Slight Ticking In my 04 Max
Old May 11, 2008 | 04:58 AM
04_Maxima
Ok,i have an 04 max with the 3.5,it has a slight tick coming from the engine.drives fine but when you kinda get on it some smoke comes out the exhaust any ideas?
-76k on it
Old May 11, 2008 | 08:06 AM
Shoey1's Avatar
do you drive it "sportingly?" (read- beat the pi ss out of it). im thinking ticking is from valve guides and smoke is oil burn. is it black, blue, or white smoke?
Old May 11, 2008 | 11:14 AM
04_Maxima
no i dont beat the **** out of it.when it smokes it black,maybe the cat cause it smells!
Old May 11, 2008 | 11:28 AM
Shoey1's Avatar
black smoke means its running rich, blue smoke is oil, and white is coolant...for the most part.....if your burning ALOT of oil then you can get white smoke but your cat will probably be plugged before that and you will be getting a service engine soon light because your O2 sensors will be fouled by all the oil.
Old May 11, 2008 | 11:40 AM
STARR's Avatar
How many miles are on it, what oil do you run
Old May 11, 2008 | 12:40 PM
!PrjctMax!'s Avatar
Reading > you
Originally Posted by 04_Maxima
-76k on it
Old May 11, 2008 | 12:43 PM
STARR's Avatar
doh
Old May 11, 2008 | 03:14 PM
04_Maxima
haha..it only smoke when i get on it no other time.its only alittle black smoke that comes out and the that awsome smell afterwards.also i have posted a thread b4 about my "vdc,brake,abs,slip" lights being on but noone knew wat it was.got my computer ran but nothing came up!
Old May 11, 2008 | 05:20 PM
redls1's Avatar
MAXIN' ON
Not sure about the tick but couldnt o2 sensors starting to go cause the smoke? Well obviously others things too. Could all of you lights being light be attributed to a bad ground?
Old May 11, 2008 | 06:50 PM
bcook8187's Avatar
My 04 does the exact same thing as you describe. If its not using oil noticably on the dipstick, I would contribute the smoke only when you get on it to moisture in the exhaust system finding its way out especially if it is white like mine and does it only the fist few times I run it hard. Rotten egg smell the first few times as well. The exhaust is very restrictive with lots of places to collect moisture unless you are blowing it out all the time. It makes a clicking noise as well, but always has even though it is louder now than when new. Thought it may be the injectors, but do these have adjustable valves? If anyone knows please let me know! Thanks!
Old May 11, 2008 | 09:32 PM
Shoey1's Avatar
black smoke isnt condensation...have a technician do a compression test and leakdown test to see if it hold pressure and dosnt leak past rings or valve guides...you could pull spark plugs and if it has a black oily residue then the oil is being burnt
Old May 12, 2008 | 05:26 PM
05AltimaSER's Avatar
the tick i say is the altenator belt tensioner pulley. my 05 Alti SER had that noise and that fixxed it
lux97Max
Sep 28, 2015 11:18 PM
05RLS2
Sep 27, 2015 09:24 PM
msellas
Sep 23, 2015 09:16 PM
RWCreative
Sep 21, 2015 11:01 AM
ColdCananda
Sep 20, 2015 10:45 PM
