Ksport coilover issue
Old May 25, 2007 | 11:13 AM
6thGenMax's Avatar
how are we securing out brake line and abs lines on the front when installing the ksports. also has anyone had a problem with the lower shock bolt in the rear being stuck?
going in for a alignment wednesday. how should these pillowball mounts be adjusted?
thanks
3rd
Old May 25, 2007 | 07:43 PM
Outlawd's Avatar
thanks
3rd
If I remember off the top of my head, the front coilover set should have came with these black bracket things that have a rubber insert where the line can be pushed into and held in the insert part. You might want to move/reroute the lines out of harms way from any moving parts.
The rear lower shock bolt isnt stuck. It's actually welded to the shock. Thats the way nissan designed the setup. You will have to get new bolts. No biggy.
Oh, and if you have the elite package....you won't have access to the rear adjustable dampener **** once its mounted. It's like trapped inside a metal "igloo". You'll have to take the rear coilover strut off to adjust the rear dampening on elite maxima's.
Old May 28, 2007 | 12:25 AM
joebangaa's Avatar
Adjusting dampening has nothing to do w/ an alignment...
Anybody qualified to do an alignment will know what to do w/ the top mounts. Just remind them to adjust it "under the hood"
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
BkGreen97
Apr 2, 2016 05:47 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
A32goldylocks
Sep 14, 2015 06:49 PM
