300zx calipers
Old May 29, 2008 | 06:55 PM
TAZ's Avatar
TAZ
300zx calipers
Just checking in... what's the going rate for these and whichones are the better one by popular opinion: aluminum turbo 90-91 calipers or 92+ cast calipers?
Just checking, I got a lead with a national parts supplier and may be able to do some magic.
Old May 29, 2008 | 07:06 PM
MAX2DAMAX's Avatar
I'll take some , and in my opinion aluminum are way better, and look kooler
Old May 29, 2008 | 07:10 PM
slvrmax7's Avatar
That would be awesome man! Work some magic!
Old May 29, 2008 | 08:08 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
Ill start a list if needed LOL, that would be sick if you could pull something off
1. Fastmax05
2.
3.
4.
5.
6.
Old May 29, 2008 | 08:30 PM
TAZ's Avatar
TAZ
well we'll see, whats the going rate for new remans? anyone know, I found a couple sets on ebay for 350-400 f/r set used, but can't find much new
Old May 29, 2008 | 08:38 PM
!PrjctMax!'s Avatar
'91 will guarantee you 30mm aluminum calipers
Will purchase brackets if supplied
Old May 29, 2008 | 09:07 PM
DeusExMaxima's Avatar
I went with aluminum and I paid $80 a couple years ago on ebay. By the time I rebuilt them, bought adaptor, painted them, put in good pads, etc. it cost about $400.
Old May 29, 2008 | 09:57 PM
STARR's Avatar
How does one count the pistons in the calipers, the OEM 6th Gen Calipers are single piston but have 2 pistons, 1 for each side, so a 4 piston setup would have 8 in the caliper right
Old May 30, 2008 | 12:43 AM
That doesnt make any sense. The OEM calipers have 1 piston in each caliper, 1 piston on 1 side of the caliper. The 300zx calipers have 4 pistons per caliper, 2 piston on each side of the caliper. The OEM and 300zx calipers are totally different calipers. The OEM is a sliding caliper, the 300zx are fixed. Hope that clears it up some.
Old May 30, 2008 | 04:43 PM
STARR's Avatar
So how do the 2 pads compress onto the rotor if only 1 piston is in the caliper, I thought u would need a piston to push on each pad
Old May 30, 2008 | 05:20 PM
!PrjctMax!'s Avatar
[ l ll l ] o
bracket/caliper-left pad-rotor-right pad-bracket/caliper-single piston
Single piston pushes on right pad and that pushes on the rotor which also pushes on the left pad.
o [ l ll l ] o
o [ l ll l ] o
piston-bracket/caliper-left pad-rotor-right pad-bracket/caliper-piston
All pistons push on the pads with more surface area and equal pressure
Old May 30, 2008 | 05:35 PM
mooseq30's Avatar
nice red looks good with the red lip!!!
I like it alot!
Old May 30, 2008 | 05:39 PM
!PrjctMax!'s Avatar
I like it alot!
Old May 30, 2008 | 06:23 PM
VigilanteMax's Avatar
Taz, Ive researched these for quite some time and the going rate for the fronts remanufactured sumitumo aluminum loaded with pads are ~$300 give or take $20. These are not ceramic pads and are just OEM, but thats ok with for now. I would like a deal if you have one.
Old May 30, 2008 | 06:43 PM
Thats because there is a sliding part to the caliper. Take ur front wheel off and look at the caliper, or better yet, take off the caliper. You'll very clearly see how it works.
Old May 30, 2008 | 07:22 PM
STARR's Avatar
Originally Posted by !PrjctMax!
[ l ll l ] o
o [ l ll l ] o
o [ l ll l ] o
Thanks for the illustration, cleared things right up
Old May 30, 2008 | 07:23 PM
STARR's Avatar
I'll do that
Old Jun 2, 2008 | 07:43 PM
redmaxpa007's Avatar
i SeE what you did therE
i have info... let me get it all together..................
and since i am pipeline over on nissancllub.com
those jokers can use this as well....
i just did this upgrade on the SE-R...
Old Jun 2, 2008 | 07:55 PM
this has tons of info on it.....
http://forums.maxima.org/showthread.php?t=395990
i am just cutting and pasting some of the info from ^^^ that thread..
i know someone said this already....
Here is a quick break down of the calipers for the z32:
1990 NON Turbo used 26mm Aluminum
1990 Turbo used 30mm aluminum
ALL 1991-1992.5 (Turbo & non turbo) used 30mm Aluminum
ALL 1992.5-1996 (Turbo & non turbo ) used 30mm Iron
Extracting the key point here, as long as you look for calipers for a 91 Z32, you are guaranteed to get 30mm Aluminum.
30mm part and brand
here is info i got first back in 03 when i was looking to do this....
http://importnut.net/300zxbrakeswap.htm
as you know
matt and jeff sell brackets
matt's bracket uses stock +04 maxima rotors
jeff's uses 13 in mustang cobra rotors...
Taz, i am sure you have already found most of this info.. just trying to help...
thats the basics..........
Old Jun 5, 2008 | 08:15 AM
MisterSparkle's Avatar
i would def be interested in a brake package deal...including 300 Zx BBK set-up, rotors, pads, backets...so taz let us all know whats going on.
Old Jun 5, 2008 | 08:30 AM
TAZ's Avatar
TAZ
I'm still working on pricing, so far being in canada is a big disadvantage when it comes to part reslling, since these calipers come up through the US, my supplier has already paid import fees which inturn get marked up and pushed onto me.
so far the best I can do is a front set of calipers with PBR ceramic or semi metallic for about $300 (core charge included), which is about the same as what you can get online already....but we'll see what I can come up with.
Old Jun 5, 2008 | 04:42 PM
!PrjctMax!'s Avatar
Joe, would you be supplying front and REAR brackets as well?
I think you would make a nice profit if you were to invent/produce a rear adapter bracket for the 300ZX calipers.
.02
Old Jun 5, 2008 | 05:49 PM
.02
I agree!!
Old Jun 9, 2008 | 12:42 PM
Shadow's Avatar
For the 6th gen are the calipers and parking brake separate? On my 4th gen, the only reason I didn't do the 300ZX caliper in rear was I wanted to keep my parking brake.
.02
Old Jun 9, 2008 | 05:12 PM
Parking brake is a drum brake that is internal.
Old Jun 9, 2008 | 05:14 PM
whoa....
shadow.... wow..!!!! did not know you were still around...
Old Jun 11, 2008 | 02:50 PM
Shadow's Avatar
I was out for over 2 years after selling the business. And the company I worked for blocked the .org so I never signed on. I recently switched firms and can check things out again. I no longer have my maxima though. I sold it to Euromaxima about a year ago. I've got an '06 IS350 and now that I've had it for about 2 years, I think I may start working on it. Nothing like what I did to the Max though.
Originally Posted by redmaxpa007
whoa....
Old Jun 11, 2008 | 04:06 PM
redls1's Avatar
MAXIN' ON
I used to have a is300. My lease on the max is over next year and was going to look at a is350. Good things to say about it?
Old Jun 12, 2008 | 04:55 AM
Shadow's Avatar
It's a great car; I got mine back in Feb. '06 so it was one of the earlier ones. So far, so good. The back seat is useless, but I knew that. Going from the Maxima to a Lexus was night and day in terms of fit and finish.
And to keep things on topic; for those of you who want 300ZX brakes, I would highly recommend getting the Cobra rotors. For me, that made the brakes. I originally had just the 300ZX brakes and rotors in '00. It worked ok, but I was slightly disappointed. Then I swapped to the Cobra rotors with Jeff's adapters and all of a sudden the brakes were exactly what I had been expecting. Power went way up.
Old Jun 12, 2008 | 07:46 AM
i don't get the difference between the cobra rotors and the 300zx rotors...can someone explain?
Old Jun 12, 2008 | 08:16 AM
Shadow's Avatar
Cobra rotors are just that, rotors off of a Mustang Cobra. They are 13" in diameter as opposed tot he 300ZX rotors which are 11".
Old Jun 12, 2008 | 11:24 PM
There is gonna be a huge difference between 300zx rotors and OEM Maxima rotors (1.6"), and maybe a slight difference between OEM Max rotors and Cobra rotors (.4")
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
beerman1378
Sep 8, 2015 02:19 PM
