Changing front brake pads
Old Jul 14, 2008 | 03:57 AM
Big Mike's Avatar
Any instructions on how to change the front brake pads on a 6th Gen Maxima.
Thanks,
Mike
Old Jul 14, 2008 | 04:51 AM
!PrjctMax!'s Avatar
Take off the wheel
Two bolts holding the caliper on
Push the piston back in with a c-clamp
Put new pads in
Put caliper back on
Put wheel back on
Old Jul 14, 2008 | 05:19 AM
Hilbe's Avatar
to PrjctMax
I'd also throw in a little bit of lube on the caliper. You'll see where to lube it when you take it off...
Old Jul 14, 2008 | 05:23 AM
Big Mike's Avatar
Thanks!!!
Old Jul 14, 2008 | 03:39 PM
Internetraver's Avatar
I'll usually open the brake fluid cover before pushing the brake piston back in. Someone once told me you could blow a break line if you don't.
Old Jul 14, 2008 | 05:30 PM
Shoey1's Avatar
you wont blow a brake line lol. if you can stand on the pedal and not blow one then you can push the caliper back in slowly without blowing one. i think you should take any more advice from that person and let it go right out your other ear.
but back to the OP, do what max said and just lube the slides
Old Jul 15, 2008 | 07:20 PM
Big Mike's Avatar
Thanks for the advice fellas but I wont be needing to replace the brakes, I bout a Q45 today and got rid of the Max.
Mike
Old Jul 15, 2008 | 07:49 PM
!PrjctMax!'s Avatar
Mike
Good choice...I may be following the trade in route soon...
rbuswell
Nov 17, 2016 04:54 AM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
