Front/ Rear endlinks
I will be doing the the front and rear endlinks this coming weekend but wanted to get any heads up from the ppl who already have done them? any advise? anything to watch out for? a guide to installing them? Thanks ahead of time
Make sure to put both sides of the car on jack stands. Jacking one wheel up at a time puts tension on them and makes them a bit more difficult to get on/off. I jack one wheel at a time and put a second floor jack under the wheel hub though
Also get some bolt buster and have a breaker bar handy. I can't seem to bust the bolts on my fronts, otherwise those would be on by now. I just ordered an air ratchet I'm going to try...
Worst case the dremel comes out and I cut those bolts off...
Careful with that air ratchet. They don't have an internal clutch like an impact and can smash your hand into the frame or something solid if the bolt doesn't let go. PB Blaster is my favorite, but Liquid Wrench is cheaper and easier to find. Does anyone make a front sway bar upgrade? I believe I read the Altima SE-R's fits? Probably hard to find used.
Thanks a bunch to you and Deus. I def want to get that and that is a really good deal. Is the SE-R rear bar worth upgrading to? I am trying to snag that Progress bar so I will prob go with that anyway. If you could get that URL that would rock.
Cant go wrong for $90 for front. Sway bars make a significant difference in handling.
I had done a full susp. swap on one of my first vehicles and it was too harsh of a ride so I put the factory suspension back on with good shocks and the aftermarket sways. It had a great mix of ride and performance. Not near as good of handling but body roll is really annoying to me so minimizing that is my goal. I am not sure if the front end links will reduce it or are more for fine tuning you turn in and pre-loading the bar, etc. If they help I will eventually get them.
Sorry for the website delay, but here it is.
www.1stAAANissanParts.com
You can find the part #'s in the stickies, or just give them a call
Good luck,
Dan
Good luck,
Dan
Cattman/SE-R > NISMO on pricing
NISMO > Cattman/SE-R "NISMO" and slightly thicker bar
Good luck,
Dan
Good luck,
Dan
Awesome, thanks Dan. I see that the 2006 SE-R bar is only $75 shipped, that's great. I take it I also need to buy the bushings as well? Do the factory brackets/clamps for the main bushings work? I'd prefer polyurethane, Energy Suspension probably has something but they are only $6 from that site. I appreciate, bookmark added.
When I did the SE-R bar mod, I ordered to sets of proper sized bushings from ES and the rears will work, but the fronts have a retarded bracket that will not accommodate the ES bushings, nor will the brackets that ES provides fit because of the design Nissan has.
!DO NOT, DO NOT, DO NOT, DO NOT! Get Energy suspension bushings for the FRONTS...you can get them for the rears, but NOT for the fronts! I said NOT, right?
CRAP! I forgot how much of a pain it was to get the steering rack out/in on my 96 and how the sway bar was in the way. Doh! I will contemplate this mod but that is a major amount of work for a simple sway bar. Dangit...
Ah, that sux. So just use the traditional rubber bushings. What about our factory brackets? I didn't really see a place to buy the Altima brackets and there is no specific bushing for SE-R's. Just 04-06 etc. Lol, I finally figured out what the oldthread vs showthread address did. Sway Bar upgrade link
When my tech did this, all that he did was drop the subframe and there was no problem with the steering column like Deus had
I could get the bar out of my 96 without dropping the subframe but I do believe the rear motor mount had to come down and the front to rear crossmember thing. That sucked and I bought this car not to have to work on it, lol. Rear bar, intake etc is cake. I do all my own work so my free time is directly related to mod wrenching time. Def don't want to mess up the alignment, hard to get the steering wheel recentered without an alignment.
bbsitum
Sep 11, 2015 04:55 PM
