My maxima is sick...
Old Dec 2, 2007 | 07:37 PM
Bezzle01's Avatar
Well while I was driving I noticed that the car was shaking at idle and even at low rpms. At idle I revved it and heard a little knock or 2 and when the rpms settled it knocked a few times. I was really scared that it was major. I thought maybe bad gas so about an hour later I went to go get gas. Sitting at a light I noticed the car wasn't shaking anymore and 5 seconds later the SES light came on. It kinda makes like a hissing type sound when revved to 3-4k rpms but its not an air hissing and i hear no exhaust leaks(I've heard them plenty of times). The idle is fine now so I'm just babying it till tomorrow morning till I can get to Autozone for a reading. Anybody have any input as to what this might be? Bad cat, bad 02 sensor maybe? Knock sensor? Belts are on and they are brand new. Probably not a MAF , I had one go bad in my 02 Maxima.
Old Dec 2, 2007 | 07:44 PM
SmokinMax02's Avatar
Sounds just like the code PO430, imo.
First thing I would do is go to your local autoparts store (autozone, advance, ect.) and have them run an OBD II scan to find the code & clear the SES light.
Wait a few weeks, and if the light comes back, then you know you have a problem.
My best guess, without seeing a code, would probably be a bad pre-cat or cat and/or a bad o2 sensor on bank 2.
Good luck!
Old Dec 2, 2007 | 08:11 PM
Bezzle01's Avatar
Yea I'm definitely going to autozone first thing in the morning. I was thinking maybe a cat due to the knocking not coming from the top of the motor, Sounded more like from the bottom area.
Old Dec 2, 2007 | 08:40 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
whta year and do u have mods?
maybe cai is not on all the way to the TB?
Old Dec 2, 2007 | 10:18 PM
Bezzle01's Avatar
2004. Intake is all, I checked the connectors and they seem fine, it happened after dark so I can't see very well but I'll check all of those in the morning. My vibramount for the Injen intake broke so it wobbles a little. I still will to go to autozone to get the code. Thanks for the input.
Old Dec 2, 2007 | 11:27 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
No worries... keep us posted and check the top of the CAI in the morn
Old Dec 3, 2007 | 08:24 AM
Bezzle01's Avatar
p0305(I think I didnt get the slip) Cylinder 5 misfire. Can anyone link me to the firing order, I'm having a hard time searching for it.
Old Dec 3, 2007 | 08:33 AM
Bezzle01's Avatar
Would this be the same as my year?
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Dec 3, 2007 | 02:01 PM
Bezzle01's Avatar
Anyone?.... confirm/deny?
Old Dec 3, 2007 | 02:27 PM
GrimMax's Avatar
Where is my shirt?
When was the last time the check engine came on?
Old Dec 3, 2007 | 03:12 PM
Bezzle01's Avatar
it came on last night but after driving around a little today it went off. Seems to idle a little low still but not shaking anymore. It idles t like 500-750 rpm.
Old Dec 4, 2007 | 02:10 PM
GrimMax's Avatar
Where is my shirt?
You have the CAI right? Try disconnecting everything from it and then reconnecting. I had the same problem recently like yours and I did that and fault cleared. I even took it back to autozone to makesure no faults.
Oh.....Did you get the reading from Autozone?
Old Dec 4, 2007 | 06:34 PM
Bezzle01's Avatar
Yea it was a cylinder 5 misfire, p0305. The light went off and now the idle is back to normal Seems to be back to normal but I think I'm still going to tighten all the intake connections tomorrow just in case.
Old Dec 4, 2007 | 06:55 PM
GrimMax's Avatar
Where is my shirt?
Ohhh ok I didnt see you post the fault earlier.
Wouldnt that be covered under warranty?
Old Dec 4, 2007 | 07:23 PM
Bezzle01's Avatar
Nah I bought used and I'm at 59k miles.
Old Dec 4, 2007 | 08:12 PM
GrimMax's Avatar
Where is my shirt?
Ohhh ok.
I found this pretty neat link that might help narrow down the causes to this code. See para 3
http://www.aa1car.com/library/misfire.htm
Old Dec 5, 2007 | 07:51 AM
Monotaur's Avatar
The great thing about Nissan's warranties is that they transfer to the new owners with used cars. Also, this sounds like it would be covered under the power train warranty which lasts until 60K miles, unless your car was purchased over 5 years ago.
I'd call the dealer to check on warranty status, and then have them look over it if it is covered... wouldn't hurt anything anyway. It might even save you some headaches later on.
Old Dec 14, 2007 | 10:06 AM
GrimMax's Avatar
Where is my shirt?
I agree.
I thought it was either 60 or 100K PLUS or 5 year including power train?
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
