Strange noise
Old Apr 17, 2007 | 08:50 AM
hfj17002's Avatar
Strange noise
What's up guys? I bought a used 05 maxima 2 months ago. My problem is that I'm hearing a strange noise coming from my car when I accelerate, mainly when my rpms get around 3k. But, It's just when I give it gas and moving, not in park. It sounds like if I was dragging a metal object that is just barely making contact with the road. I took it to the Dealer and they flushed the injectors and throttle chamber including intake plenum, and added a fuel additive to fuel tank. The sound is still there. I don't think it has anything to do with the engine since it dosen't make the noise in park when I give it gas. Has anyone else experienced this?
Also my brake pedal makes an annoying clicking noise evertime I press it. The service guy said it was normal. I don't think a $30K vehicle break pedal should make noise. Any ideas would be appreciated! Other than these things, I love the car!
Old Apr 17, 2007 | 09:16 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
check the exhaust brakets by the y-pipe. they break and cause that noice.
Old Apr 17, 2007 | 10:03 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Originally Posted by Tek-Niq
check the exhaust brackets by the y-pipe. they break and cause that noise.
Word, that's my guess, the Stealerships obviously don't read the TSB's...
Old Apr 17, 2007 | 10:52 AM
MTray's Avatar
I have heard a noise simliar to that as well (between 2500-3000rpm). I bought my Max back in February, and noticied it a few weeks ago. I had heat shield rattle in my last car (QX4), and it reminds me of that. I'll be due for an oil change next week, so we will see what turns up.
On a side note, I installed my 07 spoiler last month and got the windows tinted today... let the mods begin!
Old Apr 30, 2007 | 08:45 AM
hfj17002's Avatar
Man, I appreciate the input you guys gave me! I took it to the dealership on 4/19 and told them about the bracket and that there was a TSB for it. Sure enough, I get a call that it was the bracket. It's sad that I have to tell the service advisor what the problem is. I'm just glad you guys are here to help me out. Thanks again!
Old Apr 30, 2007 | 11:32 AM
MTray's Avatar
Yeah, I took mine to the dealership last Friday and they said it was a loose heat shield. When I picked it up, the oil maintenance display said it had 7 miles on it already. Im not sure if thats normal driving distance to check a rattle, but I guess theres nothing I can do about it. Regardless, when I picked it up, the rattle was still there. So, I am taking it back this week and someone has to ride with me to hear it. I will tell them to check the bracket this time!
Old May 1, 2007 | 06:34 PM
Longhorn101's Avatar
Glad they found the problem (with some help). I'm guessing you took it in to Round Rock Nissan.?.? I've been fairly pleased with those guys up there, although I haven't had to use them a whole lot (thankfully). I had a similar noise at ~2k RPM but my brackets look good. I think I got it to go away by wedging something between the heat shields that wrap the pipe near the "Y". I hope it stays gone.
Old May 3, 2007 | 12:07 PM
cpar's Avatar
I have a 06' SE and have a random pop/cracking noise coming from the back windshield. It doesn't necessarily pop when you hit a bump in the road, it randomly pops and cracks without notice??? I took it back to dealer and first they wanted to replace whole back window but then decided to replace the seal. After they took it to a glass specialist, they determined the seal needed lubrication. It seemed to help for a while, but still pops without reason.
Old May 5, 2007 | 06:00 AM
sosbuddha's Avatar
low noise(like stretching) from the steering wheel when i turn..
hello people, im new to this forum. I have a 06 maxima SL. i bought it new in sep last year. I started a low stretching kind of a noise comming from my steering wheel, each time i make a revolution of the wheel...has anyone here have similar issues? Is this normal for the maximas..wd appreciate any replies..
cheers.
Old May 5, 2007 | 07:21 AM
Monotaur's Avatar
cheers.
I've noticed recently that when I first start the car in the morning that I sometimes get this sound when I make the first turn of the day, but only for about 10-20 degrees of a turn of the wheel. I had this happen on my old '94 Plymouth Sundance on cold mornings, but it would happen henever it was cold and happen for a much wider wheel turn. It kind of sounds like a low humming sound, and might be described as a stretching noise.
This is in an early build 2004 (was made in September of '03, when I bought it). I haven't heard of this from anyone else.
Old May 5, 2007 | 07:22 AM
Monotaur's Avatar
I too usually hear a clicking noise when I start the engine the brake pedal. It's not always there, but it is a lot of the time... I don't think any thing is wrong, just kind of odd. Maybe someone else can chime in here?
Old May 5, 2007 | 06:40 PM
crazyjeff100's Avatar
If I'm thinking what you have is what I had on my '04 Maxima, the dealer fixed it for me, but it returned a year or two later. Apparently, like a poster said here, it was something to do with brackets on the exhaust.
It was a rattling of sorts, right? You heard it mainly from dead stops up to about 20, 25 mph right?
Old May 5, 2007 | 11:06 PM
catalinoiu's Avatar
I had the same thing (buzzing at 3000RPM). Went to the dealership, fixed the bracket (under 100k warranty) and is all gone.
BTW, I "upgraded my maxima from 99 SE to 04 SL. It' so nice....
Old May 6, 2007 | 03:39 PM
sosbuddha's Avatar
well wazzup people..i posted yesteray regarding a rubing(low)/stretching noise comming from my new 06 maxima sl...well today, i heard some strange flowing water noise near the passenger side..i remember looking a message on this issue earlier, but unable to locate it now...can anyone chip in please??
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
