Parking Brake Adjustment...
Old Nov 30, 2007 | 08:45 AM
Dayle97SE's Avatar
Whats the proper way to adjust the parking brake, I think mine is sticking a little. The back wheels seem to have a little to much drag, and where is the adjustment made, at the wheels or at the handle inside the car?
Old Nov 30, 2007 | 09:10 AM
NismoMax80's Avatar
SuPeRmOd
pull the handle all the way up. you will see a hole for a phillips on the stick.
i think this is in the manual, not sure though.
Old Nov 30, 2007 | 11:08 AM
NIKV69's Avatar
When I did my brake job I noticed a hole in the rear rotor. Through there is a adjustment similiar to one on old drum brakes. I adjusted it so there was slight drag and the lever in the car was much better. To back it out I would think you could pull the rotor and pull up that lever and turn the wheel the opposite way till there is less drag.
Old May 16, 2009 | 02:46 PM
DeusExMaxima's Avatar
By the way, you tighten it by rotating the wheel, DOWN with a flat blade screwdriver.
Old Mar 10, 2010 | 07:20 AM
Tom1222's Avatar
Okay, I am a bit confused. What wheel needs to be rotated?
I have a stretched parking brake and want to tighten it a bit.
Thanks for your help!
Tom in Indy
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
