resinator removal...
Old Feb 8, 2007 | 02:15 PM
marshallc's Avatar
has anyone tried this on their maxima? the big huge center resinator, leave the y pipe/mufflers/cats untouched just replace that with a smaller resinator, or straight pipe?
i think im going to try it, figured id post up here for opinions first.
Old Feb 8, 2007 | 02:41 PM
AuAltima3.5's Avatar
Just my opinion, but most cars I hear w/o the resonator sound obnoxious.
That said, it does give a raw sound, which sometimes sounds good.
Old Feb 8, 2007 | 02:43 PM
KCMAXX's Avatar
KC's FINEST
I went with an aftermarket Magnaflow when I put the mufflers on. DO NOT put straight pipe in it's place. Trust me, I tried. I can't find the words to tell you how loud and ghetto it sounds. You can however, replace the 2ft. piece of crimped crap they put in towards the rear. This is a 6th gen right??
I VIK I's Avatar
Ricey IMO, But your car try it out and post some clips lets see how it turns out
Old Feb 8, 2007 | 02:44 PM
KCMAXX's Avatar
KC's FINEST
If it's a 6th gen, DONT DO IT
Old Feb 8, 2007 | 03:40 PM
eK9aT10pSi's Avatar
kcmaxx, thats a good idea. rhmax i believe did that and had positive results
Old Feb 8, 2007 | 04:39 PM
I VIK I's Avatar
What type of positve results?
Old Feb 8, 2007 | 05:22 PM
RHMax's Avatar
Newbie just Registered
I dynoed my car with K&N panel and Magnaflow resonator with new piping to replace the crimp section, with stock mufflers, and gained 12WHP. The exhaust tone is a little deeper and -slightly- louder; similar tone to G35 but not nearly as loud.
Old Feb 8, 2007 | 05:41 PM
marshallc's Avatar
im looking for g35/350z stock exhuast + 1.
im talking the huge resinator after the Y before it splits to the rear mufflers.
assuming i get my car back tommorrow im going to try straight pipe instead of the resinator, figure i have 3 cats, and 2 mufflers it cant be that loud, and ill atleast know what it sounds like where as if i put a smaller resinator in id always wonder how it would be unresinated
Old Feb 8, 2007 | 06:22 PM
garose26's Avatar
The stock resonator is very important. I bought and installed the Cattman Exhaust with the resonator a couple of months ago and it sounds awesome under acceleration and I did pick up a good amount of power, but it drones terribly under load at part throttle. The Nissan guys knew what they were doing. I cannot get rid of the drone, no matter what I try.
Old Feb 8, 2007 | 06:36 PM
KCMAXX's Avatar
KC's FINEST
I love the way mine sounds.... Ecspecially now that I added a Fujita. If your curious try it. Just remember once they remove the stock resonator it cant be re-attached.
Old Feb 8, 2007 | 07:07 PM
xoomer.com's Avatar
I Donate! Why Don't You?
So many people with mods to their exhaust and nobody can provide a god damn clip? whats up guys?
Old Feb 8, 2007 | 07:12 PM
RHMax's Avatar
Droning is more muffler than resonator, it's the reason I kept stock mufflers. How big/long is Cattman resonator?
Old Feb 8, 2007 | 07:22 PM
RHMax's Avatar
Our muflers are pretty quiet, I believe there are valves inside that open up at higher RPM. If you want sound, replace the mufflers too. The best I can describe is like stock BMW loud now w/ CE y-pipe.
Yes, the big long thing under the middle of the car. I got new piping all the way to the rear split. The section to the mufflers are mandrel bent, so you can leave those alone. I went with stock size piping.
Old Feb 8, 2007 | 07:24 PM
RHMax's Avatar
I'll put one together if anyone will host it.
Old Feb 8, 2007 | 07:25 PM
xoomer.com's Avatar
I'll host it. email it to xoomer at xoomer.com
Old Feb 9, 2007 | 06:23 AM
xoomer.com's Avatar
If anybody got clips I will host them. I want to create a page with sound clips from different exhausts/different mufflers/different resonators etc. so that anybody could visit and download them before making a decision. There is a lot of posts with clips out there but the links expired, if I am allowed to host your clip, you will get credit and the files will always be available.
Old Feb 9, 2007 | 05:44 PM
KCMAXX's Avatar
KC's FINEST
I would think that you would donate and take advantage of the search function before running your mouth in every thread...
Old Feb 10, 2007 | 07:49 AM
xoomer.com's Avatar
Don't want to supply a clip? fine, but don't say somebody is running their mouth if they are not (read all the follow ups)
As to the search, JSmithsole did a search for us the other day and all the links were expired.
Old Feb 11, 2007 | 11:04 AM
xorbitman's Avatar
I removed my resonator and went with a custom pipe from the cat to the mufflers. The car is only a bit louder and performs better. Seems to breath better. I have an AEM CAI, UR-UDP and FSB. In the summer I occaisonally use 94 octane and I do the old accelerator pedal ECU reset....dramatic results and a nice loud growl when I floor it.
And the car is also lowered....and has upgraded brakes (Cross-drilled oversized rotors and Hawk HPS Pads)
Happy Motoring!
Old Feb 11, 2007 | 06:33 PM
Majestic_MAx05's Avatar
I took the resonator off when I installed my two maganflows and at first it sounded real nice. Deep growl!! Only problem was that I couldnt hear my self talk or any one else talk inside the car. Had it with out the resonator for about 2 months after that I had to go install a magnaflow resonator in cause I couldnt take it anymore.
Old Feb 11, 2007 | 07:25 PM
garose26's Avatar
Majestic,
Do you have any info on the magnaflow resonator? I need to do something with my Cattman Exhaust. It has a resonator but it is obviously not big enough.
Old Feb 12, 2007 | 01:31 PM
KCMAXX's Avatar
KC's FINEST
If it came with the Cattman, use it. It was engineered to be a complete system.
Old Feb 12, 2007 | 01:59 PM
marshallc's Avatar
well i lost the stock resinator today, straight pipe in place of it, bairly louder, like no difference at all between idle-4k rpm, a little deeper, no louder though.
4k-redline it seems to pull a little harder, like the car did after the stock airbox was modded, it also seems to sound more g/zish from 4k+ but idk if thats in my head, or it actually is.
Old Feb 12, 2007 | 05:24 PM
garose26's Avatar
I do not think much engineering was involved. The resonance is horrible. I am notthe only one with this problem.
Old Feb 14, 2007 | 10:33 AM
RHMax's Avatar
This is a clip of my exhaust sound. Stock mufflers with CE y-pipe, Magnaflow resonator, and repiping to the rear split. The burbling/popping sound is probably the result of one less cat. You can tell when I hit the 7100RPM rev-limiter, start, and stop; it like popping corns.
clip
kamski
Jul 14, 2006 04:43 PM
Street Reeper
Nov 23, 2002 02:23 PM
ptatohed
Jul 24, 2001 12:17 AM
