Swaybar upgrade
Old Sep 16, 2007 | 07:03 PM
Mack's Avatar
Swaybar upgrade
Anyone have good suggestions for a swaybar upgrade?
Old Sep 16, 2007 | 09:31 PM
Killah Kane's Avatar
stillen one
Old Sep 16, 2007 | 09:32 PM
Mack,
Read my message to you on the ALTIMA SE-R RIMS post.
Old Sep 16, 2007 | 09:36 PM
RHMax's Avatar
Newbie just Registered
Stillen won't fit 05 and up. Progress rear, Altima SE-R front, or Nismo F&R for Altima.
Old Sep 18, 2007 | 02:58 PM
steven614's Avatar
Where can you buy the Nismo ones? And how hard are they to install...to give me a good time estimate, assume it took me 45 minutes to do my intake, lol. Also, when you put the swaybars in, do you need to get the car aligned?
Old Sep 18, 2007 | 03:34 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
Easy to install... takes 10 mins
Old Sep 18, 2007 | 03:39 PM
Mack's Avatar
Originally Posted by Killah Kane
stillen one
Stillen doesn't make one. Any other suggestions??
Old Sep 18, 2007 | 03:53 PM
Sorry, I meant to say Progress one
Old Sep 22, 2007 | 06:52 PM
Mack's Avatar
Guys, sorry to bring this thread back from the dead but I'm having a hard time finding a FRONT swaybar. I have found the Progress rear bar at Autosportstyle.com for $121.20 but I cannot for the life of me find a front sway bar. I see Stillen has one for an '04 but as stated above by RHMax it apparently doesn't fit '05 and '06. I'd like to go ahead and buy them at the same time. Any help from the peeps?
Old Sep 22, 2007 | 07:06 PM
Mack's Avatar
Ok, nm. I'm getting mostly what I need in the mod section. Although several of those links are out of date.
Old Sep 22, 2007 | 07:24 PM
Hilbe's Avatar
If you find a how-to let me know. I'm doing the rear one here in a few weeks...
Old Sep 22, 2007 | 10:58 PM
STARR's Avatar
anything that fits an 04 maxima will fit the 05/06 the 3 are identical, and the 02-06 V6 altima is also a good reference.
rear sway bar is cake but I broke a socket on the last bolt which stripped the bolt and eventually ended up paying someone to cut it off, that added up fast the front is not easy but is doable, but get a friend or just pay a shop to do it, in the end my bars where free and install was free but paying to have that bolt replaced was more then I wanted to
Old Sep 23, 2007 | 04:41 AM
Hilbe's Avatar
Does the rear need to be jacked up in the air to install it? I have ramps, can I just roll the rear up on ramps?
Old Sep 23, 2007 | 07:29 AM
Mack's Avatar
Are you 100% sure about that? I just find it weird that a very reputable company like Stillen advertises a 2004 rear sway bar, but not a 2005 or 2006. Maybe I'll give them a call on Monday to ask but I'm hesitant to purchase. Especially after RHMax stated above that it wouldn't fit the 05 and up.
Old Sep 23, 2007 | 07:35 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
The Stillen rear Anti-sway bar will only fit an 04, need Progress for an 05/06
Old Sep 23, 2007 | 07:37 AM
Mack's Avatar
The master has spoken. Thanks for chiming in Chern!
Old Sep 23, 2007 | 08:12 AM
philoforlife's Avatar
Is the Altima SE-R FSB worth it if one is going to have the Progress RSB and the new Racingline FSTB? If I understand correctly, too much correction on the front will cause excessive oversteer??? Anyone running the full set up and can chime in?
Joshua
Old Sep 23, 2007 | 08:14 AM
Actually I think !PrjctMax! is running that set up - is it worth it man? I have an 04 Auto, soon to be with the RSB and the FSTB...worth the extra cash for the FSB?
Joshua
Old Sep 23, 2007 | 08:30 AM
chernmax's Avatar
Joshua
You should ask Deus, he has the SE-R Front Anti-sway bar and he autocrosses with it, no better man to answer your questions...
Old Sep 23, 2007 | 08:48 AM
Awesome!
Deus, care to chime in? Extra money worth it?
Joshua
Old Sep 23, 2007 | 10:38 AM
coolmax05's Avatar
The rear end (both sides at the same time) has to be jacked up and take of both rear wheels (easier).
You need a Hydraulic jack & 2 jackstands. Be sure to spray the bolts before hand with PB "Fabulous Blaster" a thread loosener. Be sure to have a rachet with a long handle for leverage.
Regarding the Progress Sway Bar. It is "WAY" thicker and heavier than the stock sway bar. I can attest to this. So, for $122 it's a great value. With the saving in money you can get endlinks or something else that meets your fancy.
Old Sep 23, 2007 | 02:48 PM
How much is the Altima FSTB anyway? Difficulty to install?
Joshua
Old Sep 23, 2007 | 03:09 PM
chernmax's Avatar
Joshua
PM Deus, he has the 411, if I remember correctly, about $150 and he did the install himself which required dropping the front sub-frame...
Old Sep 23, 2007 | 03:43 PM
STARR's Avatar
my bad I did not realize the bar in discussion was the stillen RSB.
I have the Stillen FSTB and the Front and Rear Nismo sways, the car should have came from the factory like this at least the SE, this car feels so planted around turns and I've pushed it hard entering on and off ramps and it leaves me speechless, I would say if handling is what you want then do the upgrade and hang with the bimmers in the twisties when pushed the car becomes more of a drivers car instead of the cruiser
Next up will be tires, endlinks and suspension then breaks, etc...
Old Sep 23, 2007 | 03:44 PM
STARR's Avatar
does anyone know why it only fits the 04, did something change
Old Sep 23, 2007 | 04:10 PM
chernmax's Avatar
LOL, how many breaks do you plan on taking???
Old Sep 23, 2007 | 04:11 PM
chernmax's Avatar
The alignment changed slightly so when progress developed theirs, it was designed around the 05 platform...
STILLEN developed theirs on the 04 platform...
Old Sep 23, 2007 | 04:18 PM
STARR's Avatar
I working on so I can take many breaks, and during 1 of those I'll work on my brakes
Old Sep 23, 2007 | 04:26 PM
chernmax's Avatar
Excellent, I'm all about progress also, thanks for laughing with me...
Old Sep 23, 2007 | 04:59 PM
!PrjctMax!'s Avatar
I think that it is a very worthy mod! I got it for $92.44 shipped from this website...http://www.trademotion.com/partlocat...?siteid=214143
It's not working now... but try it later. I think the part numbers are still in the stickies.
Right after I installed it, I took a cruise and in tight fast turns, the front felt much "flatter," and didn't lean as much.
Old Sep 23, 2007 | 05:02 PM
Ha! I just PM'd you about this!
You don't have an FSTB...I'm wondering if that compensates enough in the front - too much stiffness results in oversteer. Are you getting the Racingline FSTB?
Joshua
Old Sep 23, 2007 | 05:05 PM
!PrjctMax!'s Avatar
Joshua
lol, just replied to PM and the KYB AGX should compensate for the front being so stiff.
Old Sep 23, 2007 | 06:22 PM
chernmax's Avatar
Excellent, even better price FTW!!!
Old Sep 23, 2007 | 06:28 PM
Mack's Avatar
Dang that's a great price. If the site comes back up I'll go ahead and order. Thanks !PrjctMax!
Old Sep 23, 2007 | 10:43 PM
DeusExMaxima's Avatar
Its a fairly difficult job doing the front sway bar. I had to redo it to get the steering linkage hooked up and I did it fairly quickly once I knew what to do. I also have air tools and am a much better than average backyard mechanic. Doing swaybars with RacingLine endlinks is a great upgrade. The endlinks make a difference on their own. I have prototype front ones and am so pleased with the result.
Old Sep 23, 2007 | 11:02 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
are they taz's ?
Old Sep 24, 2007 | 07:24 AM
Mack's Avatar
Anyone got a linky to the racingline endlinks?
Old Sep 24, 2007 | 07:29 AM
Hilbe's Avatar
http://www.racinglineperformance.com...products_id=35
Ordered mine last week. Can't wait for my Progress RSB and RacingLine Endlinks.
Old Feb 24, 2008 | 04:47 PM
2theMaX05's Avatar
I know this old thread but what is the thickness of oem 05-06 rear swaybar compared to a progress bar.
Old Feb 24, 2008 | 05:55 PM
Mack's Avatar
FYI I have a brand new progress RSW in the box if anyone is interested. PM me.
