Changing the daytime driving light 2004 Maxima
I would appreciate some help. I'm a Canuck with a 2004
Maxima and the daylight driving light on the drivers side has burned out. It's a simple 1156 $1.29 bulb.
I can't access the socket because it is behind a plastic stiffener. I tried removing the only 4 bolts that I could see hoping the complete light assembly would move forward but no luck. I know there has to be a simple way to change the bulb and I am open to suggestions.
Thx
Thx
Originally Posted by bushpilotmexico
I would appreciate some help. I'm a Canuck and I am open to suggestions.
Thx
Thx
forget doing it... i had the bulb changed 3 times (both sides)....
the maxima is the only car u see on canadian roads that you might think came from the US (coz no DRL's there!!)
I do this all the time, in fact my guy a Nissan just gives me a handful of the DRL bulbs and I switch them out whenever they go out, which happens lots, according to Nissan these are a warranty item?? For the drivers side you need to remove the air filter box, just undo the hose clamp, remove the lid, pull the filter and then grab the whole box and pull it up, it is just a friction fit (plastic **** in a rubber grommet) that is holding it in place, once you have this out you can then access the the DRL on the drivers side. Let me know if you need the instructions for the passenger side, by the way this takes about 15 minutes once you have done it about 12 times like I have.
If you would like to post or PM me instructions for the passenger side it would be appreciated. The Nissan plastic gommets or screws that hold down the various covers under the hood do they simply pop off or do you need a special tool to remove them? I can see that the cover on the passenger side will need to be removed to access the windshield washer reservoir.
Thanks again
Originally Posted by BadBlackMaxSL
I'm no Canuck- but can't you just drive and have the amber parking lights on or does it need to be a white light?
lots of 6th gen maximas here with one or no DRL....
Changing the passenger side is just as easy! first remove the little plastic plugs that hold down the plastic cover (I think there is 5 on the passenger side) just push gently on the center and they will "drop" about 5 mm then pull the entire plastic plug out, seperate the 2 parts of the clip and when you put them back install the larger piece first then put the center "pin" back in flush to lock the plastic clip in place. Once you get the cover off, grab the fill tube of the windsheild washer reservoir and turn in a 1/4 turn counter-clockwise this will seperate the fill tube from the rest of the tank (just make sure your windshield washer level is down to below the bottom of the fill tube). Then I find it easier to remove the 2 bolts that are holding the radiator expansion tank (10mm I think) and move the tank slightly out of the way, you will then have full access to the passenger DRL.
Once again much thanks for your detailed how to do it description....the sticky left a little to the immagination. I went to Lordco and bought a handful of 1156 bulbs and have them stored in the glove box. I appreciate your telling me how to remove the plastic grommets....I was reluctant to try and pry them out with a screw driver.
Thanks again
not a 100% sure... but i dont think any cops are going to stop anyone here (canada) for no DRL's. I have been driving my max for over a year now with just one of them operating (ever since warranty is over... I'm not going to pay to change that bulb.... or even do it myself as they are useless bulbs)
http://www.iihs.org/research/qanda/drl.html
Yeah no resonable constable is going to give you a ticket for that, but if you mouth off to him.... $85 + vic surcharge and court fee, $110 Canadian.
if an officer wants to pull you over for something and something is amiss about your car. Keep siht thats supposed to be working..... WORKING and you wont get pulled over.
Right TRANCEADDICT???
[QUOTE=kamilkluczewski
[/QUOTE]
agree.... but with the Nissan DRL's, I'd go to court if i got ticketed for it.... 5 bulbs changed on both sides in less than 3 yrs!!!! and i have driven other cars and have never had this problem. doubt i could win... but i'd try
off topic
but i know what you say abt the cops.... everytime I am near one of them (or near borders) I roll all my windows down (tinted)... so they dont think abt it (cant do anything abt the rear windshield .. ie roll it down )
[/QUOTE]agree.... but with the Nissan DRL's, I'd go to court if i got ticketed for it.... 5 bulbs changed on both sides in less than 3 yrs!!!! and i have driven other cars and have never had this problem. doubt i could win... but i'd try
off topic
Originally Posted by kamilkluczewski
There are two types of laws. Canada's requires vehicles to be equipped with DRLs.
Originally Posted by NismoMax80
u do NOT have to remove the bumper. the Sticky covers how to access the bulbs just like post above.
kjlouis
Nov 24, 2018 06:09 AM
RealityCheck
Aug 5, 2015 06:18 AM
yat70458
Aug 3, 2015 01:16 PM
