will these fit?
Old Jan 22, 2008 | 11:20 AM
6thGenSmoke's Avatar
will these fit?
i posted in the wheel and tire section but have'nt gotten any response so i will post in here as well. im looking at some rims that are 18 x 9.5 in the rear and i was wondering they will fit without rubbing? i am not lowered but may be plans in the future. i do not know what the offset on them are. thanks in advance
Old Jan 22, 2008 | 11:50 AM
!PrjctMax!'s Avatar
get the offset on them
Old Jan 22, 2008 | 04:40 PM
carlosr's Avatar
With the correct offset they'll fit fine, there's plenty of members running 10 inch wide rear's. Off the top of my head a +40 to +45 offset should be what your looking for.
Old Jan 22, 2008 | 05:12 PM
KCMAXX's Avatar
KC's FINEST
Im running 20x10's in the rear w/+42.
No rub...
Make sure you don't go any wider than a 9" in front though.
Old Jan 22, 2008 | 07:11 PM
the offset on the front are 48 and the rear are 43. from what you guys are saying it sounds like everything should be fine. correct me if i am wrong. thanks
Old Jan 22, 2008 | 07:18 PM
what size tires should i be running with these size?
Old Jan 23, 2008 | 10:29 PM
will the offset be ok and what size tire should i be running?
Old Jan 24, 2008 | 07:03 AM
KCMAXX's Avatar
KC's FINEST
I cant see the front fitting very well without a decent spacer. Its gonna sit way up in there.
Are they local?
Test fit before you buy if possible.
Tirerack.com gives good free advise...
Old Jan 24, 2008 | 04:51 PM
silversteek's Avatar
I just bought some 20's used buy in excellent condition. They are 20X8.5 with a 38mm offset for the front. The rears are 20X9.5 with a 35mm offset. I test fit but the rears are my concern I may need to role the fenders which Im not thrilled about. I couldnt test run them because of weather.
The tires are Toyo T1R's and are flush with the edge of the wheel maybe a scoche narrower. They do look sick on the car and hopefully will be going on in the spring.
Im thinking of maybe going KYB just in the rears, I just want a little extra stiffness in the rear (not pun intended).
Wheels are Stern ST-1 if Im not mistaken, black inside polished lip. I was going to post a thread buy I am not allowed.
Andy
Old Jan 24, 2008 | 04:53 PM
Hey KCmaxx what are the offsets of the rears on your car I think they are 20X10 right?
Andy
Old Jan 24, 2008 | 05:40 PM
KCMAXX's Avatar
KC's FINEST
Andy
No rub...
__________
Old Jan 25, 2008 | 03:39 AM
Thanks for the reply, I sure hope I dont rub .
Old Aug 6, 2008 | 01:06 PM
Kkoa12h's Avatar
Anyone know if a 19 x 9.5 +40 all around will fit? or should I just go for a 19 x 9.5 +40 in the rear and a 19 x 8 +30 in the front?--- 06 Maxima, will be lowered on springs.
TIA
Old Aug 7, 2008 | 12:06 AM
carlosr's Avatar
TIA
holy old threads batman! lol... I think your question was answered by KCmaxx not to go wider then 9.5 in the front, don't wanna rub. your second option should work/look nice.
Old Aug 7, 2008 | 01:52 AM
DEADBOLT's Avatar
Go ahead... try me
KC said no wider than ~~~> 9 <~~~ read up 2-3 posts above mine
If you go 8.5 in the fronts would be better... give it more room for turns, etc. especially when you're dropped. I'm goin to run 22x8.5 in the front so I don't rub...
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
