AC Blower not working
Old Mar 25, 2008 | 07:09 PM
foreeyed's Avatar
My AC blower is not engaging when I turn on the car. It was working fine yesterday, has anyone had this problem and know how to fix it?
Thank you,
Old Mar 26, 2008 | 01:22 AM
jsmithsole's Avatar
*moderator*
Thank you,
Mine did this and was fixed under warranty. Not sure what they did now...
Old Mar 26, 2008 | 07:22 PM
esmooth's Avatar
By saying that it's not engaging, I assume that you mean that no air is coming out of the vents no matter what setting the fan is on. Or is it simply the air that is coming out isn't cold? If you meant the latter, the issue is probably your low pressure vacuum hose loose or off.
Old Mar 27, 2008 | 05:59 AM
foreeyed's Avatar
No matter the setting, there isn't any air coming out of the vents.
"By saying that it's not engaging, I assume that you mean that no air is coming out of the vents no matter what setting the fan is on. Or is it simply the air that is coming out isn't cold? If you meant the latter, the issue is probably your low pressure vacuum hose loose or off."
Old Mar 27, 2008 | 08:21 AM
KCMAXX's Avatar
KC's FINEST
Did you check the fuse box?
Old Mar 28, 2008 | 06:55 AM
foreeyed's Avatar
checked the fuses last night and they where not damaged
Old Mar 30, 2008 | 05:20 PM
ap53's Avatar
Every AC has something called low pressure cut of switch, if for any reason your 134-a gas is below operating pressure the compressor will not come on.
This is to protect you Ac system, the lower the pressure gets the colder air will and then everything will freeze.
Old Mar 30, 2008 | 09:34 PM
wildman04's Avatar
MAXXED OUT Member!
I had a 92 max and a 99 quest van and both gave me the same problem. There is a heating element mounted to a circuit board inside the fan housing under the dash and it has a circuit built into it that will shut down the blower. It happened on both of the vehicles and I don't know if they are still made the same but you might want to check it out.
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
