clutch/flywheel?
Old Oct 3, 2007 | 08:06 PM
marshallc's Avatar
clutch/flywheel?
anyone have any experence with a clutch/light weight flywheel on a 6th gen?
swapping the motor sometime in the next week or two figured i should do the clutch while im at it, thinking of going with a spec stage 1 but figured id ask here if anyones got a recomendation/suggestion
Old Oct 3, 2007 | 10:23 PM
DeusExMaxima's Avatar
When my clutch goes I an DEFINITELY getting a stage 1 or 2 clutch and light flywheel. I just replaced the clutch/flywheel on my daughters 02 Celica GTS and I put in a Fidanza lightweight flywheel (8 lbs!!!). Her stocker is around 14 lbs. It made a LOT of difference. Car is much more responsive and revs MUCH better. I cant wait to do my clutch so I can get lighten flywheel. See what is out there, do your research, and get a good set up. I think the G35/350Z flywheels all work but double check and make sure. Find out weight of stocker and get one thats maybe 40% lighter or so. You dont ant to go too light or it becomes tough to drive. and PLEASe keep us posted. Also, can you weigh your flywheel and clutch once you get it out. Thanks!!!
Old Oct 4, 2007 | 06:52 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=327187
http://forums.maxima.org/showthread.php?t=330423
Cattman
Dec 9, 2009 02:42 PM
Cattman
Sep 29, 2009 02:03 PM
WxAxGxS
Aug 18, 2007 08:56 PM
96mAx2fast
19
Oct 23, 2006 11:59 AM
EdgeX
May 7, 2006 08:41 PM
