View Poll Results: Have you had any trans issues?
2004 Auto tran problems
138
24.56%
2005 Auto tran problems
74
13.17%
2006 Auto tran problems
32
5.69%
2004 Auto tran replaced
2.67%
2005 Auto tran replaced
1.60%
2006 Auto tran replaced
2.14%
No transmission problems yet.
282
50.18%
Voters: 562. You may not vote on this poll
6th Gens and Transmission problems
Old Dec 19, 2007 | 04:40 PM
  #41
Apollos2's Avatar
According to the pics, at start up probably not at all because it's a little radiator. No movement, no cooling I think. In the winter
If I can figure out a cooler that will work, I will take some before and after temps off the dipstick and see if the temp actually drops. Check out that pic on the Stillen site (you gotta click on the little wrench) and you will see what I mean. I was kinda thinking it might not be affective, not that it would over cool.
Heck, does someone know what the operating temp on the tranny is anyway?
Old Dec 30, 2007 | 07:20 AM
  #42
Apollos2's Avatar
Well, I've got the car back. They replaced my broken tranny with a remanufactured one. Totally charge on my ticket was like $3,500. Much lower than I expected, I wonder if it would be higher if I was paying for it.
The tranny felt kind of "tight" (if that makes any sense) when I drove it home. I drove it to work and back a couple of times, it's starting to feel like normal again. I haven't really romped on it yet though, I'm just giving it some time settle in. Dealer recommended changing the fluid at 30k instead of 60k. I'll be doing that.
As far as the tranny cooler is concerned, it looks like it's a no go as we don't have tranny fluid lines to connect to.
Originally Posted by SouthFlMaxTech
yeah.. there are no cooler lines so you cant add a cooler michael!! sorry to say that....
Old Jan 1, 2008 | 08:16 PM
  #43
farzin1's Avatar
knoc on the wood so far so good and no tranny issues with my 04 mt max
Old Jan 2, 2008 | 11:40 AM
  #44
MaxEx's Avatar
My transmission shifts fine under normal driving conditions, and even under hard acceleration but at times when it down shifts upon acceleration it will really hit hard into the lower gear. it doesn't slam or make any noises, but it does hit pretty hard, not very smooth at all. It's like if you are driving a manual, rev the engine in neutral and then slam it into second at 35-40. Anybody have input on this?
Old Jan 17, 2008 | 04:19 PM
  #45
guzziee's Avatar
Are the tranny problems mostly with the 5 speed transmission?
Old Jan 19, 2008 | 10:50 PM
  #46
xorbitman's Avatar
I had a 2004 Maxima SL with the gated shift...it was such a lemon that they bought back my car after only barely 81/2 months! They put me in a 2005 SE and gave me all sorts of extras...The transmission failed after 10K Miles! Anyway so far so good on the 2005 SE hope it stays that way...knock on wood!
Old Jan 24, 2008 | 05:00 PM
  #47
wildman04's Avatar
MAXXED OUT Member!
I have a 2004 SE with a 5 speed auto. When shifting into reverse it hits pretty hard (going from park or from drive to reverse) . Has anyone had a similar issue with this problem and if so do you know what to do for it?
Old Jan 28, 2008 | 11:55 AM
  #48
Blue04SEinIL's Avatar
I've been changing (3 quarts) my trans fluid every 30k miles and its been nasty. Its dark and it stinks. I haven't had any trans problems yet, but I'm increasing the frequency of changes to 15k miles. Part of the problem too is that you can only drain 3 out of a total of, I think, 14 quarts. Not cheap either at $13 a quart.
Old Jan 28, 2008 | 03:47 PM
  #49
gen2000's Avatar
The factory service manual states that the 5 speed automatic trans axle holds 7 3/4 qts.
including the torque converter.
Old Jan 28, 2008 | 04:02 PM
  #50
MissMiami's Avatar
I have a 2004, and my transmission has been replaced. Such bad slippage, it was getting quite dangerous.
Old Jan 29, 2008 | 09:25 AM
  #51
kaymonster
I have the exact same problem. It makes terrible clunking noises and shakes the car whenever i shift from park to reverse or reverse to drive. It also has late shifts between 1st, 2nd, and 3rd. A replacement (remanufactured) through the dealer was about $3400 (average cost, i called 4 different dealerships) and only came with a 12 mo./12k warranty. I am having AAMCO rebuild it for $3800 and they incldue a 3yr/36000k warranty. I wish i had gotten the extended warranty now. who would have guessed a 6th Gen car would have a tranny go out at 70k miles???
Old Jan 29, 2008 | 09:30 AM
  #52
kaymonster
replaced
I voted "Tran Problems" but probably should have voted "Tran Replaced" as the transmission is currently being rebuilt.
Old Jan 29, 2008 | 06:52 PM
  #53
Apollos2's Avatar
They just keep adding up.
Old Jan 29, 2008 | 07:03 PM
  #54
!PrjctMax!'s Avatar
****, if mine ever goes out, then I may as well spend the equivalent amount on a "built transmission," instead of the factory one.
*knock on wood*
Old Jan 29, 2008 | 10:23 PM
  #55
black ghost's Avatar
I have a 4AT
and I did a tranny rebuilding 1 month ago!
Old Feb 7, 2008 | 02:40 AM
  #56
diontrejo's Avatar
I just had my second transmission replaced in my 04 Max. The first was at 24,000 (had terrible slippage) (under warranty) and now at 74,000 (cost 4k). I've had quite the experience with this Max. I'm actually thinking about trading it in for somethin else.
Old Feb 7, 2008 | 05:43 AM
  #57
Apollos2's Avatar
You 2nd tranny? And it only lasted 50k. Wow, I guess when they have bad trannys they have bad trannys. I'm hoping my rebuilt lasts more the 50k. The only thing I am really going to do different is have the fluid changed well before the mfg recommendation.
Old Feb 7, 2008 | 06:03 AM
  #58
ecomeau's Avatar
Originally Posted by timwdv
I have a 04 auto with 91k on it and i just wanted to know if this was normal to you guys. When I leave and the temp is on C for cold the transmission jumps from 1st to 2nd, is that normal b/c the fluid or tranny is cold?
my 05 has been jumping from 1st to 2nd since I bought it new but not every day. I brought it to the dealership and of course, the car worked perfectly. I have 79,000 miles on it now. it still does it from time to time especially if I am going 20-25 mph the shifting up and down is very jerky. I hate it and I am waiting for it to just die then I will spend a fortune getting it fixed.
Old Feb 7, 2008 | 06:13 AM
  #59
anm6's Avatar
Mine is starting slip more under acceleration and now under normal driving, also the groan when I first start out and slowing to a stop is getting worse just made an app for the 18th at the dealer. I will let you guys know how it goes.
Old Feb 7, 2008 | 11:56 AM
  #60
ecks's Avatar
I piss on Civics.
My tranny seems to struggle on quick corners but other than that I am problem free. Pray for me D:
Old Feb 8, 2008 | 04:58 AM
  #61
Kryogen's Avatar
What about the 07-08 CVT? Do they fail?
Old Feb 8, 2008 | 05:13 AM
  #62
cklamer's Avatar
No one has probably had the 07-08 long enough to find out.
Old Feb 8, 2008 | 05:40 AM
  #63
bb700092's Avatar
Yes, sometimes the CVTs fail unfortunately. But it is not at an alarming rate. Check out the Murano forums, for e.g. http://www.nissanmurano.org/forums/s...?threadid=2002, http://townhall-talk.edmunds.com/WebX?14@@.f133968/0, etc.
Here are some 07-08 Maxima CVT problems (but couldn't find many since they haven't been long enough, I guess):
http://forums.freshalloy.com/showthread.php?t=161947
http://forums.freshalloy.com/showthread.php?t=162435
The last one I don't think is a problem but just the way the CVT behaves, at least partially. For example, when cruising, releasing the gas pedal and then getting back on the gas (not aggresively) there is sometimes a sort of "kick" sensation. I think this is normal for the CVT and found it in all the three 07 Maximas I have driven.
Old Feb 8, 2008 | 06:03 AM
  #64
Lovemycar's Avatar
40K no tranny issues
Old Feb 16, 2008 | 12:01 PM
  #65
2theMaX05's Avatar
ON MY 05 TRANI WENT AT 14K I WAS LIKE WTF.. .DEALER AT FIRST TRY TO GIVE ME A HARD TIME AND REFUSE BECUASE OF MY EXHAUST MOD. THEY WRE TRYIN TO BS ME SAYIN EXHAUST GIVES MORE POWER TO THE WHEELS SO MY TRANI WENT. I LAUGHED SO I ACLLED NISSAN HEADQUARTERS THEY TOLD ME THEY SHOULD WARRANTY IT. ITS JUST EXHAUST WHICH HAD NO EFFECT ON TRANI .SO I WAS CALLIN FLATBED TO TAKE IT SOMEWHERE ELSE THEN THEY CHANGED THEIR MINDS AND DECIDED TO FIX IT IT WAS REAL FUUNY. SOMETIMES YOU HAVE TO BE FIRM ON YOUR WARRANTY OTHERWISE YOU GET THE BS REFUSAL.
Old Feb 16, 2008 | 08:40 PM
  #66
Apollos2's Avatar
Yeah the new mufflers always blow the transmisson, stupid dealership. Good job and callin their bluff.
Old Feb 19, 2008 | 06:55 AM
  #67
jrzymuscle25's Avatar
ok.. so I can't post new topics since I'm the 'new guy' but here's my story... bought my 04 se like a few months ago w/ 1k warranty and thats it- got it for a steal because of the high mileage (95K miles) and I only paid like $11000 for it.. Now I'm at 99K miles and I noticed in the last thousand miles like maybe 2 or 3 times the transmission SLAMMEd into 3rd gear.. and freaked me out so I drove her real nice. Well today I may have f'd it up since I was in a rush to work and someone decided to make a right turn in the middle of the road and I went to pass around by punching the gas. Well nothing happened for a second and then BAMMM and CHIRP the car takes off.. I was like oh crap.. and then after that it went straight to 5th gear I think at 35 mph.. so I was freaked.. the next few miles it would not come out of 5th gear- I ended up pulling over and turning the car off completely- restarting and then the check engine light came on and it was in 1st gear. Drove away and it had a rough shift into 2nd and then into 3rd and then went straight to 5th. From there on out, it only went to 3rd and wouldn't go any further down.. Now i'm here at work buggin out! What do i do? I heard something about a TCM?? Any Input is appreciated!!
Old Feb 19, 2008 | 10:39 AM
  #68
STARR's Avatar
With 45800 on my 06, the car shifts smooth and fast, feels smoother but I may just be use to it.
Old Feb 19, 2008 | 10:40 AM
  #69
STARR's Avatar
did it feel like you hit a piece of ice and the car accelerated but did not go, thats a slipping trans
Old Feb 19, 2008 | 02:53 PM
  #70
the transmission didn't slip- it just slammed and then got stuck in 5th gear ... and it only would go back down to third gear.. there was no slipping noise or grinding or anything
Old Feb 20, 2008 | 08:14 AM
  #71
ughh- the error code that came up was PO744D and basically the conclusion is I need a rebuild- so its sitting in the shop till tomorrow where my guy is gonna drop it and open it up-- SUCKS.. and I just got this car like 2 months ago..
Old Feb 20, 2008 | 08:24 AM
  #72
xoomer.com's Avatar
I Donate! Why Don't You?
Had mine replaced on 2004 about 2 weeks ago. The slipage was so bad that the car was just going places I didn't want it to go. Coming to a stop the 2nd gear was so hard that I practicaly got a whiplash. Last nissan for me, you bet your @ss it is.
Old Feb 20, 2008 | 08:32 AM
  #73
SickSE
^^^ That sounds crazy man. I gotta 2004 as well but no problems whatsoever and smooth as silk from day 1 with 75K on the clock....
Old Feb 20, 2008 | 08:53 AM
  #74
Did you replace or rebuild? Mines just as bad with the slamming and it def slips in 2nd and 3rd gear which sucks @ss..
Old Feb 20, 2008 | 08:57 AM
  #75
xoomer.com's Avatar
The dealer replaced it with a rebuild/refurbished one. From outside it looks brand new. According to a friend they rebuild them from scratch and only re-use the shell.
I spoke to another friend who owns tranny parts wholesaler business and he said that valve bodies are to blame. He said that they have been getting a lot of phone calls for this tranny within past year.
Another thing he said that I found interesting....change the fluid every 10K or don't change it at all, ever.
Old Feb 20, 2008 | 08:58 AM
  #76
xoomer.com's Avatar
On another note, I am wondering of those who had their tranny replaced or it is currently slipping, how many had their trannies flushed????????
I did at 35K
Old Feb 20, 2008 | 09:11 AM
  #77
bb700092's Avatar
What is the logic behind that?
Old Feb 22, 2008 | 05:39 PM
  #78
so the tranny is out-- took some pics with the cell as you can see below.. also- the guy showed me the fluid from the tranny was dark and had metal flakes in it ... not good he said... he said i might just need a replacement... not sure-- he's going to open it up monday... tell me what you think..
Old Feb 23, 2008 | 08:39 AM
  #79
kevin007's Avatar
Originally Posted by SilverMax_04
You did not provide an option for 6-speed manual trannie owners to reply. I have 66 K miles on my Max. I changed my OEM trannie fluid at about 30 K miles and went to synthetic. No trannie problems. Don't expect any.
Which Synthenic and type did you go to and is it recommended for the Auto?
Old Feb 23, 2008 | 09:03 AM
  #80
SilverMax_04's Avatar
The fluid in a manual trannie is much different from (and heavier than) the fluid in an auto trannie -- the two are not compatible.
I used Redline MT-90 because, at the time, Amsoil had quit making the proper fluid. Amsoil now (again) makes a GL-4 (single grade) gear oil, and I will be using that when I change the fluid again at about 90 K miles.
