siftknob
Old Sep 2, 2007 | 05:18 PM
farzin1's Avatar
siftknob
Anyone out there changed thier shift ****? I drive an 04 max, stick shift; im trying to replace the shift ****. Do I have to twist the exsiting shift **** in order to take it out or it is screwed in? I tryed to twist it but it was kinda hard and I couldnt take it out. Anyone got any answeres?/
Old Sep 2, 2007 | 07:56 PM
Mack's Avatar
Hey bro, I just swapped mine out on Friday to the Momo Italy Black/Chrome Tomahawk. OMG it looks tight! Have a peak, b4 and after. Got this one at Cardomain.com also. Was a few $$ cheaper than could be had on ebay. I've actually lowered the **** about another inch since this picture. Was sitting up a bit too high IMHO and looks tight now. I'll try to get another pic but you get the general idea here. It FEELS much nicer too.
Old Sep 2, 2007 | 09:44 PM
farzin1's Avatar
well how did you take the factory **** out?
Old Sep 2, 2007 | 10:43 PM
Mack's Avatar
I twisted and pulled it. It was a **** but it eventually gave way and came off nicely.
Old Sep 2, 2007 | 11:05 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Wow bro that looks great, consider shaving the height, I cut mine off at the notch, about an inch down...
See the shaft height... (it's a MOMO)
Old Sep 2, 2007 | 11:50 PM
Strontium's Avatar
You should be able to pry the 'sleeve', at the bottom of the ****, apart from the ****. It will slide down and reveal a plastic piece, with a wire clip...
Old Sep 3, 2007 | 02:42 AM
DeusExMaxima's Avatar
Here is my **** and matching e-brake handle. Its from an 06 Evo MR:
Old Sep 5, 2007 | 05:05 PM
xorbitman's Avatar
Nice everyone!
Old Sep 5, 2007 | 05:11 PM
!PrjctMax!'s Avatar
for the auto's-when you cut down the shaft, how does the **** "lock in," or can you just push it off with little effort?
Old Sep 5, 2007 | 05:24 PM
JG1's Avatar
JG1
$12 at WalMart
I cut the shaft down 1" after this pic was taken.
Old Sep 5, 2007 | 05:26 PM
JG1's Avatar
JG1
Thye have little allen scews that secure it in place.
Old Sep 5, 2007 | 05:39 PM
Mack's Avatar
Hey what'd you guys use to cut your shaft? I did lower my **** a bit but like Chern said I think shaving another 1" or so off it would look a bit nicer.
Old Sep 5, 2007 | 06:31 PM
JG1's Avatar
JG1
I used my dremmel w/ a cutting wheel
Old Sep 5, 2007 | 07:18 PM
Mack's Avatar
HAHA damn that easy? OK I see a weekend mod coming up. SWEEET!! Thanks guys. Gotdayim what would I do w/out my Mizzy brutha's up here in Maxima.org??
Old Sep 5, 2007 | 08:31 PM
eK9aT10pSi's Avatar
deus, how is the evo ****/boot held onto the max?
Old Sep 6, 2007 | 09:23 AM
farzin1's Avatar
it looks pretty nice though
Old Sep 6, 2007 | 09:24 AM
farzin1's Avatar
Originally Posted by JG1
$12 at WalMart
hahahaha cheap is the way to go
Old Sep 6, 2007 | 10:10 AM
JG1's Avatar
JG1
Chopped
Old Sep 6, 2007 | 01:34 PM
Mack's Avatar
Did that **** come with a free set of curb feelers?
Old Sep 6, 2007 | 02:23 PM
JG1's Avatar
JG1
.............huh?
Are we trying to crack jokes or something?
Old Sep 6, 2007 | 02:32 PM
The shift **** screwed directly on to the shaft in the same place as the original ****. Before you put the top carbon piece on, you adjust the height with an allen wrench. Then you put the carbon fiber piece on. I also ground off the ridge on the reverse unlock so that the **** screws down to a slightly shorter level than the stock taller ****. The Evo shift **** is a Momo product made only for the Evo MR. Also, that shift **** is weighted for easier shifting, and it works too!
The handbrake handle was different. I wrenched the old ugly handle off and sanded the shaft some. The hand brake handle went on one way and it had tiny allen nuts that clamp to the shaft.
The only drawback to the shift **** is that it gets REALLY hot in the summer unless the car is in shade, and it is REALLY cold in the winter. But nothing that a bit of driving won't cure.
Old Sep 7, 2007 | 08:52 AM
wolf2989's Avatar
Anyone selling their stock **** (auto) that isn't screwed up? Mine the little plastic circle jerk thing is broke and my shifter just sits on there.
Old Sep 7, 2007 | 09:02 AM
JG1's Avatar
JG1
I got one.
$25 shipped?
