A34 MAF mod info
Old Oct 26, 2007 | 09:05 AM
shawndon's Avatar
A34 MAF mod info
We have been discussing the effects of what having a larger MAF housing will do for performance. So far we know that it improves throttle response and overall performance. There is some tuning required as adding a larger MAF housing causes the engine to run lean. So the aid of an AFC or similar tuning device along with wideband o2's for 04 6th gens are needed to tune.
Just Thought we would start a new thread for those 6th gen inwers interested in the larger MAF housing mod. It starts on page 2 of this thread and ends on page 3
http://forums.maxima.org/showthread.php?t=542294&page=2
Old Oct 26, 2007 | 09:52 AM
NmexMAX's Avatar
dot dot dot ...
Thank me later
Background information is somewhat deceptive. Here are relative links, and good reading. The concept to all MAF sensors is the same, so just because your specific generation isn't mentioned, the information is still viable. Feel free to do a search on the subject, as that may also be helpful.
General MAF knowledge/principle.
http://forums.maxima.org/showthread.php?t=341223
http://forums.maxima.org/showthread.php?t=344514
http://forums.maxima.org/showthread.php?t=294132
The first person to try it.
http://forums.maxima.org/showthread.php?t=101371
More bandwagoneers.
http://forums.maxima.org/showthread.php?t=390691
http://forums.maxima.org/showthread.php?t=401373
http://forums.maxima.org/showthread.php?t=401569
http://forums.maxima.org/showthread.php?t=406909
http://forums.maxima.org/showthread.php?t=402892
http://forums.maxima.org/showthread.php?t=404074
http://forums.maxima.org/showthread.php?t=400399
Words/thoughts taken out of my mouth after I installed it. (Note: The link in the second URL below is actually linked to the 3" PVC link I posted above, due to the new org set-up, it will send you to an older/off the wall link, just FYI)
http://forums.maxima.org/showpost.ph...12&postcount=7
http://forums.maxima.org/showpost.ph...4&postcount=20
http://forums.maxima.org/showpost.ph...3&postcount=54
More good general MAF housing mod reading:
http://forums.maxima.org/showthread....&highlight=MAF
Old Oct 26, 2007 | 10:01 AM
redls1's Avatar
MAXIN' ON
Originally Posted by NmexMAX
Thank me later
More bandwagoneers.
Thanks for your efforts in supplying all links as I now have alot of reading to do!!!
Old Oct 26, 2007 | 10:24 AM
shawndon's Avatar
Good shot Nmex.
Old Oct 26, 2007 | 10:34 AM
DeusExMaxima's Avatar
I have heard that the 350Z fuel injectors are 20mm larger than the Maxima's. Would this help the lean condition if 350Z injectors were used?
Old Oct 26, 2007 | 12:55 PM
NmexMAX's Avatar
dot dot dot ...
20mm?
Did you mean they flow 20 more cc per hour? (A34's 315cc vs Z33's 335cc @3.5 Bar).
I have Z33 injectors, and I was still lean when I added this upgraded MAF housing. You would need some pretty massive injectors to compensate.
TallTom
57
Oct 14, 2025 05:16 PM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
