Subframe connectors for the 6th Gen?
Old Apr 14, 2007 | 09:50 PM
TruaxMotorsport's Avatar
Just wondering if there is much interest in Subframes for the 6th Generation? I have read a few posts from 6th Gen guys but not nearly as many as the 4th and 5th Gen owners.
Apparently some believe they won't make much of a difference because the chassis was made stiffer. Any interest? Thoughts? I don't think it will be too hard to get a 6th Gen. in the shop to look her over, but if there is little interest we will work on our other projects.
If there is interest we will be looking for a car to try them on. We prefer ones who have already added strut braces, sway bars and shocks/springs.
Dan
Old Apr 14, 2007 | 09:57 PM
eK9aT10pSi's Avatar
i would be interested. would the ones you make have the "X" bar in the center or the 2 straight pieces that run pretty much parallel to the exhaust?
Old Apr 14, 2007 | 10:07 PM
LA02MAX's Avatar
Yes sir. Check this page for pictures of the 4th gen design:
http://forums.maxima.org/showthread.php?t=516058&page=3
I believe the 6th gen will benefit greatly from SFCs, as the two I've driven seemed to have had plenty of chassis flex like the 5th gens.
Old Apr 14, 2007 | 10:12 PM
SFCs
To be honest I have never been under a 6th Gen. Mike and Sean are the fabrication experts. For the 4th and 5th Gen Maxima, we used 1" x 2" front to back tubing that tucks in tight along the frame rail, and then used Mikes adjustable cross brace and used 1/2" square 11 guage steel to complete the cross bracing to really decrease twist and to add strength. I can tell you this. Adding the cross bracing makes a big difference on my 4th Gen Maxima. The way they designed it, there is very little loss in clearence.
There is no way I can say just how it would look, each car is different. Just trying to guage if there is enough interest to make it worth their time to line one up.
Old Apr 14, 2007 | 10:16 PM
!PrjctMax!'s Avatar
Depending on price and actual benefits of this...I would definitely be in!
Old Apr 14, 2007 | 10:23 PM
LA02MAX's Avatar
I think the design would be fairly similar to the 4th/5th gens. The 6th gen unibody is a bit different, but it looks as though clearance of the two main rails is similar to the previous generations...
Nietzsche's Avatar
The 6th gen has PLENTY of flex. I would definitely add this to my list if it made right. I would really want cross bracing though, that's where I see the most improvement.
Old Apr 14, 2007 | 10:26 PM
!PrjctMax!'s Avatar
except for the stupid part!
Old Apr 14, 2007 | 10:28 PM
LA02MAX, I think Mike would sh*t if he got to work on a car a clean as yours! Usually here in Minnesota they are rusty and dirty as heck. I think you are correct about using the same principle. I will sent a link of this thread to the boys and get their feedback.
Old Apr 14, 2007 | 10:30 PM
LA02MAX's Avatar
nope not my car. I believe that is DeusExMax's car. I own a 5th gen and will be buying these as soon as they're released
Old Apr 14, 2007 | 10:40 PM
SFCs
The 5th Gens are complete, we are just waiting until BlackMaxx96 gets them welded on his car and to hear his review. In fact they are very similar to the 4th Gen, just a tad longer and we had to change the cross brace a bit. Once he gives us the green light we will be adding them to the group buy.
Sure would be nice if the 6th Gen were not a big difference. It takes a lot of time to prototype a set, then make a good solid jig so we can reproduce them with no variation from set to set. Mike has tons of experience in this area.
Old Apr 14, 2007 | 10:42 PM
Nietzsche's Avatar
I could get you more extensive pics if you would like. Just let me know how many and where.
Old Apr 14, 2007 | 10:48 PM
kamski's Avatar
.org extraordinaire
Thats Chernmax's ride, and I'm in for a set if not too expensive.
Kamski
Old Apr 14, 2007 | 10:50 PM
Nietzsche's Avatar
If you guys can't find anyone local give me a shout. It's a six hour drive but maybe it's worth it.
Old Apr 14, 2007 | 10:54 PM
LA02MAX's Avatar
Kamski
You sure?
Here's where I found it:
http://forums.maxima.org/showpost.ph...9&postcount=11
The 4th gen SFC set is going for $300 which is a freakin steal for what this does to your car!
Old Apr 14, 2007 | 10:58 PM
kamski's Avatar
.org extraordinaire
You sure?
I stand corrected, and yes im in for $300.
Kamski
Old Apr 14, 2007 | 11:29 PM
MisterSparkle's Avatar
kam realize that it is a 4th gen going for $300...and seeing how pricing normally goes for the 6th gen about anything...you can see that price raise by about $100 so $400 for a x-brace...which in my mind it very handy and still worth it.
my friend has a honda del sol and we just recently had a engine swap to a b16a...DOHC VTEC (Si engine) now we noticed a big problem when we did the engine swap. his car flexs soo much (due to the added power) espeically the fact that Del Sols have t-tops (removable cabin top) so we put in a H-brace (i think) on it...now his body doesn't flex at all and control and responsivness on it is even better now.
however we've come to realize a problem with even that! now that his chassis is strengthed...most of his force is being placed on his wish bones. he just recently blew out or broke his passenger side bushing for the lower control arm.
my only concern with this idea is the fact that now we really would be placing a lot of pressure and force on our wheels and control arms and axels...can they handle it?
Old Apr 14, 2007 | 11:48 PM
LA02MAX's Avatar
Where would you get that idea from? The 6th gen bracing shouldn't be very much longer than the 5th gen's, which means there isn't much difference in material usage between the two...I would guess that they should be very similar in pricing, but we both don't know for sure about it until measurements are taken and fabrications are made
The SFCs will make the suspension do more work soaking up the bumps, but it isn't a big enough strain to warrant concern for pre-mature wear....
Old Apr 15, 2007 | 12:24 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Kamski
LOL, that's not my ride, mine is cleaner...
Old Apr 15, 2007 | 01:18 AM
DeusExMaxima's Avatar
OOOH thems are fightin words . . .lol. Im in for a brace too!!
Old Apr 15, 2007 | 01:25 AM
chernmax's Avatar
I like it a lot, but I'm curious as to how much weight it will add???
Old Apr 15, 2007 | 01:44 AM
4MySwee's Avatar
I have seen NCSU Max's car with this set up (Just yesterday in fact). It is clean and straight forward. The car handles remarakably well. It corners like it's on rails. Very impressive to see/experience.
Swee
Old Apr 15, 2007 | 07:08 AM
Ritz's Avatar
I'd be in for a set. It seems like clearance wouldn't be much of an issue either, 'cause the frame rails stick down about an inch.. I could try to get up with blackmaxx96 (Mike) and compare the SFC's for the 5th gen to my car, if that would help anything.
Old Apr 15, 2007 | 07:47 AM
maxhead's Avatar
I'd be interested.
Old Apr 15, 2007 | 08:03 AM
Good Morning Guys,
Wow, I am pleasently surprised that there are as many responses as there have been in just 12 hours or so. I have not talked to Mike and Sean regarding pricing but if they are quite similar to the 5th Gen car, we should not have a big jump in pricing, if any. If there are extra welds and cuts needed this adds to our build time, so we would need to adjust accordingly. We will have to look for a local car. Generally it takes the boys at least a whole shop day to cut, weld and fit a set of subframes. For the 4th Gen. it took even longer, as my Maxima has been in a wreck, so once we had what we thought was a good fit, tried it on another car and ended up tweaking her a bit. This is one reason we are not cutting the holes in the tabs, even though they shoulds be exactly the same, there is minor variation from car to car. I should also add, I will actually get a weight posted today. There is only about 2-3 inch difference in length in the 5th-4th Gen SFCs so the differnece in weight is going to be about 1 lb or so.
Old Apr 15, 2007 | 09:22 AM
LA02MAX's Avatar
The guess so far is 40-50 lbs. However, this 40-50 lbs. is added to the very bottom of the car, which helps lower the center of gravity...If you're really that worried about adding the weight, I highly suggest finding a way to lighten your load a little to offset the weight of these, because they are a very worthwhile mod. Your car will ride smoother, wont rattle anymore, and handling will be dramatically improved
Old Apr 15, 2007 | 12:35 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
I'm cool with this, count me in.
Old Apr 15, 2007 | 12:39 PM
Nietzsche's Avatar
Good Morning Guys,
If you can't get someone in Minneapolis let me know.
Old Apr 15, 2007 | 01:14 PM
Im not thrilled with adding 40-50 lbs unless there is a substantial change in handling. Its almost like it offsets each other - weight vs. handling
Old Apr 15, 2007 | 03:26 PM
Nietzsche's Avatar
I agree but the Maxima has significant twist across the frame. Forty pounds to take out that twist isn't bad. Add the fact it's as low on the car as possible. Sure it adds weight, but with the pounds lost on your rims and aluminium calipers you should even out.
Old Apr 15, 2007 | 03:36 PM
i'm def down...i would think that the weight addition would affect a little since our cars are alraedy very heavy...but like lamax siad its worth the the weight for improved handling. if the x-brace is anything like a H brace which i would assume does the exact same...its well worth it.
Old Apr 15, 2007 | 03:44 PM
chernmax's Avatar
Good Morning Guys,
LOL, I may have to offset the weight by going on a diet!!! What effect may this also have on the 6th Gen since we have independent rear suspension and the 4th/5th gens don't. I'm all about performance and I really like the idea so I'm just trying to make an informed decision.
If you cannot find a local car, recommend checking with car rental companies and renting a Max for a day and take the whole day measuring, what's a daily rental $40 bucks, seems like a great return with the current interest. JMHO
Good luck and again, if it works out, I'M IN!!!
Old Apr 15, 2007 | 06:42 PM
Nietzsche's Avatar
Give it to me now, don't care how I want it now!
Sorry, I've been watching ***** Wonka
Old Apr 15, 2007 | 08:26 PM
LA02MAX's Avatar
Oh trust me...it will be worth it. You won't even notice the weight because you'l be too impressed when admiring what they do to the overall feel of the car
Anyways, we drive pretty hefty cars...40-50 lbs. is not going to make much difference. Example: when I added my 6th gen front brakes, there was a difference of about 15 lbs. and an inch in diameter of rotational mass on my front wheels. Did I notice a difference? Nope I still ran a 14.3@98 and gas mileage is still the same. Weight added at the bottom of the car will actually have benefit the handling characteristics of your car and like I said before, there's always thigngs you can do to lose weight
Old Apr 16, 2007 | 07:43 AM
NismoMax80's Avatar
SuPeRmOd
I've been waiting for this
Old Apr 16, 2007 | 01:26 PM
PakiPlaya07's Avatar
Will you consider making some for the 3rd gen Altimas?
Old Apr 16, 2007 | 02:24 PM
Well, I think, more accurately, the detriment to the added weight is minimized, by placing it low on the chassis. In other words, adding weight itself does not benefit the car, but placing it low minimizes the detriment with respect to handling and possibly braking. And its a good reason to drop a few pounds with a diet, eh?
Old Apr 16, 2007 | 04:01 PM
LA02MAX's Avatar
That's why I said handling 'characteristics'...Added weight, in general, is detrimental to the way a car handles. However, we have pretty nose-heavy cars and adding a little weight further back as well as that far down will give your car a little better balance (although VERY slight, as I mentioned before - almost un-noticable). But yes, I see this as a very good reason to go on a diet...The function outweights the drawbacks IMO. However it's your car and it's not an easily reversible mod so do what you want.
Old Apr 16, 2007 | 08:24 PM
Nietzsche's Avatar
3rd gen Altima and 6th gen Maxima are built on the same chassis.
Old Apr 16, 2007 | 08:39 PM
^Thanks for the info.
