cylinder 4 missfire.?
Old Jul 10, 2007 | 09:28 PM
marshallc's Avatar
the original problem....
http://forums.maxima.org/showthread.php?t=528338
plugged it into the obd2 reader again, pulled another p102 maf high input, and a p113 iat highimput.. reset the codes, took it for a quick drive
checked the vac at idle and its at 17hg, at 2k rpm it remains at 17ishhg
went for a drive, service engine soon light came back on, got a code cylinder 4 missfire,(p304), and p300, multiple cylinder misfire.
anyone have any ideas?
Old Jul 11, 2007 | 11:15 AM
!PrjctMax!'s Avatar
I'm not an expert on troubleshooting, but how about spark plugs? Have you ever had a "tune-up" done on this car since it has so many miles?
Old Jul 11, 2007 | 11:31 AM
NmexMAX's Avatar
dot dot dot ...
You should do what this man has suggested.
Originally Posted by madmik
Service manual... (www.vq35de.com/ESM/Nissan/Maxima/)
An excessively low voltage from the sensor is sent to ECM.
Harness or connectors (The sensor circuit is open or shorted.)
Intake air leaks
Mass air flow sensor
Manual states that ECU will enter into fail safe mode and will trigger fuel cut at 2400. This would explain why the car is sluggish.
If your buddy's MAF did not help, verify continuity of wires between MAF connection and ECU. If not MAF, then it may be a full ECU failure? MAF circuit is in section EC page 200. Check the fuses, including the ones next to windshield washer fluid. Diagram shows a 15 amp fuse for ECU.
Read code again. May have more than one code.
Reading you past posts, and seeing that you had CAI issues, double check for air leaks between MAF and throttle body (EGR hose too). You said 'much louder'... Intake loud or exhaust loud? If intake noise is consistent throughout rpm range, something is loose/cracked on intake side allowing un-metered air in and intake noise out.
Old Jul 11, 2007 | 11:54 AM
RHMax's Avatar
Newbie just Registered
checked the vac at idle and its at 17hg, at 2k rpm it remains at 2khg
Sounds like you need new ignition coils, all 6 of them.
Old Jul 11, 2007 | 12:07 PM
Lovemycar's Avatar
don't start that **** with those ignition coils i havent heard anyone complain about that in the 6th gen yet correct me if i'm wrong
Old Jul 11, 2007 | 12:38 PM
marshallc's Avatar
did the plugs at like 85k, and its been fine since then
only thing that i havnt done that i was meaning to was change the fuel filter, which i guess i will while shes down.
does this sound like the problem that would be caused by the precat failure?
Old Jul 11, 2007 | 06:06 PM
RHMax's Avatar
Multiple cylinder misfires, and you don't think ignition coils could be the problem?
Old Jul 11, 2007 | 10:19 PM
!PrjctMax!'s Avatar
Like duhh
lol
Old Jul 12, 2007 | 01:26 PM
madmik's Avatar
IAT: Intake Air Temp. Same connector as MAF. From the service manual, high input voltage from IAT means high resistance, to me, an open circuit. But, if you have a bad ground somewhere, the signal could travel an incorrect path.
Check for twisted/loose pins in the connector, a cut wire between ECU and the connector. If it was the MAF, you buddy's MAF would have solved your problem. If the ECU is not receiving a signal from the MAF/IAT, you are probably running in fail-safe mode and running too lean, thus the misfire codes.
But, not enough fuel could could cause the same... collapsed fuel filter? You would not get much power on the highway in this case.
There is a TSB about fried coils caused by a damaged ground wire to the tranny (from the battery). Do you have a grounding kit? Bad grounds cause chaos inside an ECU.
Or grab a voltmeter and follow the service manual to check the wires.
Old Jul 13, 2007 | 01:02 PM
marshallc's Avatar
i was playing around with the obd2 reader and it has a im check function, i ran that and everything is ready but the catilyst, it says there is an error
why would a cat error cause a missfire?
Old Jul 13, 2007 | 01:14 PM
RHMax's Avatar
I think it's the other way around where some unburned fuel erode or detonate in the cats.
Old Jul 15, 2007 | 10:02 PM
marshallc's Avatar
well i pulled every coilpack while the car was running, ran even worse after every one was unplugged so its not a coilpack problem.
can anyone tell me where the service valve on the maximas fuel system is so i can pull the fuel pressure?
any idea as to what it should be at?
or fuel filter is located under the back seat correct?
Old Jul 16, 2007 | 09:41 AM
dla's Avatar
dla
The fuel filter, pump and fuel level sensor are all in one assembly and is in the fuel tank. There is an access panel under the rear seat. Don’t forget to release the fuel pressure before removing the pump assembly. I think you will need a special tool to remove the pump assembly.
If you are going to test the fuel pressure you will need a fuel line adapter and a fuel pressure gauge. It should run 51psi. When checking this make sure you have no electrical items on (lights, radio AC etc.) that could give a false reading.
Old Jul 16, 2007 | 06:24 PM
marshallc's Avatar
now its throwing a p1615 aux input/aux output code? wtf?
Old Jul 17, 2007 | 08:05 PM
madmik's Avatar
P1615- Engine immobilizer says you have the wrong key. Could check fuse 1, 19 and 21 (10 amps each) just in case.
A long shot but what is the voltage with engine is off (12.0-12.6V+) and engine running (14.2-14.6v)?
Old Jul 17, 2007 | 08:24 PM
Favs's Avatar
Damn Marsh how is it going?? anything yet??
Old Jul 18, 2007 | 02:02 PM
marshallc's Avatar
engine off is right around 12.3-12.4 and when its running its a constant 14.3
Old Oct 26, 2011 | 05:38 PM
Les7311's Avatar
....so am a newbie and looking for help.
P304 code diagnosed, but something caught my eyes above.
- engine sounds like sucking more air when depress pedal, but lacking power.
- car jerked and struggled to go above 40 mph today. had to limp home (fail safe???).
where do i start to fix before buying and changing unnecessaries....?
plugs changed at 50k miles back, now at 160K miles.....
Valve body changed a month back
Cat replaced in summer...and more maintenace....
Help!!!
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
dshinn
Sep 26, 2015 08:07 PM
