Project MU ebrake pads
Old Jun 18, 2008 | 11:32 PM
kamski's Avatar
.org extraordinaire
Trollin the Z forums for ideas, i found this.
I seldom use my ebrake while driving, but realized if i ever do need it........im F..ked. The ebrake even when properly adjusted is POS.
Then I found this.
http://www.my350z.com/forum/showthre...lutch+bleeding
The 350z's e-brake is very weak. If you pull it while driving straight, the rear wheels won't even lock up and it just rumbles and gradually slows you down. Usually, you have to upset the car, push the clutch in and then yank the e-brake.
To remedy this, I decided to try the Project Mu e-brake shoes. I ordered them from Performance Nissan last July, but they didn't come in until January. After shipping, the total cost was about $200.
I got my first chance to truly test them last Wednesday at Club Loose. The first time I tried them, it wasn't quite tight enough, so I pulled out the little coin holder and quickly adjusted it with a nut driver. My next run, I yanked the e-brake naturally, like I had done many times before. The rear wheels locked up so hard that I went into a spin. I had to laugh, because I was very impressed.
I got a few more runs in that night and it worked wonderfully. Although it's a little on the pricey side, I am very happy with my purchase and I highly recommend it to amateur drifters. I promise that I'll report in at the end of the season to let everyone know how it holds up.
Quote from LAWN_DART at my350z.com
Order from eddiet@perfnissan.com
FOR the new guys unfamiliar with the search function..
350z rear non-brembo brakes, fit the maxima.
Kamski
Old Jun 19, 2008 | 06:20 AM
NmexMAX's Avatar
dot dot dot ...
Keep in mind the Z33 is RWD, so it will be a bit harder to slow if only using the eBrake.
Old Jun 19, 2008 | 06:51 PM
Shoey1's Avatar
probably cause the brakes were out of adjustment, you need to adjust them so there is a VERY light drag on the inside of the rotor when you turn it my hand.
an e brake only has to hold a car still on a 30 degree hill according to most manufacturer specs
Old Jun 19, 2008 | 07:42 PM
WINTERFAUST's Avatar
IMO waste of time and money
Old Jun 19, 2008 | 11:48 PM
kamski's Avatar
.org extraordinaire
Ok there mr 33 posts. We'll talk again when ur brakes fail and u smash you face on the back of a semi.
For everyone else. Even with a properly adjusted ebrake, the device still sucks. This is an extra option. Some of us that track the cars and have more power, this is an extra little bit of protection for that "just in case" scenario.
If you have something stupid to say.......... go back to your old civic forum and tell it to someone that cares.
Kamski
Old Jun 20, 2008 | 01:34 AM
DeusExMaxima's Avatar
I live 15 minutes from Performance Nissan. I should try these babies out. I could be ht first "drifting Maxima!!!"
Old Jun 20, 2008 | 05:37 AM
VigilanteMax's Avatar
Check youtube for maximas in dubai and middle east...they beat you to it . Looks dangerous as hell when they are drifting these front wheel drive sedans.
Old Jun 20, 2008 | 09:20 AM
redls1's Avatar
MAXIN' ON
Kamski
Curious what 33 posts has to do with it?
Old Jun 20, 2008 | 09:32 AM
jingiko's Avatar
350z non brembos do fit our maximas.
front and rear pads. same as rotors
Old Jun 20, 2008 | 09:41 AM
redls1's Avatar
MAXIN' ON
front and rear pads. same as rotors?
Yes. Although 350z front calipers didnt work for me , the rears are fine.
Old Jun 20, 2008 | 10:01 AM
I believe early 350z front calipers and rotors are smaller. I also have rear 350z rotors and calipers. Nice upgrade.
Old Jun 20, 2008 | 11:06 AM
kamski's Avatar
.org extraordinaire
not sure...... bah.
When I come back from my annual leave ill try thease puppies out.
Kamski
Old Jun 20, 2008 | 04:26 PM
jingiko's Avatar
mmm i spoke to steve at mackin and they distribute the project mu pads.
they told us they use the same pads as 350z(non brembo) / murano
a customer wanted to see if it would fit so we had to order them for a 350z(non brembo)
and sure enough it did fit.
forget what year 350z we ordered but most likely the 04-05year
Old Jun 20, 2008 | 04:48 PM
redls1's Avatar
MAXIN' ON
My rears are from and 03.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
Forge277
Jun 13, 2016 09:26 PM
NmexMAX
May 23, 2016 07:38 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
