Cipher as my o2 datalogger instead of going through the hassle of installing another o2 sensor.
If I'm mistaken in any way please enlighten me.
Old Dec 23, 2006 | 12:56 AM
NmexMAX's Avatar
dot dot dot ...
Correct. Like I mentioned earlier: I have to convert output voltages manually. In the service manual EC, page 520, there is a chart to convert voltage to A/F. I will dyno again in January. My a/f roughly follows my torque chttp://forums.maxima.org/newreply.php?do=newreply&p=5427115urve: about 12.1-12.2 @5500, and 13.1-13.5 for the rest of the range between 3500-6500. I will dyno again in January. I hope it shows similar numbers.
Happy holidays.
This man (madmik) is always right/correct. And...again, Happy Holidays....
But keep in mind, the 05(madmik) and yours(06+), are different...(o2 sensors).
Old Dec 23, 2006 | 04:35 PM
Nietzsche's Avatar
I thought 05 & 06 where the same. Do you happen to know the difference? I only have the FSM for 05.
Thanks for letting me know though, things might have gotten ugly.
Old Dec 23, 2006 | 04:46 PM
NmexMAX's Avatar
dot dot dot ...
IIRC, the wb o2 came in the 06.
Old Dec 25, 2006 | 09:50 PM
Nietzsche's Avatar
Cipher says that 04.5+ uses WB sensors.
Old Dec 26, 2006 | 09:08 AM
NmexMAX's Avatar
dot dot dot ...
Ok........what years are those?
Old Dec 27, 2006 | 02:26 AM
bmorekaotic19's Avatar
Guys, can you FLASH your ECU to get some gains without any real mods other than exhaust & a K&N filter or is that just a waste of time? cause i saw in a thread here once the directions to flash the ecu using the pedal/flash method when i tried that it didnt work. do you need a flash system like the apexi one or something..the thread made it seem like any max owner could do the pedal method...also..the max's throttle response seemed crazy after i installed the k&N filter.....for like 2 days. =( (HELP) and sry for such a stupid question guys.
Old Dec 27, 2006 | 08:01 AM
NmexMAX's Avatar
dot dot dot ...
Read this, http://forums.maxima.org/showpost.ph...3&postcount=22
Old Dec 27, 2006 | 10:06 AM
Nietzsche's Avatar
I'm guessing 04 1/2 through 07, not quite sure though. I'm going in to talk with my parts and tech guy today. The part numbers are the same for 06 and 05 I think. I'll see if I can snag the chart out of the 06 FSM as well.
Old Dec 27, 2006 | 01:05 PM
logik05se's Avatar
i will tell you first hand that i had a ce-y pipe and then took it off a few months later. The reason i took it off because i added a full exhuast, once i added that the car felt like a complete pig. Didnt even burn tires off the light. All these exhuast mods cause the car to lose back pressure and in the end you lose your low end power. The y pipe did make my car feel slightly quicker on top end but not to much, but i definatly felt the lack of power on the bottom before and after teh exhuast.
I also never got a tune which definatly would have helped everything work well together.
Old Dec 27, 2006 | 02:21 PM
NmexMAX's Avatar
dot dot dot ...
Reason it sounded bad and didn't perform well was because of the non-equal nature of the aftermarket y-pipe.
My car never lost any 'low end' due to loss of backpressure.
