6 Speed Maximas
Gear.........RPM........MPH
1............6,600........38
2............6,600........61
3............6,600........85
4............6,600........112
5............6,300........140 (governed)
6............4,925........140 (governed)
1............7,100........41
2............7,100........66
3............7,100........92
4............7,100........121
5............7,100........150 (NOT governed)
6............?????........160 (I have heard this is upper limit)
And by the way, the sound of a VQ screaming at 7,100 is quite fabulous!!!
Originally Posted by DeusExMaxima
Since my ECU is reflashed, I have 7100 rpm redline, so mine is probably as follows:
Lucky Bastard!!
Originally Posted by Altima_boy
Hey Deus where can i get a Flash done? Im in Canada but i dont mind sending it out.
http://www.technosquareinc.com/
Originally Posted by NiZMo1o1
Originally Posted by STARR
I wish I got a 6 speed, I love my car but so many times I dream of shifting the gears, sometimes I wonder how complicated a manual swap would be
Probably more complicated than its worth, when all is said and done.
Originally Posted by sdotjoe
Can it take being revved at 7100, that just doesnt sound safe...And another question, Are there any real benefits from this???
There are a few VQ's on here that make good power beyond stock rev limit.
Also, there are articles out there stating what RPM's are optimal for maximum performance. Usually it's 300-500 RPM past peak HP, depending on gear ratios and power curve. http://www.bits.nl/re/shiftlight/sl-shiftpoint.htm
Theoretically, on unloaded tires, these are the speeds.
1............7100........43.3
2............7100........70.2
3............7100........98.0
4............7100........129.3
5............7100........168.6
6............7100........216.5
The power curve (and also the torque curve) for stock engines are based on tests of only a few stock engines by Nissan. In fact, each VQ engine performs slightly differently from these test engines (and other stock engines). So the peak power point on any given VQ will not necessarily match the test engine's peak point. If you are a consistent racer, you need to experiment to find your VQ's actual power peak point.
Originally Posted by SilverMax_04
The VQ's peak horsepower happens at an RPM before red-line. So going to read-line actually reduces vehicle performance versus shifting at peak HP.
Who said anything about Efficiency? I'm talking about dino-measuerd HP and Torque for specific engines -- test engines for Nissan versus your specific VQ engine
The code name for Maxima's V-6 engines
09maxshawn11
Aug 14, 2015 10:07 PM
