shaking steering wheel on every brake?
Old Jun 7, 2008 | 10:24 PM
  #41
carcraze28's Avatar
A quick question, is warped rotor covered under warranty?
Old Jun 7, 2008 | 10:28 PM
  #42
WINTERFAUST's Avatar
3yr 36k. Some dealers **** and moan tell you its not. BUT it is, just tell them you want to talk to the manager. If that dead ends tell them you will call Nissan.
I don't even argue about it. We just resurface it. Unless you have porked your brakes and theres little pad left.
Old Jun 7, 2008 | 10:43 PM
  #43
carcraze28's Avatar
alrite, thanks for your information!
Old Jun 22, 2008 | 10:11 PM
  #44
jimmypronet's Avatar
Ok guys i got my rotors 3 days ago and i took an off today so i can go install my new rotors...... any suggestion in installing them? on front i know its easy but the back one i got no idea how it looks like...... and heres the pics on the new rotors....
and i also get me a VHT nite-shade so i can go tint my taillights.....
Old Jun 23, 2008 | 06:54 AM
  #45
VigilanteMax's Avatar
Very nice. you will be pleased
Old Jun 23, 2008 | 10:38 AM
  #46
guys i need help.....on the rear rotors i cant take it off any tricks or something? calipers are off aleady still cant take the rotors out it shakes a lil bit but im scard to pull it off.....
Old Jun 23, 2008 | 10:47 AM
  #47
KC2010's Avatar
There's a little hole in the rotor. Use a small flat head screw driver and turn the round wheel inside the rotor (inside the hole) to release the ebrake pads. It's just like how it was with the old drums brakes.
Use a flash light to peak into the hole. You'll see what I'm talking about.
Do you see the additional hole in the rear rotors you bought? That's what they're there for. Bro, don't sweat it. You'll be fine.
Old Jun 23, 2008 | 10:51 AM
  #48
ok yea i see it. its like a spring al the way to the hole....... let me try
Old Jun 23, 2008 | 11:33 AM
  #49
thanx man yea all rotors are off..... now another question.... on front how will i make it fit all the way to the studs? cuz like the stock one i need to hammer it out so it will come off.... in putting the new rotors should i put the wheels nad tighten the lug nuts so the rotors will fit all the way to the 5 studs?
Old Jun 23, 2008 | 11:58 AM
  #50
KC2010's Avatar
That's how it works. The OE rotor gets stuck from usage. Nothing major. I just did my front end this past saturday.
Install new rotor
Install Caliper Bracket - bolt back on with those two big bolts. Tighten the hell out of it.
Pads - make sure to leave the pad guides on the caliper bracket
Compress Caliper with C Clamp
slide the caliper back on the pads and rotor, bolt caliper to caliper bracket with the two "smaller" bolts.
install the wheels and torque
drive around to test
torque lugs again after you drive
This is what I do everytime I do my brakes.
Back rotors - Remember to turn the eBrake pads to the original place or as close as you can get it.
Remember: Your brakes might make a little noise for the next few 100 miles or so. They need to be broke in.
Take your time and do it right.
Old Jun 23, 2008 | 01:05 PM
  #51
Thanx mayne.... i tint my tail lights and i love how it came out
  #52
The front
Old Jun 23, 2008 | 01:06 PM
  #53
The rear
Old Jun 23, 2008 | 01:08 PM
  #54
Now i need to paint the calipers.... but damn cleaning the calipers is pain in the ***
Old Jun 23, 2008 | 01:34 PM
  #55
KC2010's Avatar
I wanted to do that. But I decided to wait and get upgraded calipers instead.
Old Jun 23, 2008 | 03:37 PM
  #56
mayne screw painting calipers..... so damn hard to clean i give up
Old Jun 23, 2008 | 03:48 PM
  #57
KC2010's Avatar
Did you buy the paint kit? I know dupli-color has one. Not sure if it's worth it. It comes with a cleaner. The instruction say to use a hard bristle toothbrush. You might want to try that. It has to be better than a rag.
Old Jun 23, 2008 | 05:37 PM
  #58
yea i bought one but damn i hope i can return it at autozone.......
Old Jun 24, 2008 | 05:55 AM
  #59
KC2010's Avatar
Did you get the wheels back on? I wanna see some pics.
Old Jun 24, 2008 | 08:54 AM
  #60
yea ill post pics later..... i decided to paint the calipers again
lowpost99
Oct 26, 2025 06:53 PM
BkGreen97
Apr 2, 2016 05:47 AM
dcam0326
Sep 8, 2015 11:02 PM
coasterswim
Sep 2, 2015 07:43 AM
