Phenolic Spacer Development for VQ35s
But other than that, your car should drive and idle perfectly normal. You'll just have more low end and midrange power along with a much cooler intake manifold resulting in less heat soak!
I have the spacers and I also used the coolant bypass connector. No cold weather issue to report down to 25F here in Virginia. No negative issue or adverse behaviour. It just pulls more. 10hp here, 10 hp there, and soon you are talking serious power.
Yeah.The purpose of the coolant bypass fitting is to prevent coolant from flowing through the Elbow. Having coolant flow through your intake manifold is just one more thing that will heat it up. If you live in an area that sees subzero temps and you drive your Maxima in those temps, I would advise against doing the throttle body coolant bypass.
lol
Yeah.
The theory is to prevent freezing and sticking of the throttle plate in extremely cold weather. You have to remember that Maximas are designed to run in all types of climates, including northern Canada.
The throttle body bypass has been tested in temps as cold as low single digits without any problems. But I recommend if you ever drive your car in temps that regularly get in the single digits while you are driving the car, then do not bypass the coolant.
Definitely not! You do not need coolant flowing through the manifold if you live in warmer climates.
I would recommend that you install the NWP bypass fitting yourself. You should easily be able to handle it. Try your best not to remove the elbow or TB. You will need to remove the MAF and intake tubing though. It will be a little cramped. But just remove the in and out coolant lines in the Elbow and connect them to the bypass fitting and secure the clamps.
This is shown in the installation instructions. If you lost them, you can download the pdf file on the website.
www.NWPEngineering.com
time to grave dig....
so no news must be good news right? will be installing these soon when spark plugs get replaced.
any stock intakes with the whistle?
any issues with the elbow coolant bypass? i guess i could bypass it when i put my summer wheels on and replace it when stockies go on for the winter...
I woudl not do the coolant TB bypass if you have 32F or less for longish periods like here in Iowa. You will have issues with ice in the TB if so. We regularly have -15F air -35F wind chill let alone moving at 60mph into a wind...... So the spacers = awesome, TB bypass if it stays above freezing where you live for most the time.
No issue other than the whistle. I suspect is need to readjust the 4x4 TB spacer. Its the only spacer that had some play. Because I enlarged the lower intake ports, I had to match the port spacers so I doubt those are the source of the whistle. I actually like the turboish sound.
I did coolant bypass. I live in VA. If car is parked outside in winter, and temp is less than 20 F, I must let it warm up a bit first, or I get a code about engine taking too long to warm up. I must say that I run a 165F thermostat and EGR is 50% blocked. I pass emission tests without problem.
Please do not hesitate to contact me if you ever notice anything other than perfection from NWP. I'm serious.
on the bypass valve and it's purpose. Aaron, remember how I kept PMing you on the point of it because my tech didn't install it? lol
