STS available for 04+ maxima
There is now a short shifter available for the 05-06 6spd maxima with 55mm shifter.It also fits the 05-06 Altima SER 6spd. Made by axxtion and i have one. Love it!
http://cgi.ebay.com/ebaymotors/ws/eB...m=190092927173
The 2004 Maxima has the 67mm shifter while the 2005-2006 Maxima has the 55mm shifter. Previously, the 2005-2006 Maxima did not have an STS available. Its about tim someone made one for the 2005+. A guy named Companyman on here was going to make an STS, and he used my car to check out the dimensions and so forth but I never heard back from him.
Originally Posted by 05AltimaSER
There is now a short shifter available for the 04+ 6spd maxima with 55mm shifter.It also fits the 05-06 Altima SER 6spd. Made by axxtion and i have one. Love it!
Yeah but does this one keep the shifter in its centre position? Or does the shifter get a slant towards the driver?
Kamski
what does the 04 have???67mm or 55mm? He has either one. email him at
axxtion@hotmail.com
axxtion@hotmail.com
keeps it just about at the factory location...you wouldnt beable to tell when you have it installed..unless you measure it.
Nismos14 has the shifter also...
Thanks Bro,
Kam
just comes with the pieces for under the hood. you dont touch the in cabin part.one piece does the shortness and the other peice moves the cable mount so that there is no angle on the cable and the shifter in cabin is at the right place.
I know your part of the nissanclub.com...go over there and under SER there is a thread about it.
http://www.nissanclub.com/forums/200...available.html
You can make your own STS for <$5 in parts. Just search for it.
edit:
I just took a pic of mine.
You only need a M8x1.25 tap and a M8x1.25-20 bolt.
Drill and tap about 10-15mm into the metal so the bolt bottoms out.
http://www.vq35de.com/Images/5dollarSTS/IMG_0106.jpg
$5STS
edit:
$5STS
Originally Posted by eK9aT10pSi
would you have a pic w/o the linkage installed? and yours looks like teh 05+. i dont think this will work with the 04
None of that crap matters. Spend the $5 to have a STS or spend $120 for the same effect. Your choice.
I will try to get you more pictures tomorrow after work.
Originally Posted by SR20DEN
Um no. My car is 2k2 and I am using a 2k4 gearbox.
Cause u freakin are man.
Kamski
my bad, i just remembered looking at other pics that the 04 has the grey bracket[67mm] while the 05+ has the gold bracket [55mm].
i was just asking for a better pic of how you drilled the hole, maybe a better angle pic?
thanks a lot!
thanks a lot!
edit:
$5STS
edit:
$5STS
and just look at how professional that looks!!!! ohh and the nice slop in the shifter bushing because its bigger then the bolt!!!!
hey to each their own!!
the color of your tranny shift bracket doesn't matter. you need to know if it's a 67mm or 55mm. drilling and tapping for a bolt will work on the 67mm. it will move the shift pattern forward into the dash because the cable end has to move forward to fit between the post and the tranny bracket that lifts the assembly up and down when you move the shifter lever left to right. a shoulder bolt would be a better choice.
you could also buy one of the cheap one piece STS's and do the same thing. by the time you buy a good cobalt split point drill and a good tap you will have spent about the same money.
none of this will work on the 55mm tranny shifter because there isn't enough room.
And there couldn't possibly be any reason why I specified a M8 bolt.
:attention
i didnt look at the year car you had..i figured it was a 04+. I appoligize for that.
I was not meaning to be degratful if thats how i came across...mainly i was trying to make a point that i would not want to drill a hole in my shifter arm and make it have a weak spot.
next time i will keep my comments to myslef
Hey I didn't twist anyones arm, nor tell anyone NOT to buy the STS. All I did was offer a much less expensive alternative. One which I have sucessfully used for over three years now. Of course it isn't for everyone. But many people will appreciate the info.
Kamski
Originally Posted by kamilkluczewski
So with the 5 dollar mod can u still move the shifter away from the dash afterwards?
Kamski
Kamski
Mine has worked perfectly for three years now. The shifter sits dead center in neutral like it's supposed to do.
Kamski
MaximaDrvr
Aug 19, 2015 08:20 PM
