Z/G cams in our cars
Originally Posted by nismology
There's no evidence that suggests that the revup rods are stronger. The ROD BOLTS are stronger (probably the nismo units), and since the connecting rod part number includes the rod bolts, voila!...new part number.
LH Exhaust Camshaft
LH Intake Camshaft
RH Exhaust Camshaft
RH Intake Camshaft
Connecting Rod
Connecting Rod Bolt
Crankshaft: Uses the same connecting rod bearings and main bearings / thrust washers as other crank.
Crankshaft Assembly
Cylinder Head Assembly - LH
Cylinder Head Assembly - RH
Pistons - STD 1, 2, 3, & OS0.20
Pistion Ring Set STD
Piston Ring Set OS 0.20
Valve Spring
Track Valve Spring Retainer
VTC Pulley & Cover Kit LH (does not include gasket or bolts)
VTC Pulley & Cover Kit RH (does not include gasket or bolts)
VTC Cover Gasket LH
VTC Cover Gasket RH
VTC Cover Bolt
The standard VQ35 rods can handle 7500 RPM with no problems. This has been proven.
I'm willing to bet this was put in place to reduce NVH and for future boosted applications, not for a 7500 RPM redline.
http://www.nissanperformancemag.com/september06/vq35hr/
Originally Posted by cjbaldw
The stock rods in the VQ35DE are widely known to have problems under higher RPM loads
and boost applications.
If it is "un-safe" to go past 7000rpm, then why did technosquare make the redline on all of their tuned ECU's to 7100rpm...
I highly doubt that they just programmed some stuff and said, "here you go, now go and see what happens!"
Parts changed in the rev-up VQ35DE:
LH Exhaust Camshaft - Duh...irrelevant
LH Intake Camshaft - ditto
RH Exhaust Camshaft - ditto
RH Intake Camshaft - ditto
Connecting Rod - Says who?
Connecting Rod Bolt - agreed
Crankshaft: Uses the same connecting rod bearings and main bearings / thrust washers as other crank. - Irrelevant
Crankshaft Assembly - Incorrect...there is only one part number associated with all non-HR 350Z motors. Besides, the standard crank is good to damn near 10000 RPM (yes 10K).
Cylinder Head Assembly - LH - Everything's the same except for slightly stiffer valve springs...hence the different part #
Cylinder Head Assembly - RH - ditto
Pistons - STD 1, 2, 3, & OS0.20 - Part number could be different due to another piston pin or pin lock manufacturer. No evidence that suggests they are any stronger. Besides, how much stronger could they be? They were still hypereutectic cast aluminum with the same basic design. I've seen pix of them and they look the same.
Pistion Ring Set STD - They were different indeed, but they're crap. Most rev up's burn oil at an alarming rate.
Piston Ring Set OS 0.20 - Ditto
Valve Spring - Duh...see above
Track Valve Spring Retainer - Yes these were different as well
VTC Pulley & Cover Kit LH (does not include gasket or bolts) - Irrelevant
VTC Pulley & Cover Kit RH (does not include gasket or bolts) - ditto
VTC Cover Gasket LH - ditto
VTC Cover Gasket RH - ditto
VTC Cover Bolt - ditto
Not according to the tuner I've worked with and many a 350Z owner over on my350z.com. The stock rods in the VQ35DE are widely known to have problems under higher RPM loads and boost applications.
It was put in place for a number of reasons in the VQ35HR and the VQ37VHR engines, only one of which was to support higher RPM performance. The VQ37VHR is most likely the engine that will be boosted in the GT-R.
It helps lower NVH as well. As for the high RPM thing, that's strictly an opinion. I am confident that there have been motors that rev to 7500 and beyond without the "deep skirt" design that the HR's block has.
Read the Engine section in this article for much more specific information and actual pics of the newer engine internals in the HR model engines:
Originally Posted by NmexMAX
We've got a few members that rev quite freely to that RPM often enough to merit nismology's statement. They do have upgraded rod BOLTS, but are using the same stock rods.
This changes things significantly. But it has been stated time and time again that tuning in boosted Z33 applications plays a large role in engine life. And many of the 'pros' self destruct their engines due to poor tuning/lack of knowledge. If tuned correctly, very good power can be made safely under boost in a VQ35DE.
To reduce emissions the VQ has its compression rings near the top of the piston. This reduces crevice volume and the potential for hydrocarbons hiding in this area to contaminate the exhaust. The downside is that this weakens the piston and detonation can thus easily break the piston in the ring land area. Many a forced induction VQ in a Z has succumbed to this fate.
Most of the issues underlying the VQ35DE engine have been resolved in the newer VQ35HR redesign. I've not yet read a detailed technical breakdown of the VQ37VHR engine so I'm not sure what if any additional improvements Nissan has made with the newest engine that's shipping with the new G37 coupe. Can't wait to find out though!
I have had the 7500rpm limiter for about two and a half years now, and although I still have no logical reason to rev that high I have done it hundreds of times. Mostly on the dyno. I don't recommend that for anyone because it now appears to me that the valves are starting to float past 7400 with the stock cams and springs.
You 6th gen owners really need to spend more time in the All Motor forum when you want to get serious about complex engine mods and higher than average naturally aspirated power levels. Your engine is nothing new and is pretty much the exact same VQ35 that you'll find in any 2002 Maxima or 2003 350Z, minus a few part number changes and external packaging.
So YES the aftermarket VQ35 cams will work and YES you can use the Ebay knockoff cams. You can buy JWT replicas and Nismo replicas. Both are a fraction of the price and just as good. And if you seriously want to do a cam swap I would also highly recommend that you use the VQ35HR valvesprings and retainers. This is another thing that has been extensively covered in the all motor forum which you can all readup on.
http://forums.maxima.org/showthread.php?t=519636
http://forums.maxima.org/showthread.php?t=497655
Hopefully they will listen.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
