camber kit
camber kit
hey guys, for the ones running the progress springs, did you get the camber bolts? and when you got the alignment done after the springs were isntalled, was the camber in spec, or was the drop enough to throw it out of range? i am also ordering the gr-2s so if the oem shocks have any sag, this would fix it up.
You don't need camber bolts, the suspension can be aligned fine without it. Anytime you replace a suspension component you NEED to get an alignment. It always throws it out of wack to change springs/shocks.
i know about the alignment, lol. for the ones taht got the alignment, was was the degree it was off? i am looking to get eh ingalls camber bolts but there are 2 types depending on the camber. thanks
Don't know anything about the camber bolts, but I got the progress springs and KYB GR2 struts installed a couple of weeks ago. Everyone I got a quote from told me the aligment would have to be redone, which makes sense when you consider what they're doing to install everything. Bottom line is that this is an awesome mod that has made a huge difference to the handling of my ride, camber bolts or no.
When I had my slignment checked after install the springs, it was still dead on. Perhaps it got better than before
The camber was slightly off, negative camber. it probably improves the handling a little.
Negative camber helps handling to a point. When I had the springs installed, I think they said I had -1 degree camber which is nice for street driving, yet not too harsh on tires. When I roadraced my RX4, I had -3.5 degrees negative, but that was only for track.
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
