car idle bad it sounds like its goin to turn off help
Old Apr 12, 2008 | 10:07 PM
drzcrazychulo4u's Avatar
ok hey guys to start i have an 06 nissan max wiff nismo cold air intake and magnaflow exhust now once in a while my car wen i turn it on if like jerks the idle like its about to turn off now there is no ses light and nuttin else is wrong so what can it be
Old Apr 12, 2008 | 10:50 PM
Drockb418's Avatar
did it start after the intake .... if so its ur maf try to reset ur car by taking the battery off for a bit
Old Apr 13, 2008 | 01:40 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
How many miles on the car? Have you used any additives in your gas? A rough idol can be attributed to MAF problem, spark plugs, coil packs, vacuum leaks, a clogged EGR valve or a blown gasket on your intake Manifold. Our cars don't have fuel filters (04+) anymore so you can eliminate that.
Last, you may have also gotten a batch of bad gas and some good premium gas, fuel injector cleaner and punching that b!tch wide open on the road may help...
Old Apr 13, 2008 | 08:42 AM
04MAX_ILLIN's Avatar
I thought our cars had a fuel filter..internal in the fuel tank, no?
Old Apr 13, 2008 | 08:47 AM
redls1's Avatar
MAXIN' ON
I thought it was in the fuel tank but not replaceable ?
Old Apr 13, 2008 | 12:08 PM
GrimMax's Avatar
Where is my shirt?
I have also had the same issue but mine was the connection wires that connect to the IAT. My Max would start and Idle then almost turn off and regain.
As if the connection is 50/50.
Do you have the SES Light? If so... did you get a reading?
Old Apr 13, 2008 | 01:43 PM
po8pimp's Avatar
check the wiring to the MAF sensor, and all O2 sensors. If all is good get carb cleaner from the store and with car running spray around all the connections for your intake. If it gets sucked in which you will see happen then you have a leak. any leak going in after the MAF will cause this problem. be sure not to spray any electrical connections. I recommend also getting LUCAS fuel system cleaner/ tuneup in a bottle and adding it to the gas tank. Bad gas as previously stated can cause this too. If these don't seem to be the problem take the car back to the muffler shop that did the work and have them check for leaks before the O2 sensors. good luck
Old Apr 13, 2008 | 02:32 PM
larsim's Avatar
Wink. I'll do the rest.
^^^^ pretty much covers what you need to look for...
Old Apr 14, 2008 | 03:42 AM
chernmax's Avatar
Correct, but it's more a series of screens and like I stated, doesn't need to be replaced anymore.
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
doobadoo
Aug 15, 2015 06:43 PM
AT978
Aug 15, 2015 06:39 PM
Maxboy23
Aug 11, 2015 11:59 AM
