A warning to others...
Old Sep 2, 2007 | 12:01 PM
coolmax05's Avatar
So I'm pulling out of my driveway and turn my steering-wheel all the way counterclockwise, and here a really bad scraping sound coming from the driver side front tire. But only when the car is moving and the wheel is all the way counterclockwise.
I just got wider tires installed but it did not make any sense that it would rub on only one side. So I jack the car up and remove the driver side front wheel/tire. This is what I found...
This part sticking out is called a "member stay pin". It helps stabalize the "front suspension member". It is held on by 1 big screw and two smaller screws. The two smaller screws were gone. Probably someplace between Arizona and Nevada. So I check the otherside and those screws are about to fall out. I tightened them to 20lbs and now I'm in the market for a new "member pin stay". Unless someone jacked me and I'm the only one--you all should check the two smaller screws holding the "member pin stay" onto the body of your car.
This is a picture of the passenger side and what the driver side SHOULD look like.
Old Sep 2, 2007 | 12:04 PM
Matts04Maxima's Avatar
holy shiznit
Old Sep 2, 2007 | 12:26 PM
Lovemycar's Avatar
THat's what you call made in america
Old Sep 2, 2007 | 08:06 PM
Mack's Avatar
Dayim! Thanks for the heads up CM!
Old Sep 2, 2007 | 08:10 PM
4MySwee's Avatar
Glad you weren't rolling into big digits when that happened/you noticed it.
Thanks for the 'heads up'.
Swee
Old Sep 2, 2007 | 08:32 PM
HedgeHog's Avatar
Thanks for the info. Im going to check mine right now.
Old Sep 3, 2007 | 04:44 AM
ramberg's Avatar
GrandPa
Thanks, I will check them.
Old Sep 3, 2007 | 06:47 AM
Mack's Avatar
Damn, grats on your 3,000th post Ramberg!
Old Sep 3, 2007 | 02:16 PM
kamski's Avatar
.org extraordinaire
HHAHAHHAHAH, by a guy that non hable inglais, wearing an Elvis outfit and drinking a bottle of Jack Daniels. Good O'l Tennessee.
Kamski
Old Sep 3, 2007 | 04:46 PM
RHMax's Avatar
Newbie just Registered
Kamski
Would you prefer them to drink CC?
Old Sep 3, 2007 | 04:55 PM
Y2k2maxse's Avatar
checked mine, bolts were tight. Thanks for the HU!
Old Sep 5, 2007 | 05:01 PM
xorbitman's Avatar
Yikes! Thanks for the heads up!
Old Sep 5, 2007 | 07:15 PM
BadBlackMaxSL's Avatar
Could it be from the added stress of the suspension changes you have done these last few months? Maybe the bolts need to be checked after dropping on lowering springs??
Old Sep 5, 2007 | 08:33 PM
eK9aT10pSi's Avatar
i wonder does it matter for auto/6 spd?
Old Sep 5, 2007 | 09:02 PM
coolmax05's Avatar
I hear ya Bro. But I'm not the only one that has gone low.
I ended up just buying a "new" one. It costed $38.
Old Sep 20, 2007 | 02:16 PM
jlm4rb's Avatar
Many thanks
Old Sep 25, 2007 | 09:44 AM
jimmypronet's Avatar
Thnx.....
Old Sep 25, 2007 | 11:21 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Thanks for the heads up!!!
litch
123
Jan 4, 2024 07:01 PM
captchaos
Mar 15, 2016 12:18 PM
mikeg75
Nov 30, 2015 05:12 PM
Gsantos79
Aug 8, 2015 07:41 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
