Wide open throttle
Old Sep 30, 2007 | 09:59 AM
digitalfish's Avatar
Wide open throttle
Something was posted on this and forgive me but I cant find it. Can someone link the discusion about the throttle closing back from WOT after a certain RPM or MPH or how to "fix" that if it can be done.
Old Sep 30, 2007 | 10:49 AM
!PrjctMax!'s Avatar
It's called DBW (drive-by-wire) and at WOT (wide open throttle) it can actually hold back up to 20%. The only "fix" that I am aware of is the TechnoSquare ECU reflash. google them and check it out for yourself
dan
Old Sep 30, 2007 | 10:51 AM
Glude's Avatar
yep, TS flash to fix. Reminds me I need to get in touch with those cats.
Old Sep 30, 2007 | 05:44 PM
thanks very much
Old Sep 30, 2007 | 05:49 PM
NmexMAX's Avatar
dot dot dot ...
Throttle doesn't close on the 5.5gen, not sure about yours, but I don't think it does.
Old Sep 30, 2007 | 07:10 PM
Nietzsche's Avatar
Nmex is right, I saw a graph that indicated no change in position and through my own testing I saw no evidence of such an anomaly
Old Sep 30, 2007 | 07:28 PM
RHMax's Avatar
Newbie just Registered
It gradually closes so it may not have shown on the graph. I noticed it when TS was tuning my ECU. I drove on a few different stages of tuning.
Old Sep 30, 2007 | 07:31 PM
NmexMAX's Avatar
dot dot dot ...
Voltage doesn’t change so it doesn’t close since it is controlled via voltage.
Old Sep 30, 2007 | 08:22 PM
to be clear here. We're talking about a 6th gen 04 to 07 right? Theres some mention of a 5.5 gen and I'm not sure where that fits in years. Was also under the impression there was some proof of it. Maybe TechnoSquare is a better source to find out although for 500 smackers I'm sure I'll live with the "problem" at this point.
Old Sep 30, 2007 | 08:33 PM
NmexMAX's Avatar
dot dot dot ...
Well, the price can be semi-justified since TS does modify other parameters too.
I have the 5.5 gen (02-03) and stated I have never seen anything re: closing as RPM’s climb. It’s actually impossible since there are 4 sensors, and they must be within a certain tolerance with respect to voltage of each other or else the car will go into limp mode.
With that said, your foot is pegged so it’s(APPS 1&2) say 4.10V, and the TPS(1&2) (actual throttle plate) are @ 4.08V, if they deviate more than that(i.e. TPS starts to close) the car will go into limp mode since your foot isn’t letting off the pedal.(voltage stays @ 4.10v)
Old Sep 30, 2007 | 10:19 PM
RHMax's Avatar
If this is correct how would an L-Spec pulled a little better than stock above 5500RPM? Like I said, I went thru the different tuning stages and had the car over night wth the basic L-Spec, 40 miles of driving to and from.
I'm not arguing with you found. I'm just wondering if there was more to it.
Old Sep 30, 2007 | 10:28 PM
Nietzsche's Avatar
What is involved in L-spec? I have monitored the sensors with two different systems and niether one shows any change. I highly doubt it closes without a voltage change in sensors.
Old Sep 30, 2007 | 11:16 PM
DeusExMaxima's Avatar
Tadashi told me that Nissan programs the throttle so that you get full open throttle under certain conditions and that its not like u bury ur foot and it opens up. I was there when Tadashi tuned my car and I could CLEARLY hear the throttle opening up AFTER the re flash but it didnt do it before it. I have read that NIssan also did htis with the 5th gen Maxima. but Icant confirm my source cuz it was a long time ago i read it.
Old Oct 1, 2007 | 06:49 AM
NmexMAX's Avatar
dot dot dot ...
The plate moves just like your right foot tells it to. Maybe a quarter second delay.
IMO, only the 7100 rev limit.
Never seen a dyno that confirms that. My before and after did not show that.
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
msellas
Sep 23, 2015 09:16 PM
Bonka
Sep 14, 2015 11:18 PM
