Knocking in the Rear
Old Jun 4, 2007 | 05:35 PM
OmarBadu's Avatar
necessary info
2005 SL
37,500 miles
cattman/progress rear sway bar
racingline endlinks
I have started to hear a knocking noise in the rear that sounds suspiciously like the suspension to me - it seems to happen when the car bounces because of a bump - seems like I don't hear it when i'm turning but not 100% on that
any suggestions??
I'm leaving town tomorrow for a bit and might not have i-net access so please be patient if my response is needed
Old Jun 4, 2007 | 09:54 PM
eK9aT10pSi's Avatar
i have the same sound [or same type of] when turning right. have you completed the rear subframe recall?
Old Jun 4, 2007 | 11:44 PM
Albert's Avatar
Check your bushings on the endlinks.
I had the knocking too and it turned out that the bushings
were ruptured. The sway bar was rubbing against the
endlink.
Apply this fix complements of coitaltie.
http://forums.maxima.org/showthread....hlight=endlink
For me, I knew it was the bushings because I can feel the
handling degraded over time.
Old Jun 5, 2007 | 08:15 AM
VigilanteMax's Avatar
What Albert said. Also may help to spray just a small amount of silicone on the endlinks itself for a little lubrication. It is golden as can be now.
Old Jun 6, 2007 | 07:42 PM
madmik's Avatar
Check the two bushings holding the sway bar. The rubber could be split or the bracket loose.
matts95max
Apr 23, 2025 10:44 AM
