"NO SAT" message - Sirius Radio
Old Feb 15, 2008 | 05:55 AM
Galto2000's Avatar
I have factory installed Sirius Satellite Radio.
Driving to work this morning, wanted to listen to one of my Sirius Sat Radio presets - when I press a satellite programmed preset or I press the SAT button I get the message "NO SAT". I just checked with Sirius and I am not past my bill due time.
Did my receiver or antenna just die on me?
Old Feb 15, 2008 | 06:01 AM
!PrjctMax!'s Avatar
Are you located in a cold climate? If so then electrical issues are very common.
Once you get the car warmed up and drive for a little bit, it *should* work again. My sister's car has the same issues with dashboard lights, and my car has issues with the CD player not "reading" the disc.
OR, just lightly tap the area for a better connection (the Polski way to do things )
Old Feb 15, 2008 | 06:07 AM
Galto2000's Avatar
This 04 Max has been in the Wash DC area for the last 4 years. It is the first time I have this problem, and this morning it wasn't way as cold as it had been many times before - it was 36F. My commute lasts 45 minutes, my car was plenty warm when I got to work. I restarted my car after I parked (I have had issues before that were gone after a "reset"), but it's a persitent "NO SAT".
Old Feb 15, 2008 | 06:25 AM
Galto2000's Avatar
I probably have to take it in; I found this Nissan Satellite Radio Service Bulletin:
http://www.titantalk.com/forums/atta...chmentid=12525
I think my receiver died according to the diagnostics flow chart.
Old Feb 15, 2008 | 06:46 AM
VigilanteMax's Avatar
You sister's car may be suffering from a combination switch failure. Sounds like a receiver issue.
Old Feb 15, 2008 | 08:09 AM
cefiro80's Avatar
My father in law is on his third unit in his 04
Old Feb 15, 2008 | 08:45 AM
Galto2000's Avatar
Where is the receiver unit located in the 04 max?
Old Feb 15, 2008 | 09:31 AM
!PrjctMax!'s Avatar
99' Civic with 176,xxx miles on it...
Old Feb 15, 2008 | 09:43 AM
MAX2DAMAX's Avatar
trunk, check the antenna cable going in there.
Old Feb 15, 2008 | 10:36 AM
Galto2000's Avatar
The antenna is on the roof of my 04 max, but I can't trace its cable down to the trunk. It's a factory installed Sirius system.
Old Feb 15, 2008 | 11:04 AM
jrpaytonAlpha06's Avatar
I live in Silver Spring, MD and lately my Sirius has been displaying "NO SIGNAL". It's frustrating. The only time I've received the message "NO SAT" is when I didn't have the service.
You need to unclip the upper half of your trunk area where the back speakers rest. You should see the Sirius unit in between your sub and speaker. (Pry the clips carefully b/c they will break if forced out). Check the connections to the unit.
Old Feb 15, 2008 | 11:33 AM
Galto2000's Avatar
I think the Sirius signal must have a low jamming margin; It's probably easily wiped out by other "who knows what" more powerful transmitters. Maybe the Discovery Channel in Silver Spring broadcasting their stuff
If you look at the link I gave earlier in this thread; it is a Satellite Radio Diagnostic Service Bulletin. "NO SAT" is - from what I understand - only when you your entertainment system doesn't "see" the satellite receiver. But I could be wrong.
I am thinking; either my receiver unit has died, or some cable to/from the unit (either power or signal) is broken. I have a persitent "NO SAT"
If you have "NO SAT" intermittently, it could very well be that you have a bad connection of one of the unit cables
Old May 10, 2008 | 05:37 PM
kiltbunny's Avatar
Since i'm new it wont let me start a new thread - but this was the most 'active' sirius radio thread so i'm going to hijack it... sorry
just bought an 05 nissan maxima to replace my totaled scion tc. i had Sirius as a factory installed option on the 07 scion (yeah i know i upgraded alot here...) - there was no outside controller for the scion, just had an antennae in the windshield. i know little/nothing about the maxima and its compatibility with sirius and what comes 'prewired'... it has a SAT button on the dash, but what else do i need now to get it up and running?
gavin68
Sep 18, 2021 12:36 PM
chisam14
Nov 6, 2018 08:56 PM
kmitchel
Oct 30, 2015 10:12 AM
Max Nu-BE
Sep 28, 2015 10:25 AM
