Location of Flasher Relay
Old Jan 13, 2007 | 05:22 PM
bry_gator1's Avatar
Can anybody help me out w/ the loaction of the flasher relay in the 04 Max. I poked around under the driver-side dash but could not find it . . .
Old Jan 13, 2007 | 06:29 PM
CanadianMoFo's Avatar
There are two fuse boxes under the hood.
Old Jan 13, 2007 | 08:12 PM
bry_gator1's Avatar
I know where one is (next to the air filter housing). Where is the other?
Old Jan 14, 2007 | 07:35 AM
bry_gator1's Avatar
I found another fuse box under the shroud on the passenger side, but the diagram on the cover does not say anything about the relays . . .
Old Jan 14, 2007 | 07:52 AM
The covers for the fuse boxes usually have a list of what does what where.
Actually I think there may not be a relay module. After reading the service manual I think its controlled by the BCM CPU.
Why exactly are you looking for it?
CM
Old Jan 14, 2007 | 10:18 AM
bry_gator1's Avatar
I get absolutely no flashing from any of the indicator lights when the indicator (or hazard) is activated. I got the following replacement relay from AutoZone (http://tinyurl.com/y4sy7b), their system said that any in the list would be a replacement, but they were no help with the location. I thought that the relay would be a good place to start to fix the problem, I had a Pathfinder a couple of years ago w/ the same symptoms and it turned out that the relay was faulty.
Old Jan 15, 2007 | 02:19 PM
madmik's Avatar
No flasher. Service manual LT-95. The BCM (Body Control Module) controls a lot of the electrical functions and it includes the hazard and flashers.
The flashers are working but not the lights in the 'unified meter'? If so, the Unified Meter Control Unit may be defective. LT-91 - "BCM sends signal to unified meter and A/C amp through CAN communication lines and turns on turn signal indicator lamp within combination meter."
May be a fuse. I think the owners manual list them.
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
zmcneely13
Sep 26, 2015 02:26 PM
