Cold air blowing...
Old Jan 30, 2007 | 02:33 PM
lilmyth's Avatar
Cold air blowing...
OK guys, I asked this before, (a while ago), but, I don't think I explained myself well so I wanna try again.
My Max is blowing cold air when I either stop at a stop light, or even if I attempt to start it, run in the house, and come back out.. It's COLD... this is with my temp set at 90 degrees. Now, it will get hot when I'm actually driving, but the second I slow down and stop.. COLD AIR... What the heck could this be? Thanks for your input.
Old Jan 30, 2007 | 02:57 PM
Lovemycar's Avatar
You have air in your cooling system there was a post on this ounce before
you will need to have it serviced at the dealer it's just draining and getting the aire out easy fix but they want 130.00 bucks WTF mine does it to but
i do get hot air when i stop my car just has to warm up a bit you must have
alot of air also check your overflow jug it may be empty mine was low after
filling it did get better
Old Jan 30, 2007 | 11:25 PM
watsupbabyboy's Avatar
I don't know if this relates to the post but I also am having problem with my air. When AC is on, only driver side works and passenger side is just blowing warm air. I've double checked the dual zone temp and both are running the same temp. It doesn't even help if I crank the A/C all the way up and lower the temp all the way down. Anyone know what the problem might be?
Old Jan 30, 2007 | 11:36 PM
tehaviator's Avatar
I see...
Is there any way you can convert that to english for the rest of us?
Old Jan 31, 2007 | 05:21 AM
bluemaxx's Avatar
Moderator GT-R
Heater Core gurgling Noise/TSB(NTB03-072)
For all those with gurgling heater core...
TSB Available - 2004 Maxima - Gurgling Noise From Heater Core
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
TKHanson
Nov 24, 2018 01:39 AM
Justin Kroll
Oct 1, 2015 07:03 PM
