Problem: Coin Stuck in ACenter Console C Adapter
Old Dec 28, 2006 | 09:47 AM
wmanimal's Avatar
Greetings all. I have a nickel that is stuck in the AC adapter located in the center console of my 04 Maxima. Wondering if anyone knew of any possible solutions? Thanks!
Old Dec 28, 2006 | 10:00 AM
!PrjctMax!'s Avatar
You'd probaly have to take out the whole center console...I know that I have the same issue, but I just left it alone!
dan
Old Dec 28, 2006 | 10:50 AM
eLMo's Avatar
I'm guessin u can't pick up a nickle with a magnet? Don't flame me please lolol.
Old Dec 28, 2006 | 11:01 AM
2LEET4U's Avatar
dont think so man.............
check out the DIY threads, they talk about how to remove the center console. its pretty easy.
Old Dec 28, 2006 | 12:11 PM
xoomer.com's Avatar
I Donate! Why Don't You?
Take a stick or something like that with a flat end (girlfriend's mascara bottle come to mind) about 1/2" in diameter attach a piece of double sided tape to it, lightly tap on the nickel and then pull it up
You're done
Old Dec 28, 2006 | 09:58 PM
jsmithsole's Avatar
*moderator*
I'd just try to push in one side and most likely it will flip on it's side and you could pull it out...
Old Dec 29, 2006 | 02:47 PM
KCMAXX's Avatar
KC's FINEST
Car wash = Vacuum
Old Dec 29, 2006 | 05:56 PM
Nightline's Avatar
Good luck on that one, as the guys know here, I had that issue myself. Thankfully, I turned in my 04 today, and my new 07 doesn't have that issue. Do a search on my name and you can see all the other suggestions people gave me on that one.
I tried everything.
Old Dec 31, 2006 | 10:57 AM
madmik's Avatar
Put some epoxy/krazy glue at the end of a stick or something. Touch the nickel and let it dry.
Touch nickel with Mig welder rod to freeze it on, then pull. Now that may be fun to watch.
Old Jan 2, 2007 | 08:44 AM
Mikesima's Avatar
I used a toothpick once.
Did like someone above mentioned, pushed on thre one side, then kinda used another to get under that.
Old Jan 2, 2007 | 12:37 PM
PapaL's Avatar
When trying all these, be sure the socket isnt hot.
Old Jan 2, 2007 | 12:51 PM
maX5's Avatar
Double Sided Tape FTW!
Old Jan 2, 2007 | 03:37 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
OK, I'll ask, how did the nickel get in there in the first place????
Old Jan 2, 2007 | 09:51 PM
xoomer.com's Avatar
Man I don't see you responding to any of these ideas which leads to me conclude that you have not been able to get it out....wait, untill now.
I have one more idea that is guaranteed to work. Change either the consolse or better yet.......... BUY A NEW MAX
HEHHEHEHE
Old Jan 3, 2007 | 02:07 PM
wmanimal's Avatar
I have yet to have any luck but I appreciate all your ideas. Hopefully I can remove the nickel soon.
As for how it got in there....I am not sure....but I won't be keeping my spare change in the console anymore.
Old Jan 6, 2007 | 09:37 PM
tubells's Avatar
keep that nickel in there..... Good Luck
u sell that car .... u have "U" in it!!
Old Jan 8, 2007 | 11:27 AM
-AoW-JP's Avatar
Metal screw driver + JB weld @ the tip = lifted coin.
Old Jan 8, 2007 | 07:14 PM
Mr. Cummings's Avatar
you telling me there is an ac adapter in my car somewhere?
Maybe if you took a picture of exactly where the nickel is I could help you rig something up.
Where is the sticky for taking apart the center console? I want to gain access to that blank panel between the seat warmer switches.
tarun900
19
Dec 20, 2021 06:57 PM
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
