How to remove the glove box assembly?
Old Dec 17, 2006 | 03:52 PM
Monotaur's Avatar
Hello,
I was trying to install the Nissan iPod interface into my 2004 Maxima, but could not remove the glove box assembly. I was able to only remove 6 out of 7 screws holding the assembly in place Even after removing the glove box completey by removing the pegs (they were a pain to remove) and then detaching the glove box from the cord holding it in place, I still couldn't see the last screw to remove. I think it may be under the trim piece that is loweest to the ground on the passenger side against the center console, but I'm not sure how to remove that one either. Has anyone removed either of these two pieces before? Any advice on how to proceed?
Thanks!
Old Dec 17, 2006 | 06:01 PM
madmik's Avatar
1) Remove the left and right foot covers from passenger area
left (center console) cover has 2 pins/pegs on top portion
carefull they are snapped on some fragile plastic bracket
right cover- pull from back or rotate top portion left
2) remove 3 screws at bottom of dash: left, center and right.
If you don't remove the lower trims, you will not see two lower screws
3) Open glove box and remove left and right screws, and 2 screws for latch.
4) Pull top a tad hard to un-snap the pins.
5) Disconnect trunk switch wire, center glove box bulb and then lower bulb
The yellow connectors under the dash are for the air bags. Much safer to disconnect battery before doing any wiring.
Old Dec 17, 2006 | 06:54 PM
Monotaur's Avatar
Thanks. I'll have to take a look later in the week, but I think I'm confused about item #1. I couldn't figure out how to remove it earlier for the life of me...
Old Dec 17, 2006 | 07:05 PM
jorgep03's Avatar
hello there, please if you install this Nissan interface let us know if you are able to see the song info in the head unit screen, are you able to control the ipod via sterring wheel controls??? are you still able to use the 6 disk cd changer???
Sorry, lot of questions but as far as I know you are the first one to install this interface from Nissan.
Thanks in advance.
Old Dec 17, 2006 | 07:28 PM
Monotaur's Avatar
Thanks in advance.
You should be able to control the iPod via the steering wheel controls, but I'm not sure on the specifics. You should also be able to continue to use the 6 disc changer. I'm not sure about the song info, but imagine that it will.
BTW, the original thread where we discussed this is (although I just checked and I see that you have posted there as well...):
http://forums.maxima.org/showthread.php?t=484034
As soon as I get more time this week to remove the glove box assembly, I'll see how much further I can get.
Old Dec 24, 2006 | 05:07 PM
jorgep03's Avatar
hello there, just checking if you were able to install the interface, please let us know your experience.
Merry Xmas.
Old Dec 26, 2006 | 05:35 AM
Monotaur's Avatar
Merry Xmas.
Not yet... I've been tied up with other things. As soon as I get some time, I will install it and report back.
Old Jan 4, 2007 | 07:12 AM
95Max's Avatar
Monotaur,
Any update? Does it work with the 04?
Old Jan 4, 2007 | 08:42 PM
Monotaur's Avatar
Originally Posted by 95Max
Monotaur,
Nope, no update, sorry. But according to my dealer and the installation docs, yeah it should work with the 04. I've been meaning to get to the adapter, but I've had a lot of other things pop up that I wasn't expecting (some health, some other). I'll try to get to it soon.
Old Jan 5, 2007 | 08:47 PM
kikepeluca's Avatar
i-Pod interface install and working!
I was able to install the i-Pod interface on my Maxima 04. See my response under i-pod interface. You will be able to control the i-pod from the steering wheel and radio controls but the song information won't be display on the screen.
Old Jan 6, 2007 | 10:46 AM
jorgep03's Avatar
what interface did you use, can you give us the part number and did you install it dissasambling the glove box or through the dass board??
Old Jan 6, 2007 | 10:57 AM
Nietzsche's Avatar
He used an aftermarket piece from usaspec, I can post the part numbers for nissan adaptors later.
MaxiNoob98
Oct 2, 2015 10:13 PM
jaydot901
Sep 29, 2015 01:18 PM
atriuum
Sep 28, 2015 01:19 PM
Sep 27, 2015 08:37 AM
Noela
Sep 26, 2015 08:22 AM
