Problems help!!!
Old Apr 4, 2008 | 03:51 PM
04_Maxima
Problems help!!!
I used the search but nothing came up for this problem.When i was driving the "slip,tdc,brake,abs lights" came on.turned off the car then on and they went away.then put it in drive and they come back on!!the ses light doesnt come on got the computer scanned and no codes come up!! Help!!!
-04 maxima sl v6
Old Apr 4, 2008 | 06:49 PM
KCMAXX's Avatar
KC's FINEST
Mine has done the same thing a couple of times...
It also went off after a restart.
Check your brake fluid.
Old Apr 7, 2008 | 03:11 AM
04_Maxima
brake fluids good.also check the pads and rotors and there fine.when i go to make a turn and brake at the same time the front brakes make noise.any clue?undid my battery for 2 hours and the light came rite back on!
Old Apr 7, 2008 | 05:04 AM
Lovemycar's Avatar
could be a bad alt
Old Apr 7, 2008 | 05:10 PM
04_Maxima
Originally Posted by Lovemycar
could be a bad alt
would that make those lights come on?
Old Apr 7, 2008 | 05:44 PM
carlosr's Avatar
could also be the notorious dirty hub/rear abs sensors
Old Apr 7, 2008 | 07:19 PM
04BlackMaxx's Avatar
Hope not! what a ***** when you are out of warrenty.
Old Apr 7, 2008 | 07:21 PM
04_Maxima
hard to do?how much would it be to repair>
Old Apr 8, 2008 | 05:52 AM
carlosr's Avatar
I did it myself since I have no warranty and don't trust places with my ride. Really not a difficult task just takes some time and elbow grease. Basically you remove right rear wheel, abs sensor, brake rotor, hub, clean and reinstall. Look up TSB NTB07-016b or go to http://x.nissanhelp.com/forums/Knowl...p=10&keyid=184
for full tsb. I personally just cleaned everything and put it all back together with zero cost to me and hasn't been issue since. You can always replace Abs sensor later if it actually a problem (it one bolt on back side of hub). There's a bunch of threads on this if you think this may be your issue or best just look at tsb. You may have to register to view it, but its free and very helpful.
Old Apr 8, 2008 | 03:00 PM
04_Maxima
thanks alot sounds pretty easy to me..iam a do it yourselfer and have no warranty.so if this is my issue thanks wat ill do thanks!
Old Apr 8, 2008 | 06:10 PM
carlosr's Avatar
No prob man its really not that hard to do, the TSB makes doing the job pretty straight fwd. Some of the stuff a little tough to get off cause they been on there so long and rusted (rubber mallet or hammer and block of wood helps here) Took me about 2-3 hours, just need a ratchet set with a breaker bar (or longer pipe to fit over ratchet for leverage, ghetto style) and some other helpful advise is there is 1-2 bolts that you may need to use a jack and or jack stand to manipulate the suspension up or down to get at.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
