My ac doesnt blow cold...
Old Feb 28, 2008 | 01:53 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
Well i have 41k on my car and my AC has stopped blowing cold now... I put it on 60` and it feels like 75...
Went to the dealer and they told me that im over my 36k warranty etc.. bla bla bla bla bla...
any ideas... ????
Old Feb 28, 2008 | 02:02 PM
ramberg's Avatar
GrandPa
Check the belts and maybe you have to add some R-134a . Hopefully its not the compresser. Here in Brooklyn its heater time. lol
Old Feb 28, 2008 | 02:09 PM
2k4MaximaSE's Avatar
any ideas... ????
I have the same issue with mine about ever 3-4 months. Mine though is known as to why I'm having that problem. It's because about 3 years ago when I was in an accident the bodyshop in which worked on my car forgot to switch out an A/C hose. The hose has a small puncture so the freeon tends to drain a bit quicker than usual. I'm too lazy to go to the dealership to have the hose changed (it's just $100), so about every 3-4 months I buy some R-134A, and fill it up. About 10 minutes or so and you're back to some cold A/C. Maybe one day I'll decide to finally take it in for the dealership to get that properly repaired, but until than this works, lol.
Old Feb 28, 2008 | 03:28 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
hmmm .... well thanks for the imput ... ill go try to find some r-134a fluid... try that and go from there..
any other comments guys?
Old Feb 28, 2008 | 04:06 PM
If you're really concerned about it, I would seriously suggest going to some local place where they specialize in A/C unless you want to get ripped off by the dealership.
Old Feb 28, 2008 | 04:16 PM
whitem1ke88's Avatar
I have teh same issue, been blowin cold since I filled up with r134a until now, now it's.. ****.. once a month? I need to have it checked out
Old Feb 28, 2008 | 04:27 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
can u get the r134a at like autozone and kragen etc...
and kinda a newb question... but where do pore the r134a in... where is the chamber located
Old Feb 28, 2008 | 04:33 PM
Longhorn101's Avatar
Many people have had the low-pressure hose with early defects near the metal crimps. My car had both a bad hose at ~40k and then a bad o-ring on the high-side at 60k miles. Talk about some cheap-**** parts...... Nissan must have sourced parts from Borat.
Old Feb 28, 2008 | 05:21 PM
....you could get that in any auto parts store. I use one called Artic Freeze (I believe, I know it has the word Freeze in it though). It also brings a hose in which tells you when your A/C is filled up to the recommended level. The compartment where you put the freeon is located by where the windshield wiper fluid is located. When you open your hood and locate it go up a bit, and a bit towards the right. You'll see a metal bar of sorts with a black "twist off" cap. It's right there. All you do is insert the nozzle piece of the R-134 fluid and pump away. It'll take about 3 minutes or so for you to feel that metal tube very cold. It is imperative that you have that the car on with the A/C on full blast otherwise I guess it might damage your system (maybe someone more knowledgeable can shed light as to why it has to be on full blast).
Old Feb 28, 2008 | 05:53 PM
redls1's Avatar
MAXIN' ON
Ive seen the stuff at walmart,target and im sure autozone. Seen it in a blue bottle with a gauge to tell how much is in there/you system needs.
Old Feb 28, 2008 | 06:50 PM
Outlawd's Avatar
Im sure its the hose...I got my replaced under warranty. I was about at 40,000 miles when I got it replaced
Old Feb 28, 2008 | 08:56 PM
oldngivout's Avatar
Willing to learn
Best advice to date.
Old Feb 28, 2008 | 09:05 PM
NismoMax80's Avatar
SuPeRmOd
you check the in-cabin filter?
Old Feb 28, 2008 | 09:23 PM
farzin1's Avatar
its winter anyway. dont worry about the ac. lol. at least your heat works
Old Feb 29, 2008 | 09:15 AM
ap53's Avatar
The best thing to do is go to any local shop and fix the leak.
I have been in the AC business for awhile and people really crack me up with this just add some gas.
To start with, normal AC system should never loose any gas, period.
Now if you have leak and pressure in the AC system drops, guess what ? moisture from the air will enter you system and by adding 134a in to your car that has moisture in the system it will make it worst it’s just matter of time.
To have permanent fix you have to fix the leak, then vacuum the system to 500 microns or less, check for leaks and only then add the 134a.
Old Feb 29, 2008 | 09:34 AM
...is that the case? After reading this you've convinced me to go out and get that hose changed,
Had I known earlier
Old Feb 29, 2008 | 10:26 AM
ap53's Avatar
Had I known earlier
Laugh all you want, adding 134a in to your car every 3 months sound like permanent solution, not mention that you have to be licensed to work with any refrigerant gas and if you ever get caught by EPA you will be surprised how much you will have to pay.
Not mention releasing refrigerant in to the atmosphere it really helps ozone layers it really does.
Old Feb 29, 2008 | 10:28 AM
EPA??? What's that?
....and the little "laugh" icon is not because I think it's a funny issue, on the contrary. I wish I had known this long ago, it just seemed a very quick fix to me, but based on what you indicated, it's far from that in the long run.
Old Feb 29, 2008 | 02:49 PM
ap53's Avatar
EPA = Environmental protection agency
I'm glad I could help.
Old Mar 1, 2008 | 01:25 AM
jsmithsole's Avatar
*moderator*
Mine is out as well, just waiting to take it into the dealer. Love that extended warranty!!!
Old Mar 1, 2008 | 03:00 AM
ramberg's Avatar
GrandPa
I don't think he needs the heater where he lives.
Old Mar 1, 2008 | 06:02 AM
redls1's Avatar
MAXIN' ON
Although I agree about the soulution why do they sell all the diy cans or refrigerant if you need a liscense?
Old Mar 1, 2008 | 06:26 AM
Never heard of the EPA before. Is this an agency only established in states where you have to pass emission tests? If so, that explains it. Here in Florida all you do is get your insurance, go to the tag agency and get your new registration and that's that.
Old Mar 1, 2008 | 07:09 AM
NismoMax80's Avatar
SuPeRmOd
EPA is extremely active in Florida. You have the Everglades.
Old Mar 1, 2008 | 08:35 AM
ap53's Avatar
You have three types of refrigerants:
CFC = Chlorofluorocarbon, commonly used CFC are R-11, R-12.
HCFC = hydrochlorofluorocarbons, commonly used HCFC is R-22 this is typically used for your house cooling.
HFC = HydroFluoroCarbon, commonly used HFC is R134a. The reason why you can buy 134a refrigerant is because the Ozone depletion potential is Zero and HFC will NOT damage the ozone in the stratosphere, How ever you still need to be licensed to do the work.
Old Mar 1, 2008 | 09:00 AM
ap53's Avatar
To answer your question why EPA is involved with the refrigeration and cooling industry is because the CFC and HCFC refrigerants have ability to deplete the ozone layer.
Also there is health effect and Global warming evidence. Such as:
Skin cancer
Cataracts can more easily occur
Timber growth is reduced
Crop yields are lowered
Marine life and food chains are impaired
Immunity against disease is reduced and the list goes on and on.
Any way I’m done preaching.
Old Mar 1, 2008 | 10:32 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
i went to the dealership and they told me that a/c and all its components WERE not covered under my "joke" of a warranty...
However, I then went to AutoZone and purchased the R134a Fluid....14 mins later, my a/c blows VERy cold...
I am still going to check out the hoses myself on sunday, but i feel very confident that i have fixed the problem..... FOR NOW...
Old Mar 1, 2008 | 10:33 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
Not VERY recently, but yes i have.... It wasnt VERY VERY dirty... but it could be changed anyday... Maybe ill do that also...
Old Mar 1, 2008 | 10:38 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
I live in californa where we dont really have a winter... I lived in Northern Arizona and Norther Idaho ... So any place where it doesnt snow or get below 45's to ME you cant really says its winter LOL...I has been between 67-73 for the last 3 weeks... a few days of rain... but 9/10 days are 70+... I use my A/C very often
Old Mar 1, 2008 | 10:40 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
I have used it twice... and one time when i was in Vegas LOL
Old Mar 1, 2008 | 10:43 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
Skin cancer
You sound like a very intelligent person, however... you lost my backing when you started talking about GLOBAL WARMING... BUT this thread is not about the EPA... or crop yields ... so ill try to stay on topic..
Thanks to everyone for ALL the advice.. i willl for sure look into getting the hoses checked out ... Ill keep everyone posted
BTW... that r134 crap is Fawkin Expensive LOL... If i had to do this once a month i would be very upset.. LOL 32.08 for a can
Old Mar 1, 2008 | 10:53 AM
cefiro80's Avatar
Just have the hose replaced it will save you money in the long run.
Old Apr 21, 2008 | 04:08 PM
TechMansoor's Avatar
50 dolllar deductable for an already purchased silver 75k warrant..i just dont even understand how this is possibly fair.... i too had this problem..simpliest thing to do is have the hose replaced..but God!!!! I'm scared to know if something else breaks...ill probably have a 2,000 dollar deductable!!
Peace everyone.. Our car is still awesome!
Old Apr 25, 2008 | 01:59 PM
saraara's Avatar
After cold winter recently I had to turn A/C ON and.....yes you guessed it right, it wont blow cold air but warm air. Just bought r-134a can from Autozone for $17 and A/C back on track in just 5 minutes. I am sure it's about time to change hose but let's see how far I can go with r-134a can.
Old Jul 3, 2008 | 05:59 PM
djrav9's Avatar
saraara or anyone else for that matter- how long did the r134a can recharge last you? because i got my AC checked out and they couldn't find any apparent leaks; however, i have the same not-so-cold AC problem.
Old Jul 4, 2008 | 12:33 PM
redls1's Avatar
MAXIN' ON
Its a closed system you shouldnt have to refill. Have them re check for a leak. If thats not it check the condenser and tightness of the ac belt. Could it be that its cold and just the weather is hotter? Check the temp in the vent and see if its appropriate.
Old Jul 4, 2008 | 05:05 PM
djrav9's Avatar
I just put in the refrigerant and it seems to have worked. Blew very cold and worked great.
... let's see how long it lasts. Thanks for the help everyone.
Old Jul 21, 2008 | 12:29 PM
fornboglod's Avatar
Make sure your car isnt overheating due to the radiator fans not coming on, the first symptom i got when the car was overheating was the a/c cutting out due to high pressure, i thought the compressor was failing but then noticed the temp guage was in the red, there is no warning light for overheat on these cars, just the guage, and they overheat real quick when the radiator fans dont run and you are at idle.
Nissan service tech told me he is seeing a lot of defective fan assemblies come in, so be aware of this issue, if the fans are defective alot of engines are going to get ruined.
Old Jul 21, 2008 | 12:31 PM
KC2010's Avatar
My brother was stuck in his Max for 6 hours when Hurricane Rita came thru Houston. This is exactly what happened to him. Be careful.
Old Jul 21, 2008 | 12:37 PM
fornboglod's Avatar
I think there is a quality control problem with the fan motors, when they burn up the wiring harness they are attached to that is serious. Nissan hasnt acknowledged it but the techs know about it, and it boils down to an inferior part that is crucial to protect the engine.
For all you guys with custom work, or people out of warranty, consider buying a quality aftermarket electric fan. For people still in warranty, ***** about it now and get new fan motors installed while in warranty. This is BS if its true it is a common problem.
