Is it possible to get 600 miles on a tank of gas?
#41
My mileage sucks. I get about 22 mixed city/highway, 24 all highway going 79 w/ cruise.
My 5th gen was marginally better.
I was under the impression that an intake could actually help mileage - is that true?
I drive somewhat aggressively, but nothing too bad.
Anything in particular that could be causing this?
I never get over 400 miles to a tank
#45
If you drive mostly hwy in flat areas, CC works. On hilly areas, turn it off and feather your throttle manually. Especially on down grades. You can really up your mileage by coasting down hills. Going up hills, do your best to keep in top gear, even if this means that you are slowing down.
Try not to use the accel button on the cc. It tends to downshift frequently, where if you manually give more gas, then set your cc again this has proven to be much more efficient.
I use my cruise all the time, like Ron Popeil says, set it and forget it. 71mph always warrants me between 26-30mpg's based upon wind and weather conditions. This is also with regular fuel. I tried premium for 3 months and it only warranted 1mpg better.
The 09 actually has a current mpg meter on one of the screens so you can better judge how you are doing.
#48
In some cases it does, you just need to be aware of what your engine is doing.
If it were a stretch of road with no hills... cc is fine. But more often than not (depending upon location) there are elevation changes.
If there are elevation changes, don't use cc.
anyhow, I'm not the type of person to even care what mpg I get, just some people make me when talking about cc.
#50
You use cc all of the time, but are you using it for fuel economy?
#52
Same here. But on that trip up north, I wasnt in any hurry, so I wanted to see how good a gas mileage I could get. I could have done even better if I went a little slower, but I kept it around 75 mph with AC on. I see these little cars advertised getting 32, 33, or 34 mpg and i got 30.0 mph on a 420 mile trip in a modded V6. woohooo!!
#58
I think its possible...just last weekend I drove to the border of New Jersey and Pennsylvania from Connecticut and burned only a quarter tank of gas and got well over 30 mpg...When I used to drive the 5th gen Maxima the same duration it burned twice as much
#59
It seems that these cars get exceptional gas mileage if driven gently. The moment you tromp it to the floor, the gas mileage drops hugely. Not only are some mods not detrimental to gas mileage, it may even help. Lowering a car reduces airflow under the car, which reduces drag - same with addition of front spoiler. Wider tires reduce gas mileage, but pumping them up a few pounds on long trip increases gas mileage. I believe my rear mesh valance may have helped gas mileage since it allows air to flow through the rear bumper instead of being trapped behind it. A UDP plus any other weight savings helps gas mileage since the car doesnt have to work as hard. Regarding intakes, exhaust mods, not sure of the effect on gas mileage.
I have an advantage with a 6 speed manual in that I can coast down hills which offsets the gas used to climb the hill and I can do that better than a car with an automatic tranny.
#61
I truely hate to say this but if any of you have ever driven a prius it really shows you how to drive at maximum MPG. Believe me I love to feel my baby go but with my K&N and that only I have been able to achieve 28+ in mixed driving. If fuel economy means the most to you a 3.5L maxi probably wasnt the best choice, but you can get reasonable gas milege if you arent constantly stomping on the pedal (which i love to do as much as the next guy).
#62
I've noticed great improvement in gas mileage after installing my lightweight rims. It went from like 15 to 17 MPG city. Then I eased of the pedal a bit and got about 19. Even if I drive like a stole it it never goes back to what it was a year ago.
Get rid of heavy sucker rims.
#63
I found my computer to be very acurate. I can just calculate what is left in the tank based on MPG it shows and when I get to the pump I am within 1/2 gallon. Last week I read about Toyota Prius owners and the techniques they employ, I hopped in the car and on the way home mixed city and highway I pulled over 27 MPG. You can do it too.
#64
We all like WOT, especially when you want to hear the Fujita growl but all in all the car is capable of decent MPG if you just don't constantly mash the pedal which I am very GUILTY of
#65
I thought my Maxima magically became a civic after a 2 hr trip to the beach (200 miles from PA - NJ ) until I read this thread. I got about 30-32mpg on highway driving at 50-60mph. I thought the ultra 93 gas kicked in but I guess it was drafting the crap outta my friends car in front of me. ( 2000 Maxima Se Auto, wish I had a manual :[ )
#69
That is one reason I prefer taking a state route (speed limit 45-60mph) rather than a hwy (speed limit 65-75mph) if that reduces the total distance travelled.
#71
I just did over 600 miles of interstate travel and I averaged over 26 MPG. There was some punching involved and lots of hills (adirondacs). If I coasted around 65-70 I would have easily obtained 30 MPG like I have in the past on other trips.
#72
Just took the 2008 on a 500 mile highway trip through PA. Lots of mountains and about 10-15% off interstate driving. I really worked HARD at driving the car in the most economical of ways. (Yes I ran the A/C most of the time.)
AVG 27.7 MPG with the CVT . ..........trust me ......it was not easy.
#73
That's weird becuase I did have the A/C running too and I didn't do anything special other then kept it fairly steady. I did stomp it on couple occasions and did do some heavy hills in the mountains. 26MPG wasn't hard to obtain. If I did all the possible tricks I am aware off I believe I doing 30MPG shouldn't be that hard. With over 21 gallons in the tank, it should be possible to get 600 Miles out of the tank. Problem is I don't have the time nor the patience to just waste a day and drive for no reason.
#74
For a short time I commuted 2 hours to work and then home, usually went on off hours, and hauling *** up and down the NJ Turnpike doing on average 75-80 and at times 90+ I consistently got 24-26mpg, only real hard take off was out of 1 toll both but usually I was easy on the pedal cause I filled up everyday
My range at the highest went to 525, mostly all highway
#76
here are the most recent numbers I had on 3 fillups, from the last week:
Total Gallons: 47.132
Total Mileage:1,298.6
Avg MPG: 27.55
Avg Cost/Gal:3.969
Total Fuel Cost: $187.12
85% approx hwy, 71/mph w/ cruise control and a/c on.
Avg MPG: 27.55
Avg Cost/Gal:3.969
#77
Reb, your numbers are right on for the 07-08 CVT. I think a conventional A/T provides better mpg than the 07-08 CVT when driving above 65 mph due to higher RPMs in the CVT. I think Nissan fixed that in the 09 CVT.
My 07 Max has 9,500 miles on the odo. Here are some of my mpg's at different speeds. Each of these are averages over at least 5 different observations. Each observation is obtained from the computer by running the car on cruise for at least 20 miles.
MPG @ 50 mph = 31.0
MPG @ 55 mph (2000 rpm) = 29.5
MPG @ 60 mph (2100 rpm) = 28.3
MPG @ 65 mph (2250 rpm) = 27.0
MPG @ 70 mph (2375 rpm) = 26.0
MPG @ 75 mph (2445 rpm) = 24.8
Xoomer, How do you fit over 21 gals of gas in a 20 gal tank?
MPG @ 50 mph = 31.0
