Dyno Results!!
Old Mar 8, 2008 | 01:48 PM
GrimMax's Avatar
Where is my shirt?
Dyno Results!!
Well I finally got the Max on a Dyno today thanks to Speedworld in Baldwin New York, and results were fairly decent. Here is the list of mods I have in conjunction w/ results:
AEM CAI, Cattman Y-Pipe, Greddy SP II, Kinetix, NWP Spacers, & UDP
Big thanks to Aaron at NWP for the talk about what to expect.
I got 3 Pulls done and unfortunately I dont have a scanner because I am too lazy. But I will scan once I get back to work and post the actual print out. Humidity was at 69% average for each run and temp average was 58 degrees.
1st Run: Max Power: 236.59 Max TQ: 254.06
2nd Run: Max Power: 246.32 Max TQ: 265.25
3rd Run: Max Power: 238.37 Max TQ: 229.48
Are the numbers fairly good guys?
Hope you guys enjoy the video and pics below.
http://s113.photobucket.com/albums/n...nt=1stDyno.flv
Old Mar 8, 2008 | 01:57 PM
Hilbe's Avatar
Seem close to mine. I ran about 239 whp before I put the exhaust and UDP on...
Old Mar 8, 2008 | 02:04 PM
NmexMAX's Avatar
dot dot dot ...
Strong values, did you get the actual files? What was the CF?
Old Mar 8, 2008 | 02:09 PM
GrimMax's Avatar
Where is my shirt?
CF states uncorrected and smoothing said 5
What does that mean???
Old Mar 8, 2008 | 03:11 PM
GrimMax's Avatar
Where is my shirt?
Also... How much HP is at the drivetrain now?
Old Mar 8, 2008 | 04:30 PM
wayne6213's Avatar
i am guessing about 300 at the crank.
calculated using 25% power loss...
also, i THINK you would have a few extra horses at the wheel if u had a lighter rims on
Old Mar 8, 2008 | 04:46 PM
Apollos2's Avatar
Hey those are good numbers! Now you are ready for the track.
Old Mar 8, 2008 | 05:22 PM
NmexMAX's Avatar
dot dot dot ...
LW wheels will help. Also, to the OP, I'm guessing your tq #'s are spikes, because that is just too much of a contrast. Correction factor takes into account atmospheric conditions and is corrected as so. Since it was 58 degrees out, I'm guessing your corrected values a re a bit lower.
Old Mar 8, 2008 | 06:11 PM
larsim's Avatar
Wink. I'll do the rest.
Sorry to be the of the bunch - but how many horses did you gain after all?
Old Mar 8, 2008 | 06:14 PM
!PrjctMax!'s Avatar
Stock is 200 or 205whp, don't remember which one.
...hmmm I should be in for a great treat then considering that I dynoed 225whp (give or take; I did it a long time ago) with only Fujita and TS
Old Mar 8, 2008 | 06:53 PM
GrimMax's Avatar
Where is my shirt?
Thats awesome!!
Yeah those rims are super heavy and I really want to get light weight racing ones in chrome but you cant beat $900 for a set of 20's. lol
Old Mar 8, 2008 | 06:55 PM
GrimMax's Avatar
Where is my shirt?
If I am doing the math right... 246.32 x .25 gave me 61.58 so I added that to the 246.32... so I think I am around 307HP now. But I suck at math...
Old Mar 8, 2008 | 06:56 PM
GrimMax's Avatar
Where is my shirt?
WOW!! So the TS gave tons of power huh!? That is want I want to do next since the headers wont be out for a minute.
Old Mar 8, 2008 | 07:00 PM
GrimMax's Avatar
Where is my shirt?
Thanks bro!!
I want to get her on the track but nothing out here on Long Island
Old Mar 8, 2008 | 07:53 PM
VigilanteMax's Avatar
That is quite impressive with those bolt ons and no change in headers or AFR. not to burst your bubble, but when was the last time his dyno was calibrated?
Old Mar 8, 2008 | 08:42 PM
NmexMAX's Avatar
dot dot dot ...
Dyno's don't need to be 'calibrated', it's the atmospheric conditions which 'calibrate' them.
Old Mar 8, 2008 | 09:03 PM
SmokeNismo's Avatar
why are the 2nd run results so much higher than the 1st and 3rd? anyone care to explain?
Old Mar 8, 2008 | 09:06 PM
!PrjctMax!'s Avatar
2nd higher because let off gas lower/higher RPM?
3rd lower because of engine heat and not long enough cool down between runs
Old Mar 8, 2008 | 09:07 PM
NiZMo1o1's Avatar
nice #s , hopefully I will be taking mines in soon
Old Mar 8, 2008 | 09:11 PM
!PrjctMax!'s Avatar
With that slightly over-sized snail...
Old Mar 8, 2008 | 09:46 PM
eK9aT10pSi's Avatar
^^^^^^^^ i wanna see pix!!! lol!
Old Mar 9, 2008 | 12:09 AM
xorbitman's Avatar
Very nice sound (Video) and great numbers too! Quick question though....Did you have to add a computer or did you reprogram your ECU after the Y-pipe? ....As changing this usually means you are running lean....
Old Mar 9, 2008 | 06:04 AM
Apollos2's Avatar
Originally Posted by GrimMax
Thanks bro!!
No track out there anywhere Bummer, you ought to poke around see if you can find one that's not to far away and get it out there. You would have a blast. You have some nice mods, it's a shame not to test them out on the track. BTW, I run mine just the way you see, chrome wheels and all. Do they make lightweight chrome wheels?
Old Mar 9, 2008 | 08:40 AM
jinyumax's Avatar
Very nice numbers and on the pics and video. Just keep on lookin for that next mod to squeeze out a little more power cant wait to get mine on a dyno in june when i go back to florida.
Old Mar 9, 2008 | 08:46 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Those are decent numbers, imaging if you slap on headers next!!! Great job
Old Mar 9, 2008 | 08:47 AM
NYPD-Arnold's Avatar
Z
Drivetrain loss on a 2WD car is typically 15-17%. You've got about 285HP at the crank, and 310lbs of TQ.
Old Mar 9, 2008 | 08:54 AM
chernmax's Avatar
True, I normally factor in 15-20% loss for an Auto max...
Old Mar 9, 2008 | 09:04 AM
niceguy's Avatar
Don't know about the newer 5spd autos but the older 4spd units lose about 22-23% from my experience...
Old Mar 9, 2008 | 09:28 AM
!PrjctMax!'s Avatar
Different cars respond to mods differently than others.
Old Mar 9, 2008 | 11:03 AM
GrimMax's Avatar
Where is my shirt?
[QUOTE=xorbitman;6289267]Very nice sound (Video) and great numbers too! Quick question though....Did you have to add a computer or did you reprogram your ECU after the Y-pipe? ....As changing this usually means you are running lean....
Thanks bro!!
No reprogram yet on the ECU or any of that.
Old Mar 9, 2008 | 11:06 AM
GrimMax's Avatar
Where is my shirt?
Thanks bro!!
Yeah I cant wait to get her back on the dyno. Its tons of fun just watching it!! I was also happy to be the 3rd 6th Gen that the shop I went to put on the dyno. So that was cool..
Old Mar 9, 2008 | 11:07 AM
GrimMax's Avatar
Where is my shirt?
Thanks Brother!!
Yeah the headers will be awesome!!
But what do you think about holding off the the TS ECU until headers are installed first??
Old Mar 9, 2008 | 02:43 PM
chernmax's Avatar
Thanks Brother!!
Absolutely, but in my opinion, unless you plan of driving above 145mph+ (removes speed limiter), you can achieve better performance gains with an APEXi piggy back computer and every time you add a mod you have the capability to dyno tune it correctly to work with everything else.
Old Mar 9, 2008 | 02:45 PM
!PrjctMax!'s Avatar
True...BUT, why not just go with UTEC that can do everything the TS does except for adjusting the maps?
Old Mar 9, 2008 | 02:53 PM
chernmax's Avatar
I haven't read any detailed info on anyone who's installed a UTEC on a 6th Gen Maxima other than they have been known to fry our coil packs. So may work great but I don't have any expertise working with to make an educated choice. They also tend to lean more toward the pricey side...
Old Mar 9, 2008 | 03:44 PM
!PrjctMax!'s Avatar
nietsche (spelling)
He is the only 6th genner with a UTEC and he has only positive results from it...so
I think you are thinking of the Emanage Ultimate that is frying coil-packs, NOT the UTEC.
Can get one used for $600 on www.my350z.com
Once I have enough mods to knock off my AFR , then I will most likely get a UTEC and post much more about it. Osiris and Cobb seem to not care about the Maximas and a reflash by TS seems to be the easy way, but I'd like to experiment with the UTEC.
Old Mar 9, 2008 | 05:16 PM
GrimMax's Avatar
Where is my shirt?
Is this what you are talking about?
http://www.erzperformance.com/product_p/401-x903.htm
Old Mar 9, 2008 | 05:36 PM
chernmax's Avatar
Yes but that's pricey considering I'm selling mine for $200.00 and it's the exact same one!!!
Old Mar 9, 2008 | 08:09 PM
NmexMAX's Avatar
dot dot dot ...
Have him email you the actual run files.
Old Mar 10, 2008 | 06:44 AM
anm6's Avatar
Good numbers man. Another auto putting out some good numbers good job. Now some headers and tune.
