Gas Gauge
Old Jul 14, 2008 | 02:59 PM
adaptabl's Avatar
Gas Gauge
I have a 2005 Maxima and the battery died. I replaced the battery and everything is fine now except the gas gauge. The needle is on the wrong side of the stop. When I start the can the gas guage moves up and is stopped by the post the usually stops the needle from going below E. When the battery died the lights and guages went nuts and the think the gas guage went around over the top.
Any ideas?
Old Jul 14, 2008 | 03:45 PM
ILL-Maxima's Avatar
You checked all your fuses, maybe one blew?
Old Jul 14, 2008 | 03:47 PM
brio_max's Avatar
Learning English...
Move it back with your fingers! I saw a guy on here having the same problem and if i remember correctly, that worked out for him.
Old Jul 14, 2008 | 05:33 PM
Shoey1's Avatar
if it a fuse then the needle wont move, which it does. not harping on, you just saying. you may have to take off the gauge cluster and manually set it back in the right spot
Old Jul 14, 2008 | 06:12 PM
adaptabl's Avatar
It moves. The problem is it can not go past the post that should stop it from going to low. I think if it was manually reset it would be O.K. How do I get at the needle to reset it? Is there an easy way to remove the clear plastic cover?
Old Jul 15, 2008 | 01:29 AM
brio_max's Avatar
Learning English...
You should check out the FSM section DI
This might help. http://www.vqpower.com/v2/infusions/...article_id=118
Old Jul 15, 2008 | 06:44 PM
adaptabl's Avatar
Thanks guys.
I went to the dealer this morning and they told me I needed a new cluster at $800.00 Not covered by the ASP warranty.
I went back to work and saw the link. After comming home it took about 10 minutes to fix the problem and everything is working great again.
Nissan can suck rocks for this one. I am not impressed by this type of service.
Bottom line you guys saved me some big bucks. Thanks again.
Old Jun 13, 2009 | 02:01 PM
tallblazer124's Avatar
Thanks guys.
Man my battery died and this same thing happened to me after the dealer changed it. Good thing i noticed it and the deal manual fixed it by opening up the cover for the gauge.
Old Jun 15, 2009 | 03:51 PM
Lovemycar's Avatar
Wow Nissan service center really sucks all they do is try to rip people off thank god for the Org
Miket2006
Mar 1, 2021 03:55 AM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
