Car Vibrates
Old Dec 20, 2007 | 02:46 PM
pilotguy18's Avatar
Car Vibrates
I have an 04 SE and I have noticed that at 60mph the steering wheel shimmys a little and between 75 and up the whole car shakes a lot like it will fall apart. I had the tires balanced and it helped alot but there is still a slight shimmy/vibration at higher speeds, it is bearable and un-noticeable at points. Has anyone else had this prob?
Old Dec 20, 2007 | 03:55 PM
brio_max's Avatar
Learning English...
http://forums.maxima.org/showthread....ghlight=shimmy
hope this helps
Old Dec 20, 2007 | 07:44 PM
BigPete's Avatar
Incognito
i think 75% of us had/have this problem. Rotors/balance/goodyears
its most likely one of the three. If you just had the rims balanced its either the rotors (warped) or the ****ty RSA's
Old Dec 20, 2007 | 08:09 PM
!PrjctMax!'s Avatar
Take that piece of **** plastic thing under your bumper off too! Many have noticed that once taken off, it helped reducing the shimmy.
The thing that has 5 plastic clips in front and 2? in the rear
Old Dec 20, 2007 | 09:31 PM
JonBlz's Avatar
a.k.a. STuNtMAN
its one or both of ur axles that r bad i had the same problem
Old Dec 20, 2007 | 09:39 PM
NismoMax80's Avatar
SuPeRmOd
of course i got it after i had to remove the plastic engine guard.
but i know it's due to the rotors i am using right now, which were installed after that.
Old Dec 21, 2007 | 04:08 AM
philoforlife's Avatar
Not necessarily...at all.
Joshua
Old Dec 21, 2007 | 07:03 AM
!PrjctMax!'s Avatar
Joshua
May as well replace your steering column at the same time if you're going to do that...
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
JMag90
Aug 25, 2015 09:17 AM
Balkins
Aug 12, 2015 06:39 AM
