omg... again
Old Dec 19, 2007 | 08:40 PM
BigPete's Avatar
Incognito
omg... again
Here we go again. Brakes are doing the same thing as before. ABS is engauging again for no reason under slow speed braking. Its also making a horrid noise (sounds like the abs motor) and its knocking away. It took the stealership a week to "fix" the problem. It was fixed for 2 days. Im wondering if I have a leak in a brake line. They fixed it by flushing out a trapped air pocket. So I can only assume air is somehow getting in the lines... 1 1/2 days of driving bliss and BAM all of a sudden its doing it again. Im getting ready to trade her in for an Altima SER I think. I just feel like I might have purchased a lemon.
Old Dec 19, 2007 | 08:50 PM
NmexMAX's Avatar
dot dot dot ...
If you had a leak in the brake line, you would probably end up 2nd best in a competition with a wall (i.e. the brakes would not wor, or be VERY weak) And your brake light would be lit indicating low brake fluid.
Old Dec 19, 2007 | 08:53 PM
BigPete's Avatar
Incognito
Hmm, how else could air be getting into the lines so fast? Im lost as to how this is happening. They bled the brakes and fixed the problem for 1 1/2 days, now its doing it again. What else could create air pockets that fast?
Old Dec 19, 2007 | 08:56 PM
Stardust's Avatar
F---ing Kangaroos
Plain and simple, the stealership lied to you.
Old Dec 19, 2007 | 08:58 PM
BigPete's Avatar
Incognito
ya, but they somehow fixed it... and its broken again lol. This is why they need to hire Mechanics instead of Techs. They cant fix ****.
Old Dec 19, 2007 | 09:00 PM
NmexMAX's Avatar
dot dot dot ...
ABS doesn't engage sporadically due to air in the system. Pull the ABS fuse and see if it will still occur. Do you have a lit ABS light?
Old Dec 19, 2007 | 09:03 PM
BigPete's Avatar
Incognito
trust me its the ABS you can feel and hear it engaging. And no lights/codes. They replaced my entire front end of the car the first time it was in the shop. After they spent hours on the phone with Nissan somehow they got it fixed. They told me they had to bleed the brakes out a certin way and when they did a huge air pocket came out. It sounded like BS to me when I picked her up but I didnt care as it was fixed. Now its doing the same **** again. I have no clue whats making it happen.
Old Dec 19, 2007 | 09:09 PM
NmexMAX's Avatar
dot dot dot ...
Bleed the brakes yourself and see if it goes away. If they are engaging, like you say they are, then something is setting one of your sensors off, albeit a physical/mechanical obstruction or a faulty sensor.
Never believe them, they will lie to you, as stated earlier in this thread.
Old Dec 19, 2007 | 09:12 PM
BigPete's Avatar
Incognito
thanks for the heads up. Ive never bled a brake system before and I dont have the time to do it anyways, work and school both full time. With christmas around the corner ill be lucky if I have time to take a **** in peace lol. I did over hear nissan telling the tech who was working on my car to try and replace all the sensors even though no codes/lights came up. Oh well, tomorrow im dropping her off again. I just hope its fixed before christmas. I have a **** load of driving to do.
Old Dec 20, 2007 | 04:59 AM
Hilbe's Avatar
This is a great idea. Try this. It'll eliminate the ABS.
Old Dec 20, 2007 | 05:04 AM
wagesgt903's Avatar
The ABS also works off of the wheel speed sensors. You could have a problem there as well if its engaging intermittently.
Old Dec 20, 2007 | 06:02 AM
BigPete's Avatar
Incognito
Dropped her off a few minutes ago. Service Adviser mentioned that one of the sensors had some "****" on it when they flushed the brakes last time. So im wondering if when they removed the "****" it fixed the malfunction temporarily. So I told him to replace the sensors and he said "Ok, call you later today with an update". So we shall see what happens.
Old Dec 20, 2007 | 06:03 AM
NmexMAX's Avatar
dot dot dot ...
Actually, that is the only way it works.
Old Dec 20, 2007 | 07:03 AM
xoomer.com's Avatar
I Donate! Why Don't You?
This time when they tell you "huge air packet came out" tell them they should've kept it and show it to you. I wonder what a "huge air packet" looks like when it comes out.
LOL
Old Dec 20, 2007 | 11:51 AM
BigPete's Avatar
Incognito
well. Apparently there was some form of debre on one of the sensors that engage abs. So it was sending an incorrect signal which made the ABS engage. They said they cleand out the debre and its fixed. He also noted that last week when it was there that one of the sensors had some sort of "build up" on it and they cleaned it off. He wasnt sure if bleeding the brakes or cleaning the sensor off was causing it. Apparently now it was definitly the sensor. If not, ill be back in the shop tomorrow or next week lol.
Old Dec 20, 2007 | 01:24 PM
RHMax's Avatar
Newbie just Registered
I thought they REPLACED ALL sensors last time. Do you still have the invoice?
Old Dec 20, 2007 | 02:11 PM
xoomer.com's Avatar
so is it working for now?
Old Dec 20, 2007 | 06:10 PM
NmexMAX's Avatar
dot dot dot ...
Sounds like something I stated earlier, or at least along those lines.
Old Dec 20, 2007 | 07:22 PM
DeusExMaxima's Avatar
U like saying "****" huh, lol
Old Dec 20, 2007 | 07:23 PM
BigPete's Avatar
Incognito
ya you called it. I told them i spoke with someone via the internet who was a mechanic and had alot of knowlege of the car IE you.
thanks again
and they didnt replace any sensors last time, they replace my front axle, wheel bearing assembly, front strut, and some other stuff.
Old Dec 20, 2007 | 09:56 PM
carlosr's Avatar
I wouldnt be suprised if it was debri/loose wheel sensor from the get go cause we had the same problem and knock on wood mine mysteriously has gone away... although I am keeping my fingers crossed. Mine started shortly after I had hit a bad pot hole and recently after all this snow and ice is melting it has gone away before I even had a chance to look into it. I did download nissan procedures for troubleshooting the brakes and abs issues, which you may want to look at as well. Next warm day I am changing my rear pads and I will look at all the sensors.
Old Dec 20, 2007 | 10:15 PM
BigPete's Avatar
Incognito
ya if you could hook me up with the link to it ill check it out bro. and thanks.
Old Dec 20, 2007 | 11:06 PM
carlosr's Avatar
post or pm me your email and I will send you the .pdf files
multiplexor
64
Mar 18, 2007 06:19 PM
blackpaladin67
21
Jun 15, 2005 04:54 PM
ChrisCheezer
Mar 28, 2005 08:34 PM
ChrisCheezer
20
Oct 22, 2002 09:22 PM
