Where is the PCV valve on this car?
Old May 14, 2008 | 05:09 PM
Rich96's Avatar
And why the mother F is it $16?
Just going to to change it out for the first time on this car......don't know where it is.......and don't have a service manual.
Old May 14, 2008 | 05:44 PM
redls1's Avatar
MAXIN' ON
http://www.phatg20.net/index.php?opt...nc=select&id=1
Heres the service manual to download. I thought there was a port in the front valve cover and one in the back but not sure.
Old May 14, 2008 | 07:09 PM
Rich96's Avatar
Ok got the manual, but it doesn't show exactly where it is.......anybody know?
Old May 15, 2008 | 03:53 AM
JRoX85's Avatar
newbie
it is on the back side of the motor by the cias assembly
Old May 15, 2008 | 05:35 AM
Rich96's Avatar
Forgive my obvious ignorance.
What and where is a cias assembly?
Is it on the driver's or passenger side?
Is it near the top of the valve cover?
Old May 15, 2008 | 06:24 AM
NmexMAX's Avatar
dot dot dot ...
I'm curious about tht too.
But seriously, read that FSM better, the instructions are as plain as day.
Old May 15, 2008 | 07:25 AM
myer84's Avatar
When is it recommended to replace the PCV valve and what are the benefits?
Old May 15, 2008 | 11:08 AM
Rich96's Avatar
Thanks man! Exactly what I needed!
Yeah the FSM probably had it, but there was not a clear picture when I looked up "PCV valve" - only replacement/testing instructions.
I'm used to the cheap Chilton/Haynes where they have diagrams for idiots.
Old May 15, 2008 | 11:52 AM
whitem1ke88's Avatar
Think he meant VIAS not CIAS, btw.
Old May 15, 2008 | 01:07 PM
NmexMAX's Avatar
dot dot dot ...
Yeah, the FSM assumes we know what each part looks like exploded, and know EXACTLY where it is on the car, so i see your point.
NO WAY!!! GET OUT!!!
Old May 15, 2008 | 01:14 PM
Terrentius's Avatar
Thanks for pointing out its locations. I was wondering where the heck it was as well :>)
Old May 15, 2008 | 01:15 PM
NmexMAX's Avatar
dot dot dot ...
Things may be slightly different being that the pic is from a 5th gen, but, I've seen it on an 04 Maxima (A34) and it is in the same place, but there are more plastic covers, etc.
Old May 15, 2008 | 02:06 PM
JRoX85's Avatar
newbie
yup that is what I ment it is located directly behind the intake manifold on mine. top rear section of manifold
Old May 15, 2008 | 02:07 PM
JRoX85's Avatar
newbie
thanks for the pik rich I was gonna go take one from my car and show him but you beat me to it
Old May 15, 2008 | 02:15 PM
NmexMAX's Avatar
dot dot dot ...
Actually, I posted the pic in this thread, rich quoted it, and Puppetmaster originally posted it elsewhere.
Old May 15, 2008 | 04:32 PM
JRoX85's Avatar
newbie
well kudos to you then it was really early and I was runnin out the door for work LOL
Old May 15, 2008 | 04:58 PM
Rich96's Avatar
That pic is from a 5th gen? Are you sure? On the 5th gen I recall it being on the driver's side.
Old May 15, 2008 | 06:41 PM
larsim's Avatar
Wink. I'll do the rest.
what is a pcv valve?
j/k lol
Old May 16, 2008 | 09:58 AM
NmexMAX's Avatar
dot dot dot ...
Your engine cover is black, ours is gray.... Oh yeah, I also have a 5th gen too.
Old May 22, 2008 | 10:40 AM
Rich96's Avatar
Sorry for my ignorance.......I must be blind......but I'm not seeing the same thing on my car.
http://render-2.snapfish.com/render2.../of=50,590,442
Old May 22, 2008 | 12:40 PM
NmexMAX's Avatar
dot dot dot ...
it be easier if you remove the engine cover.
Old May 26, 2008 | 09:03 PM
Rich96's Avatar
Just replace it.
Man its a PITA to get to. And getting a socket on it to remove it is even worst. My 5th gen was WAY easier!
Old May 28, 2008 | 06:47 PM
JRoX85's Avatar
newbie
I just ran my catch can to it and man PITA, I just used my arm and pulled the old hose off by hand total install time for catch can is about 20-30min
Old May 28, 2008 | 09:00 PM
Rich96's Avatar
Ran your catch can to it??? I'm lost.....
Old May 29, 2008 | 06:16 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread....891&highlight=
Old May 29, 2008 | 02:40 PM
JRoX85's Avatar
newbie
Ok, if you have ever looked inside you im, there usualy is a small amnt of oil build up due to driving the crap out of your car. the oil is dirty and gets circulated back into the block. with a catch can it will stop the oil from getting into your im or block. It basically prolongs engine life and makes car run more productive. I never even noticed that write up LOL I jst used and extra obx racing can I had lyin around.
Old May 29, 2008 | 03:12 PM
redls1's Avatar
MAXIN' ON
I made one from stuff from northern tools.
Lakersallday24
Jun 16, 2019 01:35 AM
lux97Max
19
Aug 27, 2015 07:48 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
