RaicingLine Endlinks Problem
Well, is been about a year or so since I had the car lowered (Progress) and struts/shocks changed (KYB). At that time I also had the sway bar (progress) and endlinks (racingline) replaced. I have been experiencing a problem where there was a thump (loud knock) coming from the rear suspension. I've researched around, taking to peeps at local meet, brian at catman and numerous trips to my mechanic to find out what the heck is going on. It was embarrasing driving the car and I even considered going back to stock but didn't want to loose the handling characteristics of a lowered ride.
I've heard things like broken shocks, loose shock mounts, improperly installed shocks, sway bar installed in reverse, grease the busings, tighten the rubber on the endlinks...etc, etc.
My ordeal came to an end last Saturday as my guy told me to bring back stock endlinks and RaicingLine ones were taken off. Man this think was driving me crazy and even my guy told me how the hell you drive this thing. Its quite like a new car again.
Here is the weird thing that ads to the mystery of the whole situation. My brother had the same setup installed 2 weeks later and he had no problems. Had any one experience this or is currently pulling hair trying to figure this knocking sound out. What gives?
there have been numerous thread on this recently....it is becoming common for the bushings to blow
people have been replacing them with Energy Suspension but there aren't any long term results just yet
try the racingline endlinks thread - that is on the first page....
get these paired with 3'' long bolts
http://www.energysuspensionparts.com...sp?prod=9.8105
I am going to VERY soon
For me it was the torned bushings that was causing the top of the endlink to rub against the frame or sway bar. After I have changed the bushings to ES, the problem went away. I drive 100 miles a week so I will know first thing if the ES bushings will hold up in the long run.
The only reaar problem with the racingline bushings was that for a while I switched suppliers and thier quality of polyurethane turned out to be poor. It had nothing to do with design, as there are altima running around with 3 year old bushings and not a single problem. The new V.2.0 endlink which will released in about 3-4 weeks time and will have a small steel insert inside the bushing to give a better mating surface when installed and to prevent any chance of over tightening or loose bushings knocking. The new bushing sets will be compatable with the old endlink design for those wanting to switch. Also I have 1 more sample to test out for the front endlinks and then they will be ready in about 5-6 weeks.
Originally Posted by eK9aT10pSi
xoomer.com, you beat me to it. or what would the cost be [pro-rated]?
also, updates on the FTSB?
and the front end links?
Originally Posted by Fastmax05
i have H&R springs and i have a loud knock in the drivers front whenever i go over a decent SPEED BUMP... its just a loud thud... hmmm ???
Originally Posted by coolmax05
Next time you're in town bud I'll take care of it for you (free).
I was hoping that installing new suspension would remedy the problem, but it's even more noticeable now. I did bang on some of the trim along the seat/pillar inside the car awhile ago and it helped quite a bit, but this time it doesn't appear to have helped.
in another thread, there is a discussion about the endlink bushings being shtity.
Originally Posted by Oolatec
Oops... meant rear Driver's side.
My bad. /Optimus Prime voice
I'm going to go out for a spin a bit later to see if I can isolate this noise.
lol optimus prime voice...i saw the movie as well.
coolmax05 how much would you charge to help someone lower there car if they came to you?
Originally Posted by xoomer.com
so taz will you supply replacement bushings to those whose set has failed?
Yes I will replace any torn bushings free of charge. New style bushing sets are still about 3 weeks out though. As stated before, I had a lot of bushings made up from a different supplier and it became impossible to tell them apart. As it turned out though thier product was an inferior one to my old supplier. So I have swithed back. The style bushing will have zero issues.
If anyone is interested, i wrote a write up about how to upgrade the bolts and bushings to the 9.8106 with 9.8105 washers. Moderators are welcome to make a sticky and use the pics I have uploaded on cardomain.com, username VigilanteATL.
Thank you.
post link....
before:
http://memimage.cardomain.net/member...2595231_15.jpg
after:
http://memimage.cardomain.net/member...2595231_16.jpg
http://memimage.cardomain.net/member...2595231_17.jpg
The write up is done on another thread about the endlinks. If I need to re do it, please let me know.
after:
Yeah... but I just installed brand new endlinks, and had the noise with the OEM ones as well.
Originally Posted by chernmax
Yo prjct, what type of 3" long bolts did you use and are they nessassary to fit these??? I already ordered the Grommets and Washers, thanks for the 411...
Oh, and just as an FYI to all, the 24mm ES sway bar bushings do NOT work on the front sway bar, but I have still yet to check on the rear.
I was planning on getting the, but the day that I planned on ordering them, TAZ put the word out that new SS end-links were coming out with better bushings, so I decided to hold off on the ES bushings.
Old:
Upgraded:
Holly ****!
You didn't even have any more bushings! lol
Wow, so I think that I am most definitely going to get these now and not waste my money on the "new" end-links that are coming out due to the fact that the noise is getting worse and there have been NO updates on the new end-links.
So did all go well and no more
noise from them?
You didn't even have any more bushings! lolWow, so I think that I am most definitely going to get these now and not waste my money on the "new" end-links that are coming out due to the fact that the noise is getting worse and there have been NO updates on the new end-links.
noise from them?
Holly ****!
noise from them?
noise from them?The a$$ is now quiet again and holding TIGHT!!!
Glad to see everyone likes this upgrade. the only thing I would change on that Chern is the washer on the RSB itself. I would remove those, but still have a washer on the other side where the nut is, which I think you have. There was a little noise due to that washer. i did use a full threaded bolt as some of you may find that you run out of threads on the bolt otherwise. No issues since.
EXCELLENT, I'm all over these, 4 of my endlink bushings are gone!!!
Originally Posted by ramberg
I was wondering why I was hearing clanking noise in the rear, I just ordered a new set.
