Headlight Bulb (non-HID) replacement
Old Dec 24, 2007 | 08:44 AM
jkjk15's Avatar
Hey guys,
My front right headlight just went out and my warranty just passed. The dealer is asking for $90 for the bulb and $50 for install. I'm thinking if I can just put in a 9005 bulb instead of the 9012 bulb. Would that work?
Any help would be appreciated.
Thanks.
Old Dec 24, 2007 | 08:46 AM
redls1's Avatar
MAXIN' ON
Dont think a 9005 bulb will work. Ive read I think it would be a 9006 and tabs need to be trimed. Also said that the bumper needs to be removed. Ive never done it so dont know.
Old Dec 24, 2007 | 09:43 AM
jsmithsole's Avatar
*moderator*
Yes the bumper has to come off (although someone said they watched their mechanic do it with no problem through the engine bay, not sure how) Might as well upgrade a bit while you are at it, you can get silverstars for cheaper (a pair even) and do the work yourself!! It would be almost $100 you can spend on x-mas gifts!!!
Old Dec 26, 2007 | 05:41 PM
GrimMax's Avatar
Where is my shirt?
What is the non-HID OEM part number for these Sylvania bulbs?
Old Dec 26, 2007 | 06:10 PM
redls1's Avatar
MAXIN' ON
Isnt it a 9012?
Old Dec 26, 2007 | 06:39 PM
farzin1's Avatar
Iam putting HID's in my car replacing my exacting bulbs. the guy is asking for 220. Is that good?
Old Dec 26, 2007 | 06:44 PM
redls1's Avatar
MAXIN' ON
I guess it depends on the quality of the kit and what your getting. Have you checked the gd section? There is one going for $160.
Old Dec 26, 2007 | 06:53 PM
BigPete's Avatar
Incognito
ebay, $90 shipped. 9006 bulb type.
Old Dec 27, 2007 | 05:35 PM
GrimMax's Avatar
Where is my shirt?
For NY... that is a great price
Old Dec 27, 2007 | 06:34 PM
jkjk15's Avatar
do you guys know if the 9005 socket is the same as the 9006 socket?..so a 9005 bulb will fit a 9006 socket?
thanks.
Old Apr 29, 2008 | 07:53 PM
jkjk15's Avatar
just an update...I put in 9006 bulbs on the front right...had to cut some of the plastic off of the bulb to make it fit..
but it looks descent..not noticeably less bright than the 9012 on the left...
Old Apr 29, 2008 | 08:15 PM
GrimMax's Avatar
Where is my shirt?
Does anyone know if there is an actual HID kit for the Max?
Also... where can we get some LED bulbs for the license plate? I bought 2 pairs and installed one but they are not as bright; but thats what I get from buying from ebay.
Old Apr 30, 2008 | 06:25 AM
DONS459's Avatar
bulb change
Did you have to take the bumper off?
Old Apr 30, 2008 | 06:32 AM
redls1's Avatar
MAXIN' ON
From what I read move have.
Old May 2, 2008 | 09:52 PM
jkjk15's Avatar
yea, I had to remove the bumper..and I also took the headlight assembly out.
Old May 3, 2008 | 09:28 AM
BigPete's Avatar
Incognito
you didint have to do that.
Removing the wheel well plastic liners gives you direct access to yoru headlights...
thats how i did mine, never touched my bumper or my headlight assembly. Just take the damn plastics off and bam, youll see your headlights.
Old May 3, 2008 | 10:52 AM
Burny's Avatar
Is this the same procedure for the Xenon bulb replacements? Through the wheel well?
Old May 3, 2008 | 02:02 PM
AscendantMax's Avatar
the 9012 HIR's are suppose to be a bit brighter than your standard halogen bulbs. the reflective coating around the 9012 glass reflects UV heat back onto the filament making it burn brighter.
so IMO getting regular 9006's to replace the 9012 is a downgrade. I would just get get a 9006 HID kit from the sponsers here on the forum. I changed mine out last year. I had to drop the front bumper to get to the headlights. It was a relatively easy upgrade.
Old May 3, 2008 | 05:06 PM
po8pimp's Avatar
that price is rediculous. I bought a new pair of 9012's from parts at nissan and it cost $14 for the pair. not sure what they are trying to pull there but I would ask around or look online. the nissan part # is 26296-9B913. I found these sites for you not what I paid but half what you were quoted. http://www.trademotion.com/partlocat...&siteid=214027 and http://www.nissanparts.cc/cart/?pn=26296-9B913+++++ and http://www.courtesyparts.com/betasit...-p-311303.html well that's all I could find for ya at the moment good luck.
Old May 3, 2008 | 10:55 PM
maX5's Avatar
http://cgi.ebay.com/ebaymotors/4-Tos...m110249622646&
Old May 16, 2008 | 05:29 PM
JD4440's Avatar
would you have to drop the bumper cover to just replace to fog lights or can you just remove the wheel well liners?
Old May 19, 2008 | 11:52 PM
i dropped my bumper while doing the change.
Old May 20, 2008 | 05:37 PM
thealliance43's Avatar
hey man... i understand why they want so much because you gotta take off the bumper... but idk i rather just do it myself.... if you want an OEM bulb i have mine... just let me know... good luck bro
Old Jan 16, 2009 | 01:30 PM
blimp's Avatar
have any of you guys done this during this cooold cooold winter???
I was in the process of twisting the bulb out up and to the right to unlock it from the housing and the piece that clips onto the projector itself cracked. ( the piece that clips on from the top and the bottom. I was just thinking that it was too cold that it just snapped.
I tried repairing it with superglue and tape and it was a no go. I went to the dealer to try and order that piece, they said you would have to order the whole headlight. That is bs. But what do you expect from the dealer.
If anyone has gone through this could you throw some help this way? thanks.
Old Jan 16, 2009 | 05:32 PM
silverbeast2004's Avatar
if ur talking about the gray plastic piece that locks the light in, I recently broke mine too. I ordered that piece from the dealership. Cost me about $15. And u don't have to buy the whole headlight the dealers full of ****.
Old Jan 16, 2009 | 06:02 PM
blimp's Avatar
ah gosh wtf. Parts guys at dealers are usually stupid anyway. I'm gonna call another dealer just in case. Do you know what the part is called or have the part number off hand? If you do that would help me out tons. Thanks man. Did you have any tricks putting it on or taking it off? Cuz when i took them off they cracked off like nothing.
Old Jan 16, 2009 | 06:09 PM
yea the dealership guys are retarded lol. the part number that I got on the receipt is 26023 - ZK00A - so ring reta is what its called. When ur putting it on, make sure you clip the bottom on first. and when I was putting in the bulb it broke the two pieces that clip on to the back too. Just be gentle with the piece when putting it on and you should be fine. hope this helped you out!
Old Jan 16, 2009 | 06:13 PM
blimp's Avatar
ya thanks man. I hope the next parts guy i talk to knows what i'm talking about.
Old Jan 16, 2009 | 06:17 PM
no problem! I hope so too! good luck!
Old Jan 23, 2009 | 11:47 AM
hmr1979's Avatar
quick question guys.
One of mine on the passenger side is out. I assume the low beam is the one on the outer part...the bigger circle on the outer side. True?
Also when I went to one store, they said 9006 would work, now I call pep boys and they tell me their computer says H13 is the original one, which translates to 9008 actually....so which one fits?
9008 and 9006 are totally different animal, one has a 90 degree angle different prongs.ect.
When they say cool blue, is that the kind that actually looks blueish in the headlight? I like those, i could care less about how bright it is, but I want them to look blue.
What should I get?
Old Jan 23, 2009 | 06:08 PM
danger300z's Avatar
good info here
Old Feb 11, 2009 | 06:44 PM
SilverBeast's Avatar
Upgrade Help...
04 SE 6spd 18 but no xeons or fog lights there is a switch for fog lights but don't work as far as for the halogens I need xeons. Whats the best solution to upgrade ? maybe the foglights just need bulbs I am not sure? Do the factory xeons look better than aftermarket ? Need Help , Most likely would be doing this myself so any help is greatfull.
Old Feb 11, 2009 | 09:32 PM
jsmithsole's Avatar
*moderator*
Huh? Can you be a bit more clear with your question...
Old Feb 12, 2009 | 12:51 PM
I have the normal halogens bulbs and I wanna upgrade to Hids. What's the best out there to upgrade to hids?? and is this something I can do myself?
and about the foglights there is a option on the light switch to turn them on but they don't?: it might be a simple process of just putting bulbs but I don't know?
martin 04SE
Old Feb 12, 2009 | 01:24 PM
Kof's Avatar
Kof
martin 04SE
I dont know what the best is but i upgraded to DDM tunings hid hit and they are great. It cost me 60 bucks shipped.
http://www.ddmtuning.com/ap55wwesa.html
your fog bulbs are probably just blown. They tend to get hot and blow fast. the same thing happened to me
Old Feb 12, 2009 | 03:32 PM
cool never knew it would be so cheap, is there any fabrication reqiured ? I've heard that you have to take the bumber off just to get to the headlights or foglights?
Do you know of a good repair manual book outthere?
thanx
Old Feb 14, 2009 | 10:38 PM
richierich2100's Avatar
i own a 2007 maxima se. so, my ? is. what is the dammmm part # if i want to change the low beam. when ever i go into a auto store. they always say the bulb is a d2s with HID'S. BUT I DONT HAVE HID'S. ANY ONE KNOW EXACTLY WHAT BULB I NEED FOR SURE? LET ME KNOW SOME THING. THE DEALER GIVES ME THE 8-10 NUMBERED PART#.NOT LIKE AT THE AUTO STORE.
Old Feb 14, 2009 | 11:30 PM
SmokeNismo's Avatar
The Bulb is a 9012. Although a 9006 or 9005 will fit, but none of them are as bright as the 9012.
Old Feb 15, 2009 | 06:15 AM
Burny's Avatar
does anyone know the bulb for the fog light ? this is the third bulb in the cluster with the high and low beam lights. Does the 2004 SL also use a 9012 bulb for the high beam. the low beams are the Xenon bulbs.
Old Feb 15, 2009 | 07:32 AM
hmr1979's Avatar
I will bump this thread because I replaced mine on my own and to be honest when I read several threads, I never got a really clear answer.
So, for low beam a 9006 type bulb will fit, It was a 90 degree angle and it fits perfectly.
If you opt to buy a cheapo $10 sylvania 9006 type bulb, it won't be as bright as the original oem halogen, but not that that visible. If it bothers you, change both out to match, that's what I did. I Bought a two pack for 20 bucks.
there is a sylvania ultra vision package of two for 50 bucks, that one IS as bright.
Another route is the toshiba 9012 bulb online and this will be as bright as your oem as well. Those are 30 something a piece so you're looking at 70bucks + shipping
You do not have to take the bumper. All you have to do is unscrew the FRONT part of the wheel splash guard. DOn't take it all off, it is not necessary. All you have to do is unscrew the front part until you have it enough to bend it out to access the bulb. It's flimsy and plastic so you can do that.
Ok once you do that there is a plastic round cap (looks like a big bottle cap) that is very sensitive and WILL break if you're not careful. I broke mine because the bulb was so hard to twist off that when I used some force, I ended up breaking the lip of the cap...so good luck with that
Even if you take off the wheel splash guard it is a pain in the a$$ to have access to it.
Verdict is ...take it to Pep boys b/c they charge you 17 dollars plus tax to do it. Money welllllll worth it without the risk of breaking that plastic part.
