Idle problem after cleaning?
Old Dec 30, 2007 | 06:47 AM
Patsky's Avatar
I had an EGR malfunction SES light and took the plastic part of the intake and etc. off of my 2004 in order to take the EGR valve off and see if there were any metal debris in it as per the TSB. I found none, so I cleaned it out and put it back on. Thing is, during the removal I also thought it was a good idea to remove the throttle assembly and clean it (the part that bolts to the intake). Well, when it all went together again and I started it up the car idled around 1500 rpm. Since then, after multiple starts, the car will idle anywhere between 1200 and 1600 rpm and while running will spike up to 2000 rpm when I push in the clutch. It also will buck during light partial throttle driving.
My question is: Do I need to reset something after unplugging and taking the assembly off the car or is it something else? How could I reset the idle?
Old Dec 30, 2007 | 08:18 AM
ShiftVQ35
watch everybody is going to say you messes up your throttle body lol
you need to reset the ecu and do the idle re-learn and throttle position re-learn. search for the information on how to do this because i don't have the link but i know the instructions can be found on the technosquare website.
Old Dec 30, 2007 | 09:13 AM
redls1's Avatar
MAXIN' ON
ECU Resetting Procedures
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON.
A stop watch or an analog clock with a second’s needle will be useful.
Operations Procedures
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. fully depress the accelerator pedal (HARD).
2b. fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
Accelerator Pedal Release Position Learning
Operation Procedure
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
Throttle Valve Closed Position Learning
Operation Procedures
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch is “ON”.
3. Turn ignition switch is “OFF” wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning (Throttle Position Learning)
It is better to count the time accurately with a clock.
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Conform that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications
Old Jan 10, 2008 | 03:19 PM
jreilly04's Avatar
all you have to do is acellerator position learning as noted above. but its not really called that. Trottle plate idle learn position. pedal fully off. key on 10 sec off 2 seconds, repeat 3 times.
captchaos
Mar 15, 2016 12:18 PM
Maximan190
Dec 16, 2015 06:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
markevans999
Sep 10, 2015 04:29 PM
nbstriker10
Sep 4, 2015 04:26 PM
