Racingline endlinks...
Old Jun 8, 2007 | 07:12 PM
!PrjctMax!'s Avatar
...is it possible that theses could be "blown?" They were causing massive squeaking from the rear of the car and when I took them off, it stopped. I lubed them up (bushings and bearings) and the sound went away, but I still hear it randomly through turns or bumps...
Old Jun 8, 2007 | 08:32 PM
kamski's Avatar
.org extraordinaire
No bro, its the sway bar bushing, because you are using the sway bar so much more you wear out the lube on the inside of it. I would use some of FORDS sway bar lube, its like $27 a bottle but it lasts through 5 Chicago winters.
Kamski
Old Jun 9, 2007 | 12:35 PM
!PrjctMax!'s Avatar
That's funny because I re-lubed the sway bar bushings as well...
Old Jun 9, 2007 | 01:27 PM
Nietzsche's Avatar
Are you sure it's not the spring seats? That is very common on these cars especially when lowered. I just threw on some isolaters to see if that helps but alas it didn't. Happens on my wife's stock Altima as well.
Just a thought.
Old Jun 10, 2007 | 12:54 AM
!PrjctMax!'s Avatar
spring seats?
Alls I know is that when I put them back in the squeaking most definitely came back! I think I might just get the OEM endlinks since these will rust to **** and the bushings are probably what is causing the squeaking.
Old Jun 10, 2007 | 07:42 AM
mightymax5's Avatar
I just purchased a progress rsb ,racline endlinks , and energy suspension endlink bushing kit p/n 98105 / universal sway bar greaseable kit 24mm p/n 95160. Just go to their website energysuspensions.com click searchenter the p/n and your be able to see a pic. I have teh 24mm bar they have universal applications for all diameter size bars. Thye also sell the lube reasonably priced.
Old Jun 10, 2007 | 09:34 AM
!PrjctMax!'s Avatar
What's the difference between the sway bar bushings?
Old Jun 10, 2007 | 12:07 PM
eK9aT10pSi's Avatar
apparently the ES bushings are thicker and hold up more than the racineline ones. there was a thread on the org about a member upgrading these to the ES with positive results
Old Jun 10, 2007 | 01:13 PM
!PrjctMax!'s Avatar
Ya well today I went under the car again and took my endlinks off and wiggled the sway bar itself and it's the sway bar bushings that are making the noise! Has anyone upgraded the bushings in the sway bar?
Old Jun 10, 2007 | 02:05 PM
VigilanteMax's Avatar
Spray some heavy duty silicone on the bushings and bar. The bushings are fine, just need to be greased
Old Jun 10, 2007 | 02:08 PM
!PrjctMax!'s Avatar
I have 3M silicone paste that I put on both the endlink bushings and the sway bar bushings...and I had to re-lube the sway bar bushings quite frequently, I think I may go with the energy bushings soon and see how they work
Old Jun 10, 2007 | 03:30 PM
kamski's Avatar
.org extraordinaire
OOOO, wonder if they make the correct size for the cattman bar? That would be pimpin. I want to upgrade mine also. They are fine thus far, but when I start pushing my car around a littel harder at one of the local track events I think they will give.
Kamski
Old Jun 10, 2007 | 04:25 PM
!PrjctMax!'s Avatar
So what is the main purpose of the energy bushings, just stiffer and hold more stress?
mightymax5 said that he bought bushings for the sway-bar, so I would assume that they do have them. I was looking at their website and they have many universal bushings that have 2 different types of clamps that they will fit in and they have greaseable and non-greaseable ones! (what's the difference between greaseable and non-greaseable...benefits?)
Old Jun 10, 2007 | 06:29 PM
One is meant to be greased, like ours and yes they do make a universal 24 mm for the chasis bushing. i initially looked into the ES for stiffer bushnigs. Get the 9.8106 and you will see. use the washers from the 9.8105. i have a link for the before and after pics on here to started by kamski.
Old Jun 10, 2007 | 07:38 PM
!PrjctMax!'s Avatar
Just want to make sure...the PROGRESS rsb is 24mm or 25mm? And why would I want to mix and match the front bushings with the rear washers? I was just planning on getting the rear bushings/washers for the rears and keeping them in the REAR.
If someone could just clarify the size of the progress bar, then that would be great, and those endlink bushings will work fine on the Racingline endlinks, correct?
Old Jun 11, 2007 | 06:39 AM
The bushings on the 9.8105 are an 1/8" larger than the 9.8106. You will have to increase the size of your bolt. you will need the washers because you wont find one at a hardware store strong enough. im sure you will be fine on the 9.8105 though, just havent tested that one. Check progresses site and they will confirm the 24" bar.
MaximaDrvr
Aug 19, 2015 08:20 PM
TAZ
Dec 27, 2007 05:22 PM
Nietzsche
Jul 12, 2006 08:14 AM
